Question about Epson Office Equipment & Supplies
When I tried to initially install the software on my new Dell computer for my new and not connected Epson NX110 printer I encountered the following error message: Epson.EXE: Epson.EXE-Bad image Epson Xtra 32 is either not designed to run on windows or it contains an error.
  • djepsen Jul 20, 2009
    Vista Home Premium
  • blueextc3221
    blueextc3221 May 11, 2010
    What O/S are you running??
    Scholar:
  • 40 Answers
The new dell pc comes with vista operating system . the printer drivers u were trying to install is not compatible with the operating system : follow the link or copy paste to download the drivers for vista operating sysytem .
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=128284&infoType=Overview
note :
1. make sure u leave no traces of old printer drivers on ur new pc .
2. make sure if u have windows vista 32 bit or 64 bit os ?
3. still having trouble ..
reach me @ http://www.crossloop.com/ironcross
Posted on Jul 20, 2009
I lost my installation cd how can I install without it
You can download the Epson printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :-http://www.epson.com/cgi-bin/Store/jsp/index.do?BV_UseBVCookie=yes
Jul 12, 2012 | Epson stylus nx110 All-In-One InkJet...
How do I LOAD CARTRIDGES INTO MY EPSON STYLUS NX110 PRINTER
Follow the link below:
http://files.support.epson.com/htmldocs/nx110_/nx110_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Click "replace ink cartriges" on the left of the page
and then select "Remove and install Cartriges"
May 04, 2011 | Epson stylus nx110 All-In-One InkJet...
Want to install the notbook to a epson aculaser c1100 printer
Hi.
First you will need to download drivers from Epson website.
Once download is complete you run the installer file and follow the on-screen instruction. Ensure that you authorize all system changes when prompted by operative system or security software.
Start the driver installation with USB cable to printer NOT connected to computer. The software will tell you when to connect the printer.
Here more on installing printer:The first thing that you will need to install a printer is a driver software...
Here download link: Epson Support - Drivers, FAQs, Troubleshooting
Jan 19, 2011 | Dell Inspiron Mini 10 Notebook
Epison nx110 printer want print says off line how to correct it
Check and see if you have print jobs in the queue[double click printer in printer folder] if so then delete them and then try disconnecting and reconnecting. If that doesn't work try uninstall completely then re-install & follow man. instructions to the letter...ie don't connect or switch on until the software prompts you
Sep 15, 2010 | Epson Stylus Multifunction Inkjet Printer/...
How do i make my computer except my epson nx110
What OS are you using? Drivers and software are available here: http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=128284&prodoid=63084353&infoType=Downloads&platform=All
Did you install the software before connecting the printer? If you didn't, uninstall the OS basic driver, unplug the data cable and install the appropriate one from the above site. Then reconnect when prompted.
Try a new data cable (scanners can be extremely sensitive to cable problems but a really bad cable will not let the printer talk to the computer at all). Make sure the cable is 6' long or shorter. If you use a print server or USB hub, try a direct connection. Check that a known working device works in the USB port. Make sure that the USB ports are active and not powered down for energy savings or security. (In Windows the first is part of the Advanced Settings from the Screen Saver set up control panel; the second is in the Device Manager.)
Is the computer with the problem connected directly to the printer or is another computer serving as a print server? If it is the latter, make sure that the firewall isn't blocking access. Make sure that the printer is a shared device (Devices and Printers (or Printers and Faxes), right click on the printer's icon and choose Properties. Then adjust the Sharing properties on the host computer.
I hope this helps.
Sep 01, 2010 | Epson Stylus Multifunction Inkjet Printer/...
New computer. no cd
You can get the driver from this site:
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=wsMoc1iChVGs8xyY6tppQqeurEYBTh8ntD7N++kOb2oU003D&tc=6
Feb 26, 2010 | Epson Stylus D92 InkJet Photo Printer
Cant get my Printer to work when connected to my laptop.
First thing I would do is uninstall any and all software for the printer that you have already installed. Use the Control panel Add/Remove.
Then open your Printers folder, right click on the icon for the printer if it is there and select delete,
After that, disconnect the printer from the computer, but leave it powered up.
You will need to know if your computer is a 32-bit or 64-bit system. You can find out if you right click on the Computer icon on your desktop and seelct properties. A window will pop up and if it is 64-bit it will say so in the window. If it doesn't say anything, assume it is a 32-bit.
Next you will need to download the correct software. Go to:
Epson NX110 Downloads
Under the Windows section there are drivers and utilities for 32 or 64 bit systems. Make sure you have the right one. You can install the driver alone or the driver + utilties. Whichever you do, click on the + sign on the left. This will expand the selection to the details and a download link. Click on Download Now.
If you get the solicition to provide an email address, enter it or decline and then Accept the License Agreement. From there you will get the download window. Select Save and then select Desktop when the Save As window opens, then click Save in the lower right.
The download will then begin. When it finishes, close any open programs and reboot your computer.
Again, make sure your printer is ON with ink and paper loaded. DO NOT connect the USB cable.
Run (double-click) the file on your desktop and follow the instructions and connect the printer when directed. Continue with the instructions.
Note: If you should get a New hardware found window just cancel it out.
For reference, here is a link to the start-up gude.
http://files.support.epson.com/pdf/nx110_/nx110_bb.pdf
Thanks for using Fixya.
Jan 04, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Missing installation software
Yes indeed. Here is the main support page for your printer:
Epson NX110 Support (Save it to your Favorites for future reference.)
Click on Drivers & Downloads.
Select your operating system from the drop-down menu. (Windows or Mac)
Since you are installing a new printer, select the Drivers and Utilities Combo Package. If you have Windows, make sure you select the correct one: 32 bit or 64 bit system. If you are not sure Comment back.
When you click on the package name it will expand and there will be a Download Now link. Click it.
You may get an option to receive emails from Epson at this point. You choose Yes or No, and Accept the EULA.
You will then get a Download pop-up. Best thing to do is to select Save and direct the download to save it to your Desktop. Once the download is complete, close the window. Close all of your open applications.
Prepare your printer (Power, ink installed, paper) as in the Setup guide. Make sure you do not connect the USB cable at this point.
Run (double-click) the file on your desktop to begin installation. Connect the cable when prompted by the software. That should get you going.
If you have any problems, just Comment back.
Note: In case you did not get the startup guide or user manual, there are links for them too on that main support page.
Sep 29, 2009 | Office Equipment & Supplies
Problem with Epson CX5000 Scanner Driver
Download in google for free registry repair for VISTA and repair ur registry and try to install again...
Still not working,Try to install driver's on another location
And rate me as FIXYA please
Dec 21, 2007 | Epson Stylus CX5000 InkJet Photo Printer
154 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
