Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Ge oven...gas....not heating right
My oven is set to 350, but won't go beyond 100 degrees. Any ideas?
  • Anonymous Mar 19, 2014
    oven cooks 100 degrees hotter
  • 213 Answers
There is an ignitor bar that has to operate properly to open the gas saftey valve. the ignitor can glow but be weak so it wont open the gas valve. replace ignitor to slove problem
Posted on Nov 20, 2007
Bosch double electric convection oven: top oven will heat and display code E1 15 once it gets to 350 degrees, will continue to heat with no response to temperature choosen. Set oven to 350 degrees and...
replace the oven temp sensor, it looks like a metal rod sticking out from the inside back wall inside the oven. part here....
http://www.repairclinic.com/PartDetail/Oven-Sensor/650101/1557889
Jan 23, 2018 | Bosch HBL3420UC Electric Single Oven
Oven temperature
Hello....Go and get yourself an oven thermometer form a store like Target.Ther are accurate from 100 to 650 degrees and can either sit on, or hang from your oven rack...Then you can be sure...I hope this was helpful....PEACE....
Jan 05, 2012 | Ovens
My Kenmore 911-4298814 oven won't hold broil or bake temp setting. The oven powers on with no error. When I press the "Bake" and dial up a temperature to (say) 350 degrees, the LCD displays...
just had similar problem with frigidaire, temp display would go blank, not even show clock, i took off back of stove, the circuit board would wiggle. when i pushed in on the circuit board it worked correctly.
Oct 30, 2011 | Ovens
The oven does not heat to the set temperature. It is usually much hotter
You can have the oven recalibrated by a professional OR you can purchase an oven thermometer and check the temperature yourself. Place the oven thermometer in the oven.Set the oven to a specific temperature. When it indicates it is at that temperature check the thermometer. Adjust your setting by that many degrees. For instance, if you set the temp at 350 and the oven thermometer shows 450, then reduce your temperature setting by 100 degrees each time you use the oven.
Nov 15, 2010 | Amana RanARG7302 Gas Kitchen Range
How do I adjust the therastat on the oven. It is
Store bought thermometers are really slow to read the correct temperature. Give your oven at least a half hour closed to let your thermometer catch up. Calibration is very delicate and you could do more damage than good if you don't know what your doing. If you think your temp is off more than 100 degrees, chances are the thermostat is beyond repair. Anything less you can just adjust your temp to compensate. In my area, the gas company will calibrate ovens as a free service. Good luck!!
Jan 16, 2010 | GE Kitchen Ranges
Mer5875QAS electric range won't heat
Maybe bake element is bad or bake relay on board is bad.
Nov 05, 2017 | Maytag MER5875QAS Electric Kitchen Range
Temp stuck on 100 degrees
try unplugging the range for at least 30 minutes
Feb 08, 2009 | Amana ACF3355AS Gas Kitchen Range
My Kitchen Aid Supuerba top covection oven will heat to set temp 350-400 then drop over 100 degree's but still read on digital display 350 or 400
how do you know it is dropping 100 degrees ?
If the set temperature is 350-400 the heaters will work untill the thermostat will read that the temperature is reached - after that the heaters will shut down and the temperature will drop...and after few minutes when the temperature goes below thw set point (in this case 350-400) the heaters will turn on again - this will happen for the duration of the timing you have selected (example 45 minutes)
Oct 04, 2008 | KitchenAid Kitchen Ranges
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
370 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
