Question about HP Hewlett Packard LaserJet 1022 Printer
Printer spool service is not working - HP Hewlett Packard LaserJet 1022 Printer
  • Keith  Clark
    Keith Clark May 11, 2010
    Hi. Please specify. What model printer? Does the service start and then stop? Was it installed from the CD or from the web download? Thanks.
    Scholar:
  • 40 Answers
Hi , please specify more information rgarding the problem ...
the most common reason being installing the wrong printer drivers in your computer ..
reach me @ http://www.crossloop.com/ironcross
Posted on Jul 20, 2009
PRINT SPOLLER SERVICE NOT WORKING
If you are having issues with your system's print spooling services. You can try this steps:
Click here: PRINT SPOOLING
Hope this helps!
Good Luck!
Mar 14, 2011 | OKI B4200 Led Printer
Tip
How to clear printer not spooling error on windows xp system.
this error comes in many terms on the monitor screen as such
" printer spooling error"
" printer not spooling"
" printer spooling service"
if any of such message shows up on your monitor on windows xp operating system.
to make spooling work its necessary to make it work
this is the procedure .if you do this it will work properly. till it is not done it will just ignore printing
1)click the start in the left side of your computer screen
2)go to control panel
3)click performance and maintenance
4)click system
5)click data execution prevention
6)turn on DEP for essential windows program and services only.
7)click the spooling services a tick mark sign will appear beside that means it has enabled.
now your printer will work properly.
on Dec 02, 2009 | Office Equipment & Supplies
My printer doesn't work as it should be beacause i tried to print a page, i pressed ok but it didn't come out
Hi Bianca!
What you should do is to clear the print spooler - the printer queue. If you're using windows, right click on my computer and then press in "Manage", in the opened window go to "Services and Applications" and then "Services". go down the alphabetical list in the right window pane until you come to the service with the name "Print Spooler". Right-click this entry, then select "stop". This will stop the service that holds your print queues. Leave this window open, press on start and then type "spool" in the search bar (or in the "Run" command line if it's windows xp) and press enter. In the opened window, go to a folder named "PRINTERS", and Delete every file within this folder to empty the jammed print queue (pressing the "ctrl" and "a" keys will select all files and then you can just
hit "delete"). Close the explorer window now that we have emptied the cleared spool files, and return to your Services window. we must re-start the Print spool service, and do so by right-clicking the Print Spool entry and selecting "Start" from the list. Close the services window and try printing again. It should work now. Good luck!
Jan 10, 2011 | Lexmark Z617 InkJet Photo Printer
Scanner not working ... can't figure out why... need to scan my paycheck to deposit to bank but says scanner not connected (but it is) or not turned on (but it is) ... printer works fine, but scanner does...
You can try these steps:
1.Check if the firewall is blocking any printer services 2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode 3.Disable all the firewalls 4.Uninstall the printer driver and software 5.Delete any items under the ff keys: HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2 HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3 HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2 HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3 Optional*** 6.Delete any non default items under the ff keys: Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED HKLM\System\CurrentControlSet\Control\Print\Monitors HKLM\System\CurrentControlSet001\Control\Print\Monitors Default items are as follows: AppleTalk Printing Devices BJ Language Monitor Local Port PJL Language Monitor Standard TCP/IP Port USB Monitor Windows NT FAx Monitor ***** 7.Delete any items under the ff keys: HKLM\System\CurrentControlSet\Control\Print\Printers HKLM\System\CurrentControlSet001\Control\Print\Printers 8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista) Ensure there are no documents in queue. Disconnect printer’s USB cable. Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility. From the start search box type spool and press . The spool folder located at c:\windows\system32\spool opens. Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup. Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup. 9.Restart the computer. 10.Check th services status Start-Run- Type Services.msc and Click on Open You will see long list of services You need to make sure following 4 Services are set to Automatically start Remote Procedure Call RPC Remote Procedure Call RPC Locater LexBce Server Print Spooler 11.Reinstall the latest printer driver
have a great day. :)
Oct 01, 2009 | Dell Photo 964 All-In-One InkJet Printer
My printer is not printing everything else works, computer says that the printer is not connected.
hi there,
have a great day :)
Sep 30, 2009 | Dell 922 All-In-One InkJet Printer
Dell 942 all in one printet wont communicate to dell dimension pc
You've tried to uninstall and reinstall the printer driver of your printer. But still no luck. The printer still won't print. Or it would say printing but it won't finish printing.
Optional***
BJ Language Monitor
Local Port
USB Monitor
LexBce Server
Print Spooler
good luck. :)
Aug 30, 2009 | Dell 942 All-In-One InkJet Printer
My printer spool service is not running
just open task manager and click on new task
then type in spoolsv.exe
your spool service should start.
else open controlpanle and in administrative tasks open services.exe
then fron there right click on spoolsv.exe and start the service.
Jul 21, 2009 | HP Hewlett Packard LaserJet 1022 Printer
Help-what to do? can't print. hp laserjet 1300. i
unplug the printer from the computer.
go to start>>control panel>>administrative tools>>services
go down the list and, right click on the printer spool to stop the service.
reconnect the printer to the computer and restart the printer spool in the services panel.
if you still having problem,please restart the printer and stop/start the printer spool.
May 08, 2009 | HP DeskJet F380 All-In-One Printer
Print spool service is not Running
What makes you think the print spooler is not working? Is it because you get a message saying that it is not working or is it because you cannot print?
If you can stop and start the print spooler that would indicate to me that the spooler is running and you have a different problem. It is probably a corrupt print job, to fix this do the following.
1) stop the spooler
2) go to My computer
3) select the C drive
4) select the windows folder
5) select the system32 folder
6) select the spool folder
7) select the printers folder
8) delete everything in the printers folder
9) restart the spooler
Sep 30, 2008 | Computers & Internet
Spool locks
I had the same problem - to fix it, I disabled "Enable Bi-Directional Support" under the printer's properties (in windows, right click on the printer in "Printers and Faxes", go down to properties).
Worked like a charm.
Nov 08, 2005 | 3Com OfficeConnect Wireless...
HP Hewlett Packard LaserJet 1022 Printer Logo
56 people viewed this question
Seeker5211
Seeker5211
