Question about Whirlpool Dryers
My frontload whirlpool dryer panel lights up and lets me select a loan but after pushing hold to start it just keeps beeping, the door is shut and I tried unpluging and replugin and still the same ting, any ideas on what the problem may be??
  • ljs10 Jul 20, 2009
    I don't think the door switch is working, with the door open I pushed in the grey rubber button or boot what ever it is called and there is no click, don you think this might be the problem, is so I can't seem to locate the part # for this part and is it easy to install, or does a tech need to do it?? I have a Duet Whirlpool, I tried running the diagnostics and no code would display. Thanks for your help
  • 3,037 Answers
Yes, if the switch isn't clicking combined with the symptoms that you are experiencing, then the door switch sounds like the problem and needs to be replaced. It isn't hard to do so don't pay someone else to do it. You can order a new one from repairclinic.com and if replacing it doesn't work (I bet it will though), then you can return the part within 30 days. Just insert your machine's model number onto the website search bar to find the part that you need. Let me know how this turns out.
Benjamin
Posted on Jul 20, 2009
  • Whirlpool Master
  • 19,396 Answers
If it keeps beeping then there is a fault.
Try first unplugging the appliance for ten minutes, check the lint filter, and ensure that door lock switch is working.
If the problem comes back, if this is a Whirpool duet, then there is some diagnostic you can run.
To start diagnostic mode pick any selector button other than Pause/Cancel and do the following
Press and hold for three seconds.
release for three seconds.
press and hold for three seconds.
If you did it correctly all indicators will turn on at once, and you will get 88 on display. After a couple of seconds 88 will alternate with the fault code , below a list of fault codes:
If there is no fault code stored, then try restarting cycle and re doing diagnostics.
If still no codes , then parts must be tested, starting from thermal fuse, passing to thermostate to check continuity, then testing volts at the control board contacts. This must be done by a technician.
A good idea is also calling the service number listed on the owner manual, a phonne operator will guide step by step through the diagnostic procedure.
Regards.
  • Ginko
    Ginko Jul 20, 2009
    If the door switch is not clicking that can be the problem . the door switch can be tested reading continuity (checking ohms) with a multimeter. this is done with appliance power unplugged.
    If you want to order a replacement door lock, try entering model number on the page below:
    Partselect.
Dryer won't start
If you look closely, there are 3 separate pins that must latch. One is a simple push-button style which latches no problem.
The others are little prongs at the top and bottom of door. The bottom prong latches cleanly, but the top one will not latch because the door is a bit too flexible.
Close the door normally, then firmly press on the top edge of the door. You will hear the final latch grab, then you press and hold the start button. The dryer starts normally.
Oct 21, 2012 | Whirlpool GEW9250 Electric Dryer
Won't start, keeps beeping when i push start.
The door switch has gone bad. Replace door switch and you should be good to go.
May 16, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My whirlpool dryer just beeps when you try to start it. The panel is lit up the door is shut, push start and it just beeps...any idea what the problem is
To unlock the Control Locked feature:
Press and hold the End Of Cycle Signal button for 3 seconds to turn this feature off.
NOTE: When the dryer is running and Control Locked light is on, the dryer can be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
If holding doesn't unlock the feature, it is likely a faulty interface. I am having the same problem with my Whirlpool dryer and it is the interface, but it seems that a lot of people are able to correct the issue just by pressing the End of Cycle button for 3 minutes.
Here is a link to parts, numbers, and prices from Sears:
http://www.searspartsdirec t.com/partsdirect/getSubComp.pd?modelNumber=GGW9250PW1&productCategoryId=0151200&brandId=1198&modelName=RESIDENTIAL-DRYER&diagramPageId=00001&componentDescription=TOP%20AND%20CONSOLE%20PARTS&documentId=W0508037&blt=06
Jan 09, 2010 | Whirlpool GEW9250 Electric Dryer
I press the start button, but the dryer will not start.
ok open the dryer door look for a button inside where door shuts against hold that button down with other hand spin the dryer have some one push start button let it run for a sec then shut door and it should start
Dec 23, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool Duet GGW9200LL1 will not start
The electric flash does not sound cool, It sounds like you have a door switch problem. Check to see if the door switch button is in tact. If it is , you may have to go after the door switch itself. Try this, press more time, less time, more time, less time buttons in that order, the whole panel should light up, open the dryer door, you should hear 1 beep and OE displayed, If you have this the door switch is ok, Catriver
Jan 14, 2009 | Dryers
I have a whirlpool duet washer and dryer the dryer lights all come on but I get a beeping sound and dryer will not start
try to unplug the dryer for 5-10 minutes this should reset the board. if not take off the bottom panel and test the resistance of the thermistor ( the tech sheet is in the bottom there or up top)
Dec 09, 2008 | Whirlpool GEW9250 Electric Dryer
Start /stop problems
check to make sure you have the belt routed the right way around the idler pulley.
Nov 11, 2008 | Whirlpool LER4634J Electric Dryer
Replaced burned out dryer bulb on Whirlpool GEW9250PW and now drum light won't shut off even with door closed. Dryer will not work but all panel lights function normally - UNTIL you press start. Dryer...
Hello jmylymok,
Welcome to Fizya,
You said, you replaced burned out dryer bulb on Whirlpool GEW9250PW and now drum light won't shut off even with door closed. Dryer will not work but all panel lights function normally - UNTIL you press start. Dryer just beeps and doesn't work. When I tried the troubleshooting solutions, the error 6E comes up. What does this mean?
This sounds like the reason your bulb went out was more than just a bulb normally dying!
There is a short, or in that socked or the switch or it affected the the control panel too!!
This sounds like a hands on diagnoses job!
Let me know how it goes.
Huuum
Oct 08, 2008 | Dryers
Dryer just says beep beep beep everytime I push start
sounds like you may have a bad door switch(mach thinks door is open when it is not).open door and look on front panel that door pushes into.you should find a small button covered in a grey rubber boot.push on it and listen for a click,if u dont hear a click the switch is bad.if u do hear a click it could still be bad or you can have a open thermal fuse
Sep 29, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
96 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
