Question about Olympus Stylus / mju 1050 SW Digital Camera
Can i access panoramic feature, it is always
I am unable to use my camera in panaramic mode, when i go into the menu to select panaramic mode it will not let me, as it is greyed out and anything i do does not change this. is there a setting where i will be able to select the panaramic feature??
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 88 Answers
Make sure you are using an Olympus XD memory card, most others do not support the panoramic photo setting :)
Posted on Aug 07, 2009
I don't have a problem as much of a question.. does the nikon n65 do panaramic pictures?
Not in the camera, but you could shoot a panoramic and crop it later. That is what most of the panoramic camera of that era did anyways. Use your widest lens.
Oct 23, 2009 | Nikon N65 35mm SLR Camera
Cannot select "camera menu" from the Top Menu
If the camera is in Auto mode those items cannot be selected because the camera is already using factory default settings and they cannot be changed, If you press the Ok button and change to P mode then you will be able to access all of those menu settings and make any changes you wish to the camera settings.
Dec 28, 2008 | Olympus Stylus 850SW Digital Camera
How do you take panoramic pics on an olympus e410,in sene mode it
make sure that xd is selected in the menu...if you have compact flash in your camera, take it out and try again
Dec 18, 2008 | Olympus SP-550 UZ Digital Camera
Pictures print panaramic
Double check your camera as this model did have a panoramic version available and you had a lever on the side of the camera to select normal/panoramic.
If this is not the case you may have a problem with the shutter on your camera.
Check on the negative and if the exposed part runs is the lower third of the negative it is a shutter problem and needs to be looked at by a repair tech, if the exposed part of the neg is even and runs through the middle of the frame. I am pretty sure you have a panoramic camera and you would just need to switch it off
Nov 15, 2008 | Konica Minolta Maxxum 3Xi 35mm SLR Camera
Red hand symbol is flashing on the view screen
This is the sign warning you that the shutter speed is slow so camera shake is a problem. It means use a tripod or support the camera because holding by hand will cause blurred pictures that you see. When you see this sign you can either try to get more light on the subject or support the camera. This sign will also come on the low light conditions. Look at the shutter speed & you will see that this symbol will appear when it falls to about 1/60th of a second. Using a tripod is the best idea especially for a panoramic shot as when it is on the tripod you can turn the camera through 180 degrees taking overlapping shots then "stitch" them together in Photoshop or whichever software you use to create a single large panorama. If you don't have a tripod then put the camera on a wall or lean against something to give you more support. Good Luck!
Aug 10, 2007 | Nikon Coolpix 4600 Digital Camera
Panoramic Pictures
If I remember my last Olympus camera it would only work in Panorama mode with an official Olympus memory card. No third party cards would enable that feature. My instructions read "An Olympus xD-Picture Card is required for panorama shooting." If you are using an official Olympus xD-Picture card, there may be a problem with your camera.
Jul 19, 2007 | Olympus FE-230 Digital Camera
Small bright dot
Pixel Mapping is a feature of the camera to check and adjust the CCD and image processing functions. Locate Pixel Mapping in the camera's Mode Menu and select OK to activate it. Once Pixel Mapping is completed the Mode Menu displays. The bright dot should no longer appear in your downloaded images.
Sep 01, 2005 | Olympus ? Stylus 500 Digital Camera
Small bright dot
Sep 01, 2005 | Olympus D-595 Zoom Digital Camera
Shooting features
There is an option where you can set the camera to capture two images side by side, within the same frame. This feature is called “2 in 1” and can be accessed through the Mode Menu. Press the OK/Menu button, and use the right (>) arrow key to access the Mode Menu. Press the up (^) or down (v) arrow key to navigate to the CAMERA tab and then use the right (>) arrow key to access this sub-menu. Use the down (v) arrow key to navigate to the “2 in 1” feature and by using the right (>) arrow hey the “2 in 1” feature will be active for the next two shots. After the second shot the camera will display the menu option for “2 in 1”. You can select the option again, or you can return to normal shooting by pressing the OK/Menu button.
Shooting features
Aug 31, 2005 | Olympus D-545 Zoom Digital Camera
Olympus Stylus / mju 1050 SW Digital Camera Logo
100 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
