Question about Hotpoint First Edition FEW12 Front Load Washer
Washer is working but is fusing partway thru a washing cycle?, if i put another fuse in it workes for a good time then fuses? vtyman
  • vic_youle Jul 23, 2009
    thanks jim i,ll check that out,in the time frame from my question and your reply,i,ve had the m/c out of its confined space to have a look ,took top off checked for any obvious signs no luck? put a new fuse in, ran m/c working without fuseing, has done five loads without a problem? i must have disturbed something? if it goes again will look at the element?
    thanks again
    vtyman
I had similar problem due to heating element furring up and shorting against side! New element fitted by engineer now OK - It also uses much more electricity with this problem. The old element looked like it was bent so could more easily have shirted out!
Posted on Jul 23, 2009
Have a Whirlpool Cabrio washer WTW6400SW3 went thru wash wash cycle, then started to drain water to go into rinse cycle. Half way thru draining, was a loud electrical pop in control area of washer and...
sounds like a shorted machine due to water or moister? In most case you had a fuse blow on the machine somewhat like a thermal shut off fuse, most likely located in the panel. if this is the case u need to find out what shorted it, how water or moister got in? You can also look at the control curcuit board and look for burned seized transistors or areas indicating a burned out board.
Feb 11, 2015 | Whirlpool Washing Machines
Power went out while washer was in cycle.when power returned the washer wont come on.there is power in outlet but no power onon my washer
hello it's possible that the glass fuse may blown in the power supply inside the washer beware if you put another fuse in and it blows again the you have a dead short on the board someware also make sure you use the same rated fuse the value will be on the end of the fuse or on the fuse holder on the power board good luck
regards
shaun
Oct 08, 2010 | LG WM-2277HW Front Load Washer
WASHER QUIT WORKING BEFORE RINSE CYCLE AN WILL NOT WORK ON ANY OTHER CYCLES AND IT DOES HAVE POWER GOING TO IT
It doesn't work at all If your washer doesn't seem to work at all, check these: No power Lid switch No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped? Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse
Jan 03, 2010 | Washing Machines
I have a Bosch Exxcel 1400 S Express which blew
There is no internal fuse in the washer to replace.
If you have replaced the fuse, make sure that is is a good one.
If you are satisfied that you have power to the washer, then I'm afraid it sounds quite serious.
Trust this helps.
Dec 04, 2009 | Bosch Washing Machines
When washer starts to work in wash cycle it blows electrical fuses
1-fuse rated properly? 2-there is a capacitor next to the motor, get a new one. 3-With machine off turn cycle selector around 3x roughly then retry machine.
Mar 29, 2009 | Kenmore 24032\24036 Top Load Washer
Won't work
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Aug 16, 2008 | Maytag MAH2400A Front Load Washer
Washing machine fuse blows every couple of washes
the machine is pulling to much power.check to see if it is on a 15 or 20 amp outlet. you said you replaced the fuse. the amp size should be on it. if it is a 15 amp fuse,plug the machine into a 20 amp circuit and see if the fuse blows then. it shouldn't since it wasn't blowing everytime on the 15 amp circuit, but never put a 20 amp fuse in a 15 amp socket! the fuse can handle the load[ no pun intended], but the electrical wire would burn not blowing the fuse, thus causing a fire.
hope this helps.
wg
Feb 17, 2008 | Creda W100FW Front Load Washer
Indesit WG1235T O
I would say the doorlock switch is faulty
Oct 21, 2007 | AEG Lavamat 72640 Front Load Washer
Hotpoint First Edition FEW12 Front Load Washer Logo
64 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
