Question about Powerware 9120 UPS System
Battery test failed
I came into work this morning and I had blinking lights (battery) on my three of my powerware 9125 machines. When checking the machine with lansafe i found that the battery test had failed on all three of them. Normally I would hold down the mute button and it would reset but it isn't working this time. Any ideas?
Thank you in advance,
Byron Nelson
Byron.Nelson@prosodiecrm.com
  • 922 Answers
1. Replace the batteries because they NEED to be replaced. It is not wise to ignore alarms.
2. Remove the battery backups. Without good batteries they are useless so why waste your time silencing alarms. Just make sure that the computers are plugged into a surge-protected outlet and you save your work frequently when there is bad weather.
FYI: Retail UPS batteries are only good for 2-3 years and high-end commercial batteries are only good for 3-5 years.
I hope this helps.
Posted on Jul 20, 2009
I have a powerware 9120 (6kva) and about 1 week i replaced all 20 batteries after the UPS failed. but its displaying battery disconnected when i try to power it. i cant seem to figure the problem. i tried...
Did your UPS display "Battery disconnected" or did it display "Battery Failure"? If it was "Battery Failure", for some reason the Powerware 9120 will take almost 18 hours after plugging in to power after battery replacement to correct the Battery Failure indication. Charger has to charge up the batteries, followed by an automatic battery test by the UPS. If the indication was "Battery Disconnected", you will need to check the internal fuses to see if they are blown. If the UPS keeps blowing fuses, it will require a board repair.
Jun 12, 2011 | Powerware 9120 UPS System
MY UPS IS NOT GIVING SUFFICIENT BACKUP WHAT SHOULD I DO?
This appears to be an older model UPS, and it might be time to think about purchasing a new one, especially if this one has been through several outages/surges. Once a UPS like this is surged, the protection fuses can blow. In addition, if the battery has had a long lifetime it might be worn out.
Mar 16, 2011 | Powerware 9125 1250VA (051460085501) UPS...
I, Bypass battery and nomral mode are blinking UPS bypass unavailable. I need help please
Here is the link to all of the documentation:
http://powerquality.eaton.com/Products-services/legacy/9125-info.asp
You can also contact Eaton. Eaton bought Powerware 5-6 years ago.
Toll Free: 1 800 356 5737
E-mail (Hardware): SinglePhaseTS@eaton.com
Mar 01, 2011 | Powerware 9125 UPS System
UPS will not power up.
replace the battery of your UPS .
Dec 18, 2010 | Powerware 9125 UPS System
I am looking for schematics for a Powerware 9125 6000G.
This may not help, but it is the best I can find:
http://www.hmcdistributor.com/web/wp-content/uploads/2007/07/powerware-ups-9125-users-guide-5000-6000-va.pdf
Mar 11, 2010 | Computers & Internet
Battery Packs for Powerware 9355 UPS
The Batts can be charged externally, then refitted, usually I extend the DC cables so I can work with the batt outside the unit. This is ONLY to be done if you understand the risk and what may happen if you get it wrong.
Batts are always live and can cause fire/explosion/severe burns if shorted!
IF YOU ARE NOT SURE THEN GET SOME EXPERIENCED HELP!
OK so the UPS will not normally recognise a very low batt pack, that is the reason you can not start the test, this test will back of the rectifier so the batt pack takes the load for a short period.
If the batt pack is out of range then this will make the load go off, so the UPS is designed not to allow the test,unless the batt is at the right level.
If you can get the batt pack up close to normal then the unit will recharge it to full.,Wait until it is fully charged before testing.
If this is sucessful the cyle the batt a few times allowing it to reach around low batt warning before recharging. This will assist the batt in recovery. During this process if possible monitor with a test intrument(fluke 123 or 43B will do) the batt pack discharge curve , once the batt pack has dropped to its charge level from float, it should be a smooth decay.
depending on the state of the batts you may be ok, if there are weak ones in the string then you may have to replace all of them depending on the age of the batt pack.
MAKE SURE YOU ARE VERY CAREFUL WITH BATTERIES, THEY ARE VERY DANGEROUS, AND ALWAYS LIVE!
Check you manual for safety procedures, BEFORE working on Batteries.
hope this helps
thanks for using Fixya
Feb 03, 2010 | Powerware 9355 UPS System
The bypass mode indicator is blinking, what do I need to do?
my be its indicating that the bypass mode is not available because power input is not of range that the ups is designed to take, check the ratinng of ups and use amultimeter to check whether the input matches the input. also depending on the type of ups this could be a code for a fault. please avail the ups type.
Oct 13, 2009 | Powerware 9125 UPS System
When the machine is power on it show disconnect battery powerware 9120 2kva
There may be a broken batt lead or a failed cell or bloc inside.
try checking with software or
take out batts and test with meter.
if you dont understand how then get a tech to help. batts are dangerous.
Sep 13, 2009 | Powerware 9120 UPS System
Powerware 9125 power problems
Most modern ups units will not start at all without the batt, so disconnect the extra packs beg, borrow some new or old good batt blocs same spec as the original internal ones, as this is just a test any set of batts that is just ok will do.
fit them to the ups unit and see if it will start. if it will then you will need to replace all the batt blocs in the whole system.
If it does not start then the ups is faulty.
If you are not happy fitting /working with batteries then get a tech to do this work for you, batteries are very dangerous, they are always live and need to be handled with care at all times.
Hope this helps, thanks for asking FixYa
Jul 28, 2009 | Eaton Powerware® 9125 UPS System
Batery faillure
Advanced Battery Management Technology Prevents Premature Failure and Significantly Extends Battery Service Life
Batteries are the most critical component in the reliability of any UPS, but they face three fundamental challenges: All Batteries Need Charging
But extended charging significantly shortens battery life. Most batteries are charged with a trickle-charging process (a constant voltage feeding a low current to the battery). This method dries the electrolyte and corrodes the plates, reducing potential life by up to 50%.
Batteries Take Time To Recharge
Users can’t wait. During prolonged power outages, the UPS batteries will discharge and not recharge until the power returns. When there is a subsequent power failure before the batteries recharge, the computer will not have full backup time. Overly rapid charging can cause premature battery failure, so the trick is to charge at the fastest rate that is safe for the battery.
All Batteries Will Eventually Fail
The question isn’t “Will it happen?” but “When will it happen?” Because UPS batteries are valve-regulated, sealed lead acid, there has previously been no practical way to provide the user with any meaningful advance notice that batteries need to be replaced. In the past, the only way to know when the batteries were dead was when the power failed and took your computer down with it. Until now, typical UPS batteries have required replacement every two to three years.
Our exclusive ABM technology solves these UPS battery problems. It significantly increases the life of UPS batteries (see Figure 1), provides the fastest safe recharge time, and provides reliable advanced notice when the batteries need replacement. By extending battery life and virtually eliminating this major cause of surprise load crashes, we are able to offer the industry’s longest and most inclusive warranties on all products that incorporate ABM. No other manufacturer can make this statement.
ABM technology is available on Powerware 5115, 5125, 9120, 9125, 9140, 9155, 9170+, 9355, and BladeUPS UPSs.
Jul 02, 2009 | Powerware 9120 UPS System
Powerware 9120 UPS System Logo
795 people viewed this question
Top Powerware Computers & Internet Experts
Vassilis Chamaidis
Level 1 Expert
Jax Planet
Jax Planet
Are you a Powerware Computer and Internet Expert? Answer questions, earn points and help others
