Question about Toshiba E-Studio 161 Copier
Toshiba estudio 2500c C-448 (445) error codes
I have the error codes coming up constantly and we have gone as far to replace the fusing unit, power supply, and the LGC board. Do you have any further suggestions?
Thanks,
Brian
  • Toshiba Master
  • 653 Answers
Did u clear the status counter ?
After repairing the matter which caused the error [C448], perform the following:
(1) Turn the power ON while [0] and [8] are pressed simultaneously.
(2) Key in "400", then press the [START] button.
(3) Change the displayed current status counter value "32" to "0", then press [ENTER] or [INTER-
RUPT] (to cancel C448).
(4) Turn the power OFF and then back ON. Make sure that the equipment enters the normal status
Posted on Jul 20, 2009
  • Toshiba Master
  • 653 Answers
    New Friend:
Did the counter of Toshiba E Studio 445 can Backward?
Posted on May 10, 2016
To clear the code error c413 of Toshiba estudio 2505
How do i clear the error code C413 at Toshiba estudio 2505 thnx, regard asif ali
Feb 08, 2017 | Toshiba Office Equipment & Supplies
I have toshiba e-studio 2500c error code E030. No paper jam.
Power-ON jam: The paper is remaining on the
paper transport path when power is turned ON.
Nov 27, 2016 | Toshiba E-studio 2500c Color...
Call for service C413 toshiba estudio 2006
Here is the verbage for the error code at this link
http://printcopy.info/?l=en&mod=erc&brand=Toshiba&model=e-Studio%202006&code=C413
In the interim you may try the following one time to see if it is a false error... Hold "0" and "8" while turning on machine.....continue holding until machine enters service mode. Enter "400" press enter. Enter "0" press enter. Power off / on. If code returns, machine needs parts replaced. Contact your Toshiba technician (there should be an 800 number label on the unit for service. Do Not keep resetting, may cause damage to Fuser Unit.
Aug 11, 2016 | Toshiba Office Equipment & Supplies
How do I fix a error code cc 41 on the Toshiba estudio 506 copier?
C41 Fusing unit warm-up error, defective thermistor, fusing lamp or thermofuse
Mar 25, 2015 | Toshiba Office Equipment & Supplies
ERROR CODE CC93 ON A TOSHIBA ESTUDIO 456
Knurled roller shift solenoid abnormality: An abnormality occurs in the knurled roller shift solenoid. [MJ-1032]
that's what the error means. If you've replaced the roller, solenoid, etc. you may need an actual Toshiba tech to help you.
Oct 17, 2014 | Toshiba E-Studio 456 Copier
I have a toshiba estudio 2500c. I have error code C3B0. How do I fix it without calling a service person?
I have a toshiba estudio 2040c. I have error code C3B0. How do I fix it without calling a service person?
Sep 08, 2011 | Toshiba E-studio 2500c Color...
HOW I PULL OUT THE DEVELOPERS
It is possible that the pressure in your fuser has been adjusted and is now too loose. You can adjusting this by tightening the two inlet silver screws on the fusing unit (the black unit with the yellow warning on it.)
Jan 22, 2010 | Toshiba Office Equipment & Supplies
Toshiba eStudio 2500c - CA00
This is a pretty complicated issue/problem. there are 5 pages devoted to this issue in the service manual. This issue would be best handled by a technician. but you could try the following....
[CA00] Color registration abnormality
<Color toner low density>
Turn on the copier holding down 0 and 8 and wait till it boots up into its service mode..then enter code 2692 “Prevention of color toner low density / change the zero to 1.
Then change code 2693 “Prevention of color toner low density / Judged number of sheets setting” value to 40 (default 20).
Make sure you have cleaned the main charge units by fully extending the rods with the green handles for each color.(open the front door) and use the plastic wand attached to the front door to clean the laser glass for each color..there is a small **** under each color unit to slid the wand into..felt side down on the wand.
Like I said there are several other complicated ways of fixing this.
Jan 15, 2010 | Toshiba Office Equipment & Supplies
Error code C380 paper feed failure
c380 indicates auto-toner error for black developer (K).
Check following:
Is the harness between the LGC board and the developer unit drawer connector open-circuited?
Is any harness inside the developer unit or the auto-toner sensor harness open-circuited?
Is the auto-toner sensor connector or the connector CN341 on the LGC board disconnected?
IF connector no problems, then u probably need to replace the auto toner sensor.
May 27, 2009 | Toshiba Office Equipment & Supplies
Toshiba E-Studio 161 Copier Logo
3,431 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
