Question about GE 30 in. JGP336 Gas Cooktop
Spark continuously on
Today since morning our JGP336's spark module is continuously on. the only way we are able to turn it off is to unplug it.
what do i do?
thanks much
  • 2 more comments
  • David Moore Jan 08, 2008
    Same problem. Solution?
  • freddozsa Sep 15, 2008
    My unit sparks continuously.
  • jyabc888 May 03, 2009
    I had the same problem today... I am asking my wife to dry it with hair dry.. and I will report back.
  • Anonymous May 17, 2009
    Just the trick the hairdryer worked like a charm. Worked in just a few minutes. In the future I'll keep the area under the knobs dry. Thanks for the help.
  • 248 Answers
If you have recently cleaned it, you may have gotten moisture behind the knobs and into the spark switches. Be very careful not to let moisture get behind knobs. Very dangerous. If this is the case, they may dry out themselves and stop sparking. If not you may need to replace a spark switch behind knob.
Posted on Nov 20, 2007
I had the same problem of ignition clicking after the stove top had been cleaned. Took the knobs off the ignition switches, used a hair dryer in each hole for a few minutes, problem solved!!
Posted on May 02, 2009
Thanks ....
I had same problem...I ran turned off the electicity to the cook top! Not a fan of Gas. but it is the best cooking and it's what I have!
Anyway this solved my Problem!
Posted on Aug 09, 2009
I had the same problem and took it completely out and was about to go buy a new one. I then found this site and uncovered that my wife had just cleaned it real good with a wet soapy sponge. I put it back in and the clicking start back up.
I took a hair dryer and blew it constantly through the knob holes (keep it clean fellas). After about 5 minute the clicking was less and less. 2 minutes later all silent.
Posted on Nov 08, 2008
I have a 30 in jgp336 gas cooktop that fails to ignite when it clicks what is wrong, it worked a few days ago and suddenly stopped working
usually the spark module is not put back together properly.
1 make sure the spark unit is clean
2 make sure the gas jet is pointing towards the sparker
3 make sure there is no aluminum foil or other metal near the sparker pulling the spark away from the gas
Jul 06, 2014 | GE 30 in. JGP336 Gas Cooktop
30 in. JGP336 Gas Cooktop: We have a GE model # JGP933SEK2SS gas cooktop. ...
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
May 18, 2010 | GE 30 in. JGP336 Gas Cooktop
All the igniters are clicking after cleaning - help!
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
Apr 18, 2010 | GE 30 in. JGP336 Gas Cooktop
I have a GE model jgp940 gas cooktop one of the four burner electrodes will not spark.
You have to determine if it is the electrode or the ignitor module and replace the component. A simple test is to swap the wires on the spark module for the non working one and see if the other electrode still works. If not the electrode is bad, if it does than the module is bad.
Dec 24, 2009 | GE 30 in. JGP336 Gas Cooktop
Gas cooktop starter continues firing
Turn your gas valve on, but leave your unit unplugged for a few days. You can light your burners in the meantime with a lighter so you can cook. Usually this problem is caused by moisture getting into one of your ignitor switches which are under your burner knobs. Most of the time the switch dries out and you can plug your unit back in after a few days. If it still keeps firing then you will have to replace one or more of your ignitor switches. Usually a very difficult job as most gas cooktops are now sealed burner units which means the top of your cooktop is bolted down to the burners with several screws or nuts that heat up with usage and become almost impossible to remove, without having to drill out the screws, or chiseling off the nuts. Be careful of boilovers or cleaning around the knobs with too much water to prevent this from happening again. Also get a surge protector at least 2000 joules or higher to prevent damage to you spark module. Good Luck, Appliance Specialists
Dec 16, 2009 | GE 30 in. JGP336 Gas Cooktop
All four burners will not ignite
first chk the power outlet and make sure there is 120 v available.if it is ok.more likely it is the spark module which is chkd this remove all the burners by removing the screws and then the top.then chk power at input of the spark module.if ok chg the spark module.
Aug 17, 2009 | GE 30 in. JGP336 Gas Cooktop
I own a GE Profile gas cooktop model number JGP940SEK1SS. The igniter continues to make a sparking sound when it is plugged in . We have to unplug the the stove to make it stop.
It could be one of the burner switches shot it out or spark module malfunctions.
Burner switches ***. part# WB18T10366
Spark module part# WB13T10046
Nov 30, 2008 | Cooktops
Igniter clicking when all four knobs in off position after water spill
It is possible that once the unit dries out the clicking will stop. If it doesn't, you will need to call someone to have the problem addressed. You will need a spark module and or an ignition switch(s).
Oct 28, 2008 | GE 30 in. JGP336 Gas Cooktop
GE 30 in. JGP336 Gas Cooktop Logo
755 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Dave Harrison
Are you a GE Cooktop Expert? Answer questions, earn points and help others
