Question about Nikon F801S 35mm Film Camera
Image through Nokia F80 viewfinder dark and cloudy
A few months ago I bought a second hand Nikon f80 (actual f80, the website doesn't seem to recognise it). All its functions are working since I last tested, although the batteries have died out since then. However, whenever I look through the viewfinder there is a dark and cloudy rectangle which obscures the whole image; around it is a clear outline, and there is also a small black curve across the top (definitely something else). If the camera is pointed at bright light, then this dark patch seems to fill up with white dots. I'm sure it isn't the lens, which I've cleaned, because the image remains the same if I remove the lens and look through the viewfinder. I don't think it is the mirror, which is quite dusty but otherwise looks fine. The focusing screen also looks normal, although there is a small scratch (which I can't see through the viewfinder anyway). I can't think of anything else; so I was wondering if anyone could tell me what it is and how to fix it/how much it would cost to fix, if it can be at all. Thanks,
CC
  • charlessjcon Jul 20, 2009
    please disregard this post
    Brigadier General:
  • 3,006 Answers
Please also ignore this answer, (see askers comment above). I've only posted it so that this question doesn't continue to appear as an unanswered one.
If anyone else has this problem please go to
http://www.fixya.com/support/t2637498-image_nikon_f80_dark_cloudy
for an answer.
Posted on Jul 26, 2009
I have an Nikon f80 camera and when I take a photo it takes a few seconds to take . can anyone tell me if I have the wrong settings on it
Yes you must have. This is a good camera. I always suggest reading the manual at least cover to cover when you buy it and then again after a month of use.
http://www.nikonsupport.eu/europe/Manuals/YIrdVGsET/F80_En_05.pdf
Nov 16, 2017 | Nikon Cameras
Hi I cannot get my F80 to autofocus. I have tried all my lenses on my Brothers F80 and they all work fine on his camera. I only bought the camera second hand a few days ago and i'm 99% sure when the...
If the gears are stripped, it will require an experienced tech to repair.
That being said, there should be a small switch near the lens mount to switch between auto and manual focus mode's, be sure that that switch is pointing to A. When set to M, the little screw recesses into the mount so it doesn't try to engage, when set to A, it'll extend very slightly.
Also, Nikon has manufactured two types of AF lenses - with the motor in the body and with the motor in the lens, as with most newer lenses. Your camera should have a small screw on the lens mount that drives the focus motor between the lens and the camera, but I'm not 100% certain on that. Your camera can focus lenses with and without this type of coupling. BUT, if that screw/motor in the body is not functioning, you'll only be able to use lenses which contain the focus motor inside them, or manual focus lenses (you can manually focus AF lenses too).
May 19, 2011 | Nikon F80 35mm SLR Camera
The depth of field preview function of my Nikon F80 (N80)
needs repairing at a qualified shop, when was it last cleaned or serviced ?
Jun 21, 2010 | Nikon F80 35mm SLR Camera
Image through nikon f80 dark and cloudy
I'm unfamiliar with the F80 but on models like the f65 and f75 the viewfinder screen has an lcd overlay and when the battery is exhausted or removed the viewfinder goes dark and blurry.
Looking at a picture of the f80 it looks like it's just an update on my f75 so it strongly suggests that you just need to insert a fresh battery. The lcd does draw power from the battery even with the camera turned off.
I hope that you found my answer useful, once you've tried another battery to confirm what I've suggested I'd appreciate it if you return the favour by rating my answer.
Jul 20, 2009 | Nikon F801S 35mm Film Camera
Nikon f80 b/w cmera
The camera will not support the newer lenses since they have the auto focus motor internally. The lenses do not have the coupler in the mount to match with the camera
Jul 27, 2008 | Nikon F80 35mm SLR Camera
Weird error message
Whenever you have a problem like this, start with the simple fix. Reset the electronics by removing the batteries, waiting a few seconds and replacing them.
May 08, 2008 | Nikon F80 35mm SLR Camera
Nikon MB16 fitting to Nikon F80
To quote Nikon. 'hold the camera's battery chamber cover at approximately 45 degrees to the camera body and then pull it out gently'.
Bill
Apr 19, 2008 | Nikon F80 35mm SLR Camera
Re: Shutter Wont click
Hi , check everything set c amera speed to 60/seconds auto or manual / check also the the camera shutter blade , open the lense and close to activate the shutter blade .
Feb 17, 2008 | Nikon F80 35mm SLR Camera
Manual Exposure mode Nikon F80
1) turn the mode switch/knob on the left of the camera to M ( manual mode ) 2) turn your lens to the highest f-stop ( 22 or 16 depending on your lens ) 3) in front of shutter release button you have control for your aperture : turn until the desired aperture is displayed ( view finder or the LCD monitor on the top ) 4) your shutter speed setting is controlled with your thumb with the control situated next to the strap lug on the right hand side of the camera. 5) press shutter release half way and look through viewfinder and see light meter reading and adjust either shutter speeds or the aperture as explained being guided by the l.meter.
Sep 23, 2007 | Nikon F80D 35mm SLR Camera
Nikon F801S 35mm Film Camera Logo
435 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Nikon Photography Expert? Answer questions, earn points and help others
