Question about KitchenAid KAWS850L Top Load Washer
My washer fills the tub, but when it goes to next cycle just hums
I have a Kitchen Aid top load washing machine and it was working fine until we put a fairly large load in it. My wife noticed a burning odor and unplugged everything. I scooped out all the water and then checked things out. It all seemed to be in order so I plugged everything back in and tried the washer without clothes in it, the tub filled with water but onlly buzzes instead of advancing to the next cycle.
  • 15,935 Answers
Your motor has failed.
Remove it from the washer to have it repaired or replaced.
Thanks
:D
Posted on Jul 20, 2009
Just put all new hoses on y kenmore top loading washer machine went to fill and it almost overflowed no spin or any other cycle working
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tub. As the water level increases the air in the tube is compressed until there is enough pressure to make the switch stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
Oct 26, 2010 | Kenmore Washing Machines
Machine keeps overflowing during wash cycle
Water inlet valve
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
May 20, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer fills, but overflows, will not go into wash cycle on any water level or washer setting, however on final spin cycle will spin water normally!n HELP!!
Feb 11, 2010 | Maytag PAV2300 Top Load Washer
WASH MACHINE KEEPS FILLING WITH WATER AND WON'T GO TO THE NEXT CYCLE.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tub. As the water level increases, the air in the tube is compressed until there is enough pressure to make the switch, stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
Dec 15, 2009 | Whirlpool WTW5100S Top Load Washer
Washer stops at rinse cycle-hums and has a smell.
Problem is with your lid switch which has to be replaced. This is if your filter is all clean.
Feb 28, 2009 | Kenmore 15864/15862 Top Load Washer
Clothes washer just makes a noise like a gear spinning ?
I was having the same problem with mine so I took it apart. There is a plastic coupler-like device that connects the drive motor to shaft which allows your "spin" cycle to commence. This coupler has posts in side it but they are under the little belt. My posts were all broken so the bottom piece of the coupler was spinning but the top was not, so it just made a humming noise. This part is available at
http://www.searspartsdirect.com
partNumber=3363664
Nov 24, 2008 | KitchenAid KAWS850L Top Load Washer
Washing machine will not go thru it's spin cycle.
I just replaced the 4 rubber straps on the tub. Washed a load and it worked fine. Washed a second load and it did not spin on the rinse cycle. Checked the wiring on the switches. All OK. What do I check next. Did I mess up something around the tub ?
Nov 13, 2008 | Washing Machines
Washing machine fills, but won't agitate
maytag washer dryer stack unit , model # lse7806ace washer fills with water but won't agitate or do anything else. I had the same problem a year ago and replace the lid switch asssemby and fuse and it worked fine until now. the switch clicks when I open and close the lid and the pink and orange wires show continuity with the lid closed.
Aug 29, 2008 | Maytag LSE7806A Top Load Stacked...
Washing machine
check pressure switch hose
Jan 02, 2008 | KitchenAid KAWS850L Top Load Washer
Washer tub will only fill on the hot setting
Is the tap to te cold water turned on
I would check that
Jan 13, 2007 | Maytag MAV3905EWW 13 Cycle Washer
KitchenAid KAWS850L Top Load Washer Logo
300 people viewed this question
Top KitchenAid Washing Machines Experts
Sal DeAngelo
thinksewfast
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
