Question about AMD M863G (M863G15CV22ARV000) Motherboard
Blank monitor upon turning on PC
The monitor remains blank after turning on PC
    Sergeant:
  • 121 Answers
Well.... The motherboard could be dead... or check the power supply unit. Check the memory chips, see if the capacitors around the processor looks blown up (then motherboard is kaput) or make sure the monitor is properly connected to the motherboard monitor port... It could be numerous reasons ... See if the processor cooler fan is running and check if the processor's cooling paste is OK which would cause the processor to run TOO HOT and would prevent the PC to start-up etc etc....
Posted on Jul 20, 2009
My computer turns on but the screen remains black. What should I do?
The problem can be solved by these steps
1) Check the Video connector properly connected to PC
2) Monitor power supply cable fault
3) The VGA card is not working properly
4) The screen resolution is set to higher than the monitor supported resolution limit
The Best way to solve it replace monitor and see it is working properly
In case the monitor still stay blank you should check the VGA card
Try to start cmos setup and see whether the monitor still remains blank then it's VGA problem
Feb 07, 2011 | Compaq Computers & Internet
We recently were installing updates to our Acer Aspire One. Of course the computer had to restart. Upon shutting down, the computer has never turned back on. When you push the power button, you can hear...
Try Hooking an external monitor to the video output on the back of your computer to see if there is video activity present, if it works then we would suspect the LCD or the inverter board. But if both screens show blank then it could be a hardware issue. I suggest taking it to a computer tech for an estimate if all else fails.
Dec 20, 2010 | Acer Aspire One PC Notebook
I have a samtron 74v and upon booting up the screen stays black and a message flashing across my screen says "no optimum mode, recomended 1280 x 1024 : 60hz" but how can i change the resolution and...
Running XP? Boot the PC in safe mode (hit F8 key while PC is booting up and select safe mode), then set the video resoltuion to 640 x 480, reboot into regular boot up, reset the video resolution to 1280 x 1024 @ 60Hz.
Mar 19, 2010 | Samtron 74V 17" LCD Monitor
My monitor screen is ok for awhile but suddenly turns a dull yellow color. I just bought it a few months ago.
you must adjust the display settings in the software program that was being used to change the display setting.
  • If you have a flat panel LCD monitor, unplug the monitor power cable, wait about 30 seconds, reconnect the cable and then turn on the monitor. This resets the electronics on the monitor.
  • Make sure the monitor has power - the light on the monitor is on. If the light on the monitor is off, the monitor does not have power. Connect it to a different power outlet.
  • If the monitor has a detachable video cable, obtain a second monitor cable for testing purposes in case the cable is bad.
  • follw the another steps-
  • Replace the monitor power cable.
    1. Turn on the monitor. If the monitor displays an image, you are done. If the monitor remains blank, continue using these steps.
    2. Replace the video cable. Turn on the monitor. If the monitor displays an image, you are done. If the monitor remains blank, continue using these steps.
    3. If the monitor does not work after replacing the cables, replace or service the monitor
  • Thanks,
    Nov 18, 2009 | Compaq Presario 5000 PC Desktop
    Turning on but remains blank screen
    it may happen that your extetnal (VGA Display) is enabled, this will disable your LCD Display.
    just press Fn key and look function keys where monitor symbol is drawn ( that is F7 or F8 key. (turn on laptop then press Fn + F8/F7)
    Aug 20, 2009 | HP Pavilion tx1000z Notebook
    Blank screen upon startup
    Try taking out the hard disk, plug in power and see if you have a display on your screen or external monitor. if same thing happen, try taking out the memory card. If you hear a beep sound it's a faulty mem. card, if no beep sound appears I suspected it's a motherboard faulty.
    May 31, 2009 | Lenovo ThinkPad T61 Notebook
    Blank Monitor on my DELL
    Your display is having problems with the Inverter that generates high voltage to lit the lamp.
    This issue is explained (including how to fix it) here:
    http://josepino.com/?howto-repair-dell
    Good luck
    May 07, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
    Blank screen
    This looks like a problem with the video card or the power supply to the monitor. Try connecting a different monitor and if you still face the same problem then probably you may need to have a look at your video card or its connection in motherboard
    Feb 01, 2009 | ViewSonic A90f+ 19" CRT Monitor
    Monitor blinks and then remains blank after computer turns on
    THERE OR AN DEVICE THAT IS CALLED A CHOCK AND IT IS A MAGNET IN A SQAURE HOUSING THE A CORD FITS OVER YOU CAN PICK THEM AT ANY ELECTRONIC STORE THIS MAY HELP WITH AN INPEDANCE PROBLEMS SOME TIMES
    CANDYMANGANDY
    Dec 13, 2008 | ViewSonic VA720 17" LCD Flat Panel Monitor
    AMD M863G (M863G15CV22ARV000) Motherboard Logo
    196 people viewed this question
    Top AMD Computers & Internet Experts
    David
    David
    rafnix
    rafnix
    Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
