Dyson Ball DC24 Bagless Upright Vacuum Logo
Rebecca Smoak Posted on Nov 27, 2016
Empty hatch on canister will not open - Dyson Ball DC24 Bagless Upright Vacuum
Jacob Fare
Level 1:
  • Contributor 3 Answers
  • Posted on Dec 27, 2020
Jacob Fare
Contributor
Level 1:
Answers
Questions
Helped
1970
Points
7
Sometimes on mine, the red clip that's at bottom of canister doesn't always click back into place, so when you press the red button, it just slides out missing the catch. How i resolve this i pressed down the red button so the clip was sticking out, then with my thumb pressed it in, and it clicked back into place, now been fine with each empty.
How do I open the canister
Make, model? Your question is asking a doctor what is wrong with you and giving him no info.
Nov 22, 2014 • Vacuums
How do i clean the canister va
Hi Agnes....what is the make and model of your vacuum?
Regards,
Dennis
Sep 28, 2014 • Vacuums
How do I empty the hvc-22
If you are meaning the DC24, like your post seems to be tied to, the manual can be found here:
https://www.dyson.co.uk/medialibrary/Files/Dyson/Support/downloads/UK/floorcare/Manuals/DC24_Manual.pdf and the pictures for removing the canister and triggering the lower empty-hatch are on page 3 under 'Clear Bin Emptying'.
Good Luck!
Latch on my dirt devil total pet canister to empty is stuck. how do I make it open
I bet I have the same problem as you. My vacuums canister was put back together backwards and now will not move far enough to click unlocked. I am not sure how to fix this and I cant find anyone on any forums who do :( If you figure it out post it! So far ime just trying to muscle it open.
Where is the filter on an electrolux canister and how to you change it.
This model has the filter beneath the tools/attachments.
Open the hatch to gain access to the tools. Release latch/tab at the front of the tool holder, and lift. Remove and replace filter. This should be done every 6 bags.
For additional information, check your manual, or download one from the below link. The Guardian will be listed under "older models".
How do you empty the dirt out of it
The plastic dirt holder should have a lever that opens the canister.Should come right out with a slight pull.empty contents into the trash.
1helpful
How do u open up the compartment to empty the trash
I couldn't figure that out either...since I misplaced the owner's manual...Anyway, there is a little gray colored knob at the top of the "collection" canister...and simply press that button and it disassembles that canister from the rest of the upright and then you are able to empty that trash contained therein.
2helpful
Hi, im hoovering my mothers house whilst she is away, using a vitesse pet lover, but now the cylinder is full and i can work out how to open it so i can empty it. thanks
Lift the catch where the canister lid joins the handle, then pull the whole assembly away from the handle.  Take the assembly to wherever you want to empty it, then press the button at the bottom front of the canister.  The bottom swings down and the muck falls out.  In the ideal world, you will then take the lid off by twisting it slightly anti-clockwise (you'll see the "lock" and "open" markings on the canister rim), remove the pleated filter (again by twisting anti-clockwise), give it a good shake and then brush between the pleats.  Reverse this process to put it back together, and away you go again!
I hope this helps. Any more questions, just ask. Please remember to rate my response, thank you.
1helpful
I can not find how to get the canister apart to empty the dirt.
From the bottom of your machine going upwards past the handle that is on the canister portion of this vacuum, you will see that the top of that canister had a depression where you should be able to put your fingers in, and gently pull that lid back, opening the vacuum bag compartment. According to the manual, simply pull that back, exposing the bag. To remove the bag, pull the cardboard plate on the top of the bag, out towards the no open face. Throw away your old bag, and take your new bag, fold down the paper sides of the bag, then slide the new bag into the track completely. Close your lid, and you are done.
While you have this compartment open, it's a good idea to check your filter that sits below the paper bag.
Part numbers
Paper Bag: SC-P11
Filter: SC-F2
I hope this helps you.
4helpful
Dirt canister lid is stuck on
push it back in till you hear it click.pres the button and hold and pull the dirt cup at the same time.please leave feedback
Top Dyson Vacuums Experts
AskDyson
AskDyson
Sean Wright
Sean Wright
xxxxxx xxx
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
