Question about GPS
MY H2OC LOWRANCE HAND HELD GPS IS LOCKED ON MY LAST POSITION
I HAVE CHANGED BATTERIES
CHECKED TERMINALS ON SIM CARD
I GET 3 TO 4 SATELITES BUT IT WILL NOT LOCK ONTO NEW POSITION
    Brigadier General:
  • 4,090 Answers
Check the BAUD rate is correct as in the manual
Posted on Jul 22, 2009
I have a ifinder hunt GPS, it will not locate any satellites, it then prompts me to stop searching or continue to search for satellites. I have been trying this device over the last 10 months, mostly on...
With a normal GPS device, when you first switch it on, it needs some time to locate enough satelites. Most of the time it needs at least 5 satelites. Some time should be like minutes and not hours. After the GPS device fond enough satelites, it knows where it is and can when it is switched on again work faster. When you try to let the GPS search for satelites indoors, or without a free view to the sky, it is possible the receiver never can find satelites at all.
I don't know if any test of the Lowrance iFINDER Hunt GPS was placed on the net, but that is where you can check how long it should take for the GPS to find enough satelites.
Oct 30, 2013 | Lowrance iFINDER Hunt GPS Receiver
Uppon "swich-on", my magellan gps 315 does not
GPS SYSTEMS HAVE A TENDENCY TO LOSE CONNECTIVITY TO SATILLITES BECAUSE OF BAD WEATHER, CLOUD COVER, TUNNEL ENTRANCE, BAD OR NO POWER, BATTERY LIFE HAS BEEN EXPENDED, HAZARD OF ELECTROMAGNETIC INTERFERENCE TO GPS SYSTEMS, AND IMPROPER VEHICLE MOUNTING AND HAND HELD POSITION. FREE SOLUTIONS 1. ALWAYS PLACE YOUR GPS DEVICE IN THE UPPERMOST PORTION OF YOUR VEHICLE SO THAT THE GPS SIGNAL MAY EASILY LOCATE YOUR DEVICE EVEN WHEN THE WEATHER IS BAD 2. KEEP YOUR BATTERY CHARGED ONLY WHEN IT NEEDS IT MOST AND AVOID CHARGING OFTEN 3. IF YOU OVERCHARGE YOUR GPS DEVICE, YOU WILL EXPERIENCE BATTERY LEAKAGE, WHICH CAN EAT AWAY AT YOUR CLOTHING, DESTROY YOUR DEVICE IN SECONDS, AND CAUSE DAMAGE TO YOUR VEHICLE SEATS 4. YOUR GPS DEVICE HAS A TENDENCY TO FREEZE BECAUSE OF THE SIM AND MEMORY CHIPS LOCATED WITHIN IT 5. YOU CAN FIX THE FREEZING PROBLEM BY REMOVING THE SIM CHIP AND MEMORY CHIP AND RESTARTING YOUR SYSTEM 6. OTHER FREEZE PROBLEMS OCCUR BECAUSE THE DEVICE IS COLD WHEN IT IS KEPT IN THE VEHICLE AND CHIP CREEK OCCURS WHERE THE DEVICES MICROCHIPS BECOME LOOSE AND TIGHTEND BECAUSE OF WARM AND COLDER AIR FLUCTUATIONS. IT IS BEST TO KEEP THE DEVICE IN A PURSE OR ON A TABLE WHERE IT IS NOT SUBJECT TO CONSTANT TEMP. CHANGE 7. PREVENTION OF ELECTROMAGNETIC INTERFERENCE IS BEST SOLVED BY: interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common
Jan 23, 2011 | Magellan GPS 315 GPS Receiver
The maps on my i way 250c are out of date - how do I up date them?
you may update them by accessing the factory website for your device GPS SYSTEMS HAVE A TENDENCY TO LOSE CONNECTIVITY TO SATILLITES BECAUSE OF BAD WEATHER, CLOUD COVER, TUNNEL ENTRANCE, BAD OR NO POWER, BATTERY LIFE HAS BEEN EXPENDED, HAZARD OF ELECTROMAGNETIC INTERFERENCE TO GPS SYSTEMS, AND IMPROPER VEHICLE MOUNTING AND HAND HELD POSITION. FREE SOLUTIONS 1. ALWAYS PLACE YOUR GPS DEVICE IN THE UPPERMOST PORTION OF YOUR VEHICLE SO THAT THE GPS SIGNAL MAY EASILY LOCATE YOUR DEVICE EVEN WHEN THE WEATHER IS BAD 2. KEEP YOUR BATTERY CHARGED ONLY WHEN IT NEEDS IT MOST AND AVOID CHARGING OFTEN 3. IF YOU OVERCHARGE YOUR GPS DEVICE, YOU WILL EXPERIENCE BATTERY LEAKAGE, WHICH CAN EAT AWAY AT YOUR CLOTHING, DESTROY YOUR DEVICE IN SECONDS, AND CAUSE DAMAGE TO YOUR VEHICLE SEATS 4. YOUR GPS DEVICE HAS A TENDENCY TO FREEZE BECAUSE OF THE SIM AND MEMORY CHIPS LOCATED WITHIN IT 5. YOU CAN FIX THE FREEZING PROBLEM BY REMOVING THE SIM CHIP AND MEMORY CHIP AND RESTARTING YOUR SYSTEM 6. OTHER FREEZE PROBLEMS OCCUR BECAUSE THE DEVICE IS COLD WHEN IT IS KEPT IN THE VEHICLE AND CHIP CREEK OCCURS WHERE THE DEVICES MICROCHIPS BECOME LOOSE AND TIGHTEND BECAUSE OF WARM AND COLDER AIR FLUCTUATIONS. IT IS BEST TO KEEP THE DEVICE IN A PURSE OR ON A TABLE WHERE IT IS NOT SUBJECT TO CONSTANT TEMP. CHANGE 7. PREVENTION OF ELECTROMAGNETIC INTERFERENCE IS BEST SOLVED BY: interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common
Jan 22, 2011 | Lowrance iWAY 250C GPS Receiver
Lowrance LCX 28c HD with Navionics HotMaps Premium SD chip. Chip worked fine last fall but when I went to use yesterday the Lowrance would not read the chip.
I had the same problem with my handheld Lowrance Hunt C. After installing the card and locking it in place, I had to slide the card "out" toward the locking mechanism. It barely moves, but worked after that. Whenever I load the card, I now slide it out or wiggle it and it works every time.
Apr 20, 2009 | Lowrance Lcx 28c Hd 7" Gps Fish Finder...
Lowrance iFinder H2Oc analog speedometer...
I found that it works better to push exit three times from the map view.
Mar 08, 2008 | GPS
Can't lock onto satelite signal!!
Sounds like the aerial. There is a very fine wire in the center of the male aerial plug. If this is bent then you will have that problem. Aerials are hard to get, dealers say they are obsolete...update your model. Cheers, Peter
Feb 27, 2008 | Lowrance Globalnav 310 GPS Receiver
New H2O C cannot find any satelites
hi
I have been useing the H2O std unit for about 3 yrs and dont claim to be expert but may be able to help you if your still haveing same problem contact me at randy487vs@yahoo.com
Dec 29, 2007 | Lowrance iFINDER Expedition C GPS...
Can't get position fix
Check to see if the date and the start point location where you are located are properly set. The GPS needs close enough location and date to know where it is starting from.
Read the instructions about the initial setup.
Jerry G.
Nov 28, 2007 | Lowrance iFinder GPS Receiver
GPS Logo
200 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
