Question about Casio EX-Z1050 Digital Camera
Camera was dropped in use and the lens has half closed and jammed! The camera will not turn on even to view the pictures on the memory card. Is there a way to reset or manually close the lens? Also do you need special tools to disassemble? as I cant see how it comes apart.
  • wranger433 Jul 20, 2009
    Thanks for this solution, however the camera wont turn on! I have tried it anyway and can sometimes get some life but it reads on the lcd screen VER 1.00 any button I press just turns off the camera and pressing nothing the camera tuns off automatically after a few seconds. I'd much appreciate any other ideas. Cheers.
  • 744 Answers
Hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...
thank u!!!
rate me!!
Posted on Jul 20, 2009
  • Prakash Ram
    Prakash Ram Jul 21, 2009
    If any digital camera is subjected to extreme humidity or just plain
    dampness it's a fairly good bet the battery terminals within the
    battery could become corroded. Check them before blaming either the
    camera or batteries. Quite often a vigorous rub of the battery
    terminals themselves with a sheet of printer paper(especially aa
    type)is enough to cure the problem.
    With most cameras you will
    need a torch to check the lower contacts in the camera and any
    corrosion will be easy to spot but even if you can't see any it's
    always a good idea to use a little piece of wet and dry wrapped around
    you index finger to rub the tops of the contacts.
    So don't forget, check the batteries AND the camera contacts.
    A
    good way to check to see if the batteries have had their day would be
    to pop them in a torch or other appliance after cleaning them to see if
    they work.
    rate me
My Kodak Easyshare V1223 turns on and shows all icons normally on the view screen as well as older pictures on the memory card...but shows everything else black and pictures remain black even with flash...
Hi!
It is not necessary something wrong with the camera itself. Sometimes the simptom is caused by the memory card. Reading from it works (so you can see older pictures) but every new picture is written wrong, so the camera shows only black.
Hope it is only the memory card in your case.
Good luck,
Bogdan
Aug 28, 2011 | Kodak EASYSHARE V1253 Digital Camera
I dropped my Canon PowerShot SD750. the lens comes out half way
Sorry, but there is no DIY fix for the lens problem, and any attempts at homebrew repair will likely worsen the problem. The camera needs professional repair, so I suggest that you take it to a camera shop (not the camera department at a large store) or contact Canon customer service via the Canon.com web site. Be sure to get a firm price before committing to repairs -- the cost to fix it may be close to the price of a new camera, and repairs typically only carry a 30-day warranty.
Dec 06, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Powers on, lens extends, 3 beeps, lens closes, camera turns off
Try doing a couple of things.
1) remove and digital media cards.
2) turn the camera on and delete any pictures that may be stored in the camera memory (not on a removeable card)
3) remove the batteries for 60 seconds
4) replace the batteries without the media card and lay the camera on a flat surface with the lens pointing up (5) The lens should retract.
6) Turn off the camera
7) replace the media card and turn on.
I think the camera was getting hung up on the pictures stored in the camera's memory.
Aug 17, 2009 | Cameras
Lines on screen and photos, too bright photos outside
Lines across your pictures or pictures too bright are due to the shutter not closing correctly or at all.
to check this- turn camera on, turn off flash, turn camera around and look into the lens. Adjust the zoom so that the shutter and internal lens comes up to the end of the lens and whatch as you take a picture. You should see the shutter close completely over the lens. If it doesn't move or does not close over completely then there is your problem.
If camera was dropped it could have jammed the shutter open or obstructed it in some way from closing completely.
camera will require repair/ service.
You may have some luck if you power up and down your camera numerous times before taking a picture. The action of the lens opening and closing may free the shutter.
Aug 07, 2009 | Fuji FinePix V10 Digital Camera
ERROR 99
if you have a DSLR and your'e getting this "error 99" it may be associated with the particular lens youre using. try turning off the camera and removing the battery, the lens, and the memory card. let it sit for half an hour. reinsert the battery only and depress the shutter button as if you were to take a normal picture. if error 99 occurs again, then the camera needs servicing. if it error 99 doesn't occur at this point, turn the camera off and install the memory card. format the memory card while it's in the camera and press the shutter button as if youw ere to take a normal picture again. if you see error 99, then the problem probably lies with the memory card. if it doesn't occur, turn off the camera and install the lens. again, power on the camera and press the shutter as if you are taking a normal picture. if the error occurs, then it's with the lens. try to clean the lens including the connection points both on the camera and the lens. if the error code still occurs, try different lens to narrow it down to which particular lens is giving the issue. if it happends with all the lens, then the camera needs to be serviced.
Sep 16, 2008 | Canon Cameras
Camera
It a lens misalignment try tapping the lens gently in an opposite direction the camera dropped on and that should pop the gear back into place
May 12, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
No power and lens will not come out
Your lens mechanism is jammed or off its "track" you need to get it realigned and lubricated w/a safe lube, like a white grease. You can try and gently "help" it out while it is trying to do this mechanically and if you hear a little ckick, then it may have realigned itself. Some have used compressed air to blow out any crud in there. Try these or take it to a camera shop. maybe they can help instead of sending it back for service as there is usually a fixed fee for ANY repair, big or small and usually eclipses the cost of a replacement camera, or very close to it.
Dec 28, 2007 | Canon PowerShot S3 IS Digital Camera
My new digital camara
Your lens is jammed. The only way to fix that is to send it into casio.
Nov 06, 2007 | Casio Exilim EX-S600 Digital Camera
Lens jammed
It sound like a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Sep 04, 2007 | Canon PowerShot A520 Digital Camera
Casio EX-Z1050 Digital Camera Logo
140 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
