Question about Fargo Office Equipment & Supplies
HEAD LIFT ERROR ON FARGO DTC500 - Fargo Office Equipment & Supplies
Where can i go to solve this problem of printheadlift?
Posted on Oct 23, 2010
  • makusafe Nov 14, 2010
    Turn off printer, and try to reseat the ribbom cable that connects to the back of the printer, if that doesn't work and you getting screatching sunds during boot up, the printer needs a new o-ring, and will need to go back to Fargo
    oops! back of Printer Head
I had the same issue with a DCT515. After doing a bunch of updates and getting no where I took the advice above and checked the o-ring. It was fine but there were some bits of plastic caught in the gears in the front of the machine that move the print head up and down. After cleaning them out with a pick and air can it started turning all the way round and now it works. Not sure how the plastic got in there but something to check.
Posted on Oct 01, 2012
  • 4 Answers
Replace the o-ring ubder the headlift motor
Posted on May 18, 2011
Solution to head lift error problem on my Fargo printer
You don't mention which printer model you have, but we mostly see that error on old DTC5xx printers. It is usually caused when a rubber o-ring within the printer has failed (broken), and the head-lift motor no longer has the necessary connection to the head-lift mechanism.
Jul 20, 2017 | Fargo Office Equipment & Supplies
Fargo dtc 550 head voltage error
Fargo DTC550 Head Lift Error - YouTube
? 4:46
https://www.youtube.com/watch?v=1MCO3wHmLgE
Jan 8, 2015 - Uploaded by Alfonso Terrazas L
Fargo DTC550. Head Lift Error. Este error se origina porque el O-Ring que hace girar el engrane que ...
Mar 22, 2017 | Fargo Office Equipment & Supplies
Troubleshooting
error code problem E020 ,0173
Aug 15, 2013 | Fargo DTC400 ID Card Printer Package
I am using fargo direct to card 550 printing machine.In that error displays "HEAD LIFT ERROR". sir how can i solve this problem and also have lots of noise is coming from the printer..please...
In this problem , first check the front side head lift gear and gear belt.
solution : Gear or gear belt may be broken.
by
LAKSHMI KANTH,
CHENNAI.
Aug 02, 2011 | Fargo DTC550 Thermal Card Printer
Service manual
Here is the manual for the DTC500 series. Good Luck!
Jun 08, 2011 | Fargo DTC500-LE Card Printer
The printer shows head lift error ...so ..how can I solve this problem ?
I had the same problem with my fargo dtc 550.
I changed the "O" Ring rubber attached to the printhead and that solved the problem. No more head lift errors.
Jul 02, 2009 | Fargo DTC550 Thermal Card Printer
Error/ Head Lift Error
If you replaced the o-ring on the headlift assembly and that did not solve the problem, most likely you may have a sensor out that controls the position of the head lift.
Dec 12, 2008 | Fargo DTC550 Thermal Card Printer
Printer restarts itself after putting it on
We would recommend to try to update the firmware for this printer from the Fargo website - www.fargo.com. Update the print driver to the most current version from this site as well. Run a test card from the LCD panel if the printer starts after your updates. If successful, run a test card from the print driver on the computer.
If this does not work, there may be major issues. Contact Fargo Technical Support at 800-459-5636.
Visit our id card printer blog for additional Fargo information at www.safecardid.com/blog.
Oct 14, 2008 | Fargo DTC525 ID Card Printer
Print quality with Fargo DTC500 printer
You might go to the print driver settings to change the way the printer prints the card. This can be found in the printing preferences. Go to the device options tab and choose "rotate front 180 degrees". Then print a card. This may fix the problem.
If not, try downloading the latest print driver from www.fargo.com.
Visit our id card printer technical assistance blog at www.safecardid.com/blog.
Sep 24, 2008 | Fargo DTC525 ID Card Printer
1,155 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
