Question about Kenwood KDC-MP2035 CD Player
KDC-MP2035 Issue I had some repair work done on my car, specifically on the driver's side door.  Apparently, the door was open all day so the dome light was on.  When I went to pick up the car the next day, the battery was dead and I had to be jumped started to leave the repair place. MY KDC-MP2035 no longer switches to Aux or Sirius - it will only indicate that it plays CDs if a CD is in the player.  Right now I have access to the radio tuner and Standby. Any help is appreciated.
  • 626 Answers
Re: KDC-MP2035 Issue
According to the Manual, which is here, you need to ENABLE to AUX thru the Menu Setting.
Instructions begin on Page 18.
Best of Luck.
Please RATE my solution BELOW.
Posted on Nov 20, 2007
Re: KDC-MP2035 Issue - Kenwood KDC-MP2035 CD Player Car Audio Receivers
I have the same problem
Posted on Nov 06, 2008
0 characters
3 Points
My kenwood kdc-mp2035 display reads protect. how can it be reset so it works again?
Mine started to do the same thing and they said it was going into a power save mode and that I would just have to replace it :(
Nov 19, 2012 | Kenwood KDC-MP2035 CD Player
What is the code for stereo kenwood kdc-mp2035
You can enter a 4-digit security code as an option after purchase of the unit. If you do so, make sure it is noted down somewhere. If you did select a code (or the previous owner has done so) this must be used when the unit is removed from the vehicle, or the constant power source is disconnected from the unit. When constant power is restored to the unit, the security code must be entered before the unit becomes operational. If the code is lost or forgotten I am afraid the unit has to be re-coded by a Kenwood dealer.
Hope this helps, Good luck with it.
Mar 29, 2011 | Kenwood KDC-MP2035 CD Player
I need unlock code for my kdc-mp2035 kenwood stereo
Unfortunately Kenwood codes are only available from the Main Dealer or by using a Radio Decoding Service who will connect a laptop to read the working code inside your radio`s memory chip (EEPROM)
Mar 27, 2010 | Kenwood KDC-MP2035 CD Player
Kenwood kdc mp2035 locked need a code to unklock
i no a trick for this ,put it in the freezer over night and it will crack the code crystle,yes i said put it in the freezer
Dec 27, 2009 | Kenwood KDC-MP2035 CD Player
Kenwood KDC-MP2035 cd player has power and everything functions but there is no sound. The 10A fuse in the unit is good.
make sure that the power output is enabled. this will turn on you internal amp. I have the same unit and I fouund this to be a problem. If this does not work your out put amps might be fried. good luck.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
Dec 07, 2009 | Kenwood KDC-MP2035 CD Player
How do you work the aux input? im trying to connect my ipod to through an auxilary cord but im not getting any results?
I have the answer for this problem...finally! This is by far the dumbest instruction manual ever. Here goes:
while in standby mode, push and hold down the menu button until the display changes. Once the menu is up, toggle thur (using the am/fm toggle) until you come to AUX OFF, now toggle it to AUX ON. Exit the menu. Plug in your ipod and push the SRC button until AUX is displayed and enjoy.
Oct 23, 2009 | Kenwood KDC-MP2035 CD Player
I have a Kenwood kdc-mp2035 and it says protect on the screen and plays no music. how do i get rid of that so i can listen to my music again????
You can try pressing the reset button, worked for me for months but now, for me, the "PROTECT" never goes away... But the reset button worked for months, give it a try!
Sep 02, 2009 | Kenwood KDC-MP2035 CD Player
How do you reset this deck
There is a reset button on the left front of the deck>
Feb 16, 2008 | Kenwood KDC-MP2035 CD Player
Setting the time on a Kenwood KDC-MP2035
Make sure the power is off before setting the clock (hold down the "FUNC" button until nothing shows but the time). Then Hold down one of the buttons on the right side for like 3 seconds until the time starts blinking. I can't remember which button it is as I don't have the unit in front of me right now. Use the track buttons to adjust the time. Hope this helps!
Dec 21, 2007 | Kenwood KDC-MP2035 CD Player
Kenwood KDC-MP2035 CD Player Logo
589 people viewed this question
Top Kenwood Car Audio Receivers Experts
xxxxxx xxx
Pablo Gonzalez
Are you a Kenwood Car Audio Receiver Expert? Answer questions, earn points and help others
