Check the alternator is putting out charge !
use a volt meter & rev motor a little to see if volts increas if it doesnt then get a replacement
Sorry to say your stator is toasted. Its not making amps for your batter to charge up. the way to test it is with a 12 volt battery start your bike and hold the volt meter to the positive and negative terminal. at idle it should be about 13 but at 2000rpm your looking close to 14 or better. if you dont have any of those numbers its your stator.
