Question about Cell Phones
We have a panasonic kx-t7730 corded phone system. We have 7 phone stations. They all ring immediatiely except one was programmed to have a delayed ring. How do we re-program this one extension to ring immediately like the other 6? How do we REMOVE the delayed ring on that one extension?
Not ringing and i can`t make calls from one line from panasonic kx-t7730
The phone plugs into a Pana system that requires programming. Ringing and line access are just two of the things that require you to select in programming.
Carl
Jan 08, 2012 | Panasonic KX-T7730 Corded Phone
How can we change the ringtone on Panasonic KX-T7730 phone?
You don't. Panasonic analog system phones have one ring tone. You can change the cadence (single double or triple) ring from outside calls, but not the tone.
Carl
Oct 26, 2011 | Panasonic KX-T7730 Corded Phone
How to switch on the ringer in Panasonic KX-T7730 ?
I have a 3 position switch on the left side of the phone. Since I doubt that's what you're really asking, the ring from outside lines is controlled by system programming. Consult the manual for your Panasonic system. In a TA series, it's program 408-409 for Day and Night ringing.
Carl
Jun 26, 2011 | Panasonic KX-T7730 Corded Phone
How to program ring tone on KX-T7730 for each CO? For example I want the inbound call on CO1 and CO2 to ring differently, and for the call for CO3 not to ring ... thank you !
Analog Panasonic phones have one "ring tone". You program it to ring or not ring, but the tone is exactly the same. Ringing programming is in SYSTEM programming in the 40x's, depending on the cabinet. In a TA series, inbound ringing is program 408 409 and 410.
Carl
Jun 15, 2011 | Panasonic KX-T7730 Corded Phone
Is there a way to turn off the ringer in certain rooms on this phone ? Panasonic KX-T7730 Corded Phone
There is. It's called a MANUAL. The particular operating and programming manual of the phone system will give you programming access and instructions on where to program the 40x locations to adjust direct and delayed ringing.
Carl
Jan 26, 2011 | Panasonic KX-T7730 Corded Phone
Hi I have panasonic kx-t7730 and I have a problem. We have two lines but only rings on switchboard. We also Use cordless panasonic phone but it does not ring unles i transfer to it. I have already done...
In a TA series, the ringing is programmed in system programs 408-410. You go to the main phone, enter system programming, and select those options and turn on ringing per line and per extension.
Carl
Sep 03, 2010 | Panasonic KX-T7730 Corded Phone
I use Panasonic Kx-T7730 as a propitiatory telephone. When someone calls from outside, All phones on the network ring. It had to ring only on the proprietary telephone.
The 7730 plugs into a Panasonic phone system. That system (KXTA, KXTD, KXT-something) has programming. Each system has a manual or set of manuals to program system ringing. Comment back or search the internet or your files for that manual and it can be reprogrammed.
Carl
Jul 14, 2010 | Panasonic KX-T7730 Corded Phone
How do you program ring length on a panasonic Kx-ta824 system via a panasonic phone model kx-t7735?
The length of the ring is fixed, the time before it forwards is programmed in 5 second increments in System program 202. Since it's defaulted to 15 and the maximum is 20, there's not a whole lot to work with.
Carl
Oct 28, 2009 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7730 Speed Dials - Please Help!
So I guess that means you're not programming SYSTEM speed dial numbers. Those are programmed from the system manager or operator's station. Personal speed dials are 1-0 and are programmed per set.
Carl
Sep 02, 2009 | Panasonic KX-T7730 Corded Phone
KX-T7730 programming manual
i have 10 extentions but my call ring to all extentions. but the ring to one extentions 101 only plz tell me
Aug 05, 2008 | Panasonic KX-T7730 Corded Phone
Cell Phones Logo
50 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
