Question about Microsoft Windows 98 for PC
Installing xp sir pls help me because i could not install windows xp on my pc. but I can only install windows 98 the specs is p4 1.6 ghz asrock m266a 256mb 40gb 300w psu
  • totomicsclan
    totomicsclan Nov 21, 2007
    tnx for the advice but sorry i didnt explain the situation further.
    the situation is this.
    i know how to install microsoft xp. the thing is that after i format in ntfs file and it is starting to copy files, it will stop and will not continue copying and later it will hang. i dont know whether i will update the bios of asrock m266a or not because i might damage the bios causing it to not work. this is my last option.
    pls help me
  • totomicsclan
    totomicsclan Nov 23, 2007
    sir have changed the memory module quite a while.
    i am using 512mb ddr400 in installing xp but still the same.
    the copying hangs and will not continue for almost 2 hours.
    do i need to update my asrock m266a?
  • 37 Answers
There could be a memory problem on your pc.
If your cd is damaged or some part of it is unreadable, there will be a message on the screen to tell you that there is/ are corrupt file/s that could not be read. This will prevent the installation to continue.
But in your case, the computer stops the copying process and then hangs. The set-up process uses some memory to copy the files and proceed with the installation.
Bad memory could be the reason why the installation process could not continue.
Try replacing the installed memory module with another memory module that is known working then proceed with the installation.
If the installation is successful, you must replace your memory module. I recomend 512 mb of memory for windows xp.
Posted on Nov 22, 2007
  • 46 Answers
What i can suggest u is(1) boot from the cd first to do that at the starting of booting press del key in keyborad and u will go to cmos there u change the first boot priority to the cdrom then save and exit the setup put the xp cd in cdrom restart the computer and it will show like boot from cd windows xp... press enter it will boot and then follow the instructions or (2) else if u alredy have any operating system working on ur comp then go to the operating system and then put the xp cd the cd will auto run there it show u setup or install windows xp after that it will boot from there follow the instructions any of the comp can have windows xp might be u have got a non bootable disk then go to the(2)solution
Posted on Nov 20, 2007
For my asrock m266a motherboard, when i clean install win xp OS and at halfway finished installing it the pc just hangs or stops. what could be the problem?
It is most likely an issue with the hard drive or at least that is the easiest and cheapest thing to test first. I would say connect it to another PC either directly or via a USB adapter and run a utility like check disk and then try it again.
Also make sure you don't have any thing connected to the computer you don't need: disconnect printers, cameras, thumb drives, remove TV cards etc. That extra stuff can only cause problems during an install. You just want the monitor keyboard and mouse and that's it in other words.
Jun 10, 2010 | Asrock M266A Motherboard
My asrock m266a having problem with the graphic card
Any card with an AGP interface is supported, just that the power of a new video card is severely limited by the capabilities of the motherboard and everything else on it (processor, memory, hard disk).
Ge-force FX5500 256MB is a good card but you can get something a little more powerfull, something like
May 08, 2010 | Asrock M266 Motherboard
Asrock 775i65G motherboard when i install widows xp can't continue, and hungs when setup windows excutive load,,how i fix this problem pls help me
Try installing Windows in a directory other than Windows. Let it be installed in say WINXP or whatever name you like.
Jan 13, 2010 | Asrock 4CoreDual-SATA2 Motherboard
Dear Sir I need driver sound for ASRockM266A mainboard
Here is the page to get drivers for your mainboard:
Thanks for using Fixya.
Dec 12, 2009 | Asrock M266A Motherboard
How much video card is the capacity of the my Asrock m266a motherboard?and also the processor?
There is the specs of your motherboard. You can have AGP 4x graphics cards.
Jul 23, 2009 | Asrock M266A Motherboard
No audio sound
a driver called AC'97
you can get it from dell's download support... good luck!
May 27, 2009 | Computers & Internet
Windows xp does not continue to start up
Hi if you hear knocking noise from the hard disk then it has conked off - as for the data there are service agents who claim to retrieve even from bad hard disks - search for them on the net .
May 28, 2008 | Asrock M266A Motherboard
No sound coming from the computer
After I have formatted my computer, there is no sound out of my computer. I want to get sound driver,but I can't find one.
Apr 27, 2008 | Asrock M266A Motherboard
How to work tally 4.5 in windows xp
pls send me reply for this how to work tally 4.5 xp
Mar 14, 2008 | Oracle 10g Database Standard (ODBSEONUPP0)
Microsoft Windows 98 for PC Logo
96 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
