Question about Samsung Electronics - Others
Samsung HT-TX35R shutdown protection error
Hi, have had this system for around 16months, it has worked perfectly until just the other day when it displayed this message. I have so far taken apart the system, opened it up, cleaned it all out, removed the fan and put it back in, it appears to be in good working order. I have also tried the systems on a variety of settings to establish when and what is making it swtich off. The only time when it appears to stay on is when all speakers are unplugged and the system isnt having to work hard to create any sort of output. (My thoughts are it might be down to overheating, but the fan is working but it will work for about 30mins after being swtiched off for a while, this time will then decrease as i turn it back on for immediate use) Any help from any of you guys would be great????
  • 10 Answers
SOURCE: Error displaying 552
Hi ladakh the fuser unit has failed to reach its required temperature there are 3 possible causes 1.the thermister is faulty 2.the heater lamp has blown 3.the power supply is faulty you need an engineer to check and replace any parts
Posted on Mar 05, 2007
SOURCE: Memorex MVD4544 flashes error message that reads "SAFE"
Thanks! I couldn't figure it out either!
Posted on Dec 18, 2008
  • 7 Answers
SOURCE: WHAT IS THE DEST ERROR IN SONY AUDIO HI FI SYSTEMS
Disc Error you need to check the CD quality,condition ,& correct CD placement! There is a chance that the CD optic lens needs to be cleaned or replaced or CD lens motor mech. is bad & needs replacement!
Posted on Feb 04, 2009
SOURCE: "Protect" error - HTZ110
Home Theater System Is Displaying "Protection" spacer.gif As soon as the unit is turned on, the word "PROTECTION" will flash on the front panel of the unit and SHUT OFF. This error message usually indicates that the fan in the back of the unit is not on.
The PROTECTION feature automatically shuts down the unit to avoid further damage. The unit will need service if this error message is displayed.
Please use our ASC Locator to find your nearest Authorized Service Center
from samsung's web
http://www.samsung.com/au/support/faqs/supportFaqList.do?group=&type=hometheatre&subtype=hometheatresystems&model_nm=HT-Z110&dType=D&mType=UM&vType=R&prd_ia_cd=03030100&acc_ia_fl=&disp_nm=HT-Z110&menu=faqs
Posted on Feb 17, 2009
ginko
  • 19396 Answers
SOURCE: When i turn on my samsung HT-Z110, the word "Protect" appears...
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Posted on May 04, 2009
Samsung ht-f9750w blur-ray 7.1 home theater came up an error Protection then shut down automatically.
The unit has DC Offset, meaning a damaged amplifier. This issue will not allow to unit to turn until the damaged is repaired.
If you are interested in having your Samsung repaired, please look to my website at audioserviceclinic.com. Thank you.
Aug 08, 2015 | Samsung Audio Players & Recorders
I have a samsung HT-Z120 it show a PROT error
This error means that you are trying to play a region-protected disc that is not in the same region as your player.
It is possible to "hack" the region on your DVD player by following these instructions:
http://www.videohelp.com/dvdhacks/samsung-ht-z120/10244
Please rate my answer.
Thanks,
Chris
Mar 05, 2011 | Samsung HTP-1200 System
HT-Z320 displays PROT code and then shuts down
i had the same problem a prot display then it would shut down. turns out i had the sub disconnected(noise complaint from the shaking at my apartment complex) but the speaker wires for the sub connected to the amp or central unit. when i disconnected the sub i left the wires on the floor behind the sub separating the pos. and neg. somehow the wires got moved around and the pos was touching the neg. as soon as i noticed and fixed this problem the system was working fine. my samsung hometheater model is HT-BD1250
Dec 29, 2009 | Samsung HT-DB120 System
Samsung ht-x30 sutting down protection error
My samsung shuts down with "PROTECTION".Help me to solve the problem.David ilomo.
Dec 05, 2009 | Samsung Audio Players & Recorders
Same probleme ht-x250
with the receiver power off, hold down the stop button on the front of the receiver for 5 seconds. it will reset the system.
Aug 17, 2009 | Samsung HT-WP38 System
My HT-TX75 DVD flashes a message
First thing to do is disconnect all your speakers at the back of the receiver, then turn it back on. If it does not go into protection, post a comment and I can walk you thru troubleshooting. If it still goes into protection, your unit needs to be serviced. Hope this helps
Jun 24, 2009 | Electronics - Others
Samsung HT-TX52 keeps shutting off.
I've had the Samsung HT-TX52 for almost a year now, and just recently, after about 10 mintues it keeps shutting off. Its almost like new and hardly used, why is it doing this?There is no error message, it just shuts off. I've tried unplugging it for a day, taking out all my wires and reconnecting them perfectly, and it still does this robert
Jun 13, 2009 | Samsung HT-TX72 Theater System
Protection and shut down.ht-tx35
protection error message means that your unit's fan is not working
it is a feature to keep your unit from overheating
check if there is anything blocking the fan of your unit from rotation
Jun 09, 2009 | Samsung HT-X40 System
My dvd home theatre system ht tx75 keeps shutting down
check if there is anything blocking the fan of your unit from rotating
if problem still persist replace the fan
May 28, 2009 | Samsung HT-TX72 Theater System
Electronics - Others Logo
265 people viewed this question
Top Samsung Electronics - Others Experts
Jeff Sterrett
Jeff Sterrett
Tom Chichester
Steven's...
Steven's...
Are you a Samsung Electronics - Other Expert? Answer questions, earn points and help others
