Question about Western Digital My Book Essential 500GB External USB 2.0 - WDH1U5000N 500 GB Hard Drive
External hard drive problem NEED HELP
When i connect my external hard drive to the computer it says "new hardware is found, new hardware is installed and ready to use" but then when i click on the my computer the drive isn't there, nor is it found in computer management. but ironically, under device manager it is seen that a universal slot is occupied by the device. any idea how to fix this problem? ... i have the my book essential edition 500g external hard drive.. thanks hope to her from you..
  • Juan Carlos Cabrera
    Juan Carlos Cabrera May 11, 2010
    Hello, 1. Let's troubleshoot. Need some info first.
    You used some program that interact directly with the drive before this happen?
    Sure you have power connected? I know this is obvious, but need to know.
    How is the sound of the drive? Put the device on your ear when powering up. Suppose to spin up and hear some data access from the heads. If there repeated movements, like trying to gather data, is not a good sign.
    Problem Solver:
  • 7 Answers
Is this a new external with no data on it? If it is, it may need to be formatted.Go to disk management to see if the drive is there. It may need to be initialize first before you can formatted.If it has not been initialized, a message will pop up for you to initialized it. Once it is done, formatted--This should be done only if don't have any data on it.
Good luck
Posted on Jul 23, 2009
External hard drive not accessible
A Hitachi USB external hard drive is a device that acts as portable, removable storage for your personal computer. If you need additional space to house files on your computer but don't want to go to the trouble of installing an internal drive inside the case, a USB external hard drive is your best option. These drives are "plug and play" devices, which means that very little can actually go wrong. If you're having problems, fixing them shouldn't take more than a minute or two.
Check your connections. A USB cable needs to be connecting your Hitachi external hard drive to your computer. Your external hard drive's power cable also needs to be plugged into a functional wall outlet, surge protector, extension cord or power strip. Make sure your Hitachi USB external hard drive is turned to "On." An "On/Off" button is present on the front of the unit. If the indicator light around said button is not illuminated, the drive is "Off" and your computer won't be able to recognize it. Press it to turn it on and then try to access your drive again. Format your hard drive. If your Hitachi USB external hard drive doesn't currently have a file system on it, you won't be able to use it to store data. Open up the "Computer" icon in the "Start" menu. Right-click on your USB external hard drive's icon and click "Format." Click "Start." This will install a file system on your Hitachi USB external hard drive. After this process is finished, you will now be able to use your drive. Restart your computer. Certain models of computers (especially older models) won't recognize new hardware unless your computer boots with the hardware already connected. Leave your USB drive plugged in and restart your computer. Once you do this, your Hitachi USB external hard drive should appear as normal in the "Computer" folder with all of your other drives. Hope this helps.
Jan 08, 2013 | Hitachi Travelstar 7K60 (DK23FA60) Hard...
How do I disconnect (uninstall) a WD External Hard Drive from my computer? I am using a WD 3200AAK WD External Hard Drive and want to install a 1 TB WD External Hard Drive. I would like to use the old one...
External hard drives don't need any program installed on your computer to run. Your operating system Windows, Linux should handle it as soon as you plug the usb in your computer. The programs included in your WD external hard drive are tools to backup your data.
If you try to hook up your hard drive to a Windows prior to XP, maybe your computer will not handle it.
It is always safer to safely remove your drive using the green arrow icon in the lower right corner of your screen. This way, the drive is shut down properly and you minimize chances of fails when you plug it again on another computer.
Hope this helps!
Feb 08, 2011 | Western Digital My Book Essential Edition...
When I connect my seagate expansion external hard disk 500gb having p/n:9sf2a2-500 in windows xp(sp2) system, found new hardware wizard pops up and when I click next it says Cannot install this hardware....
either an issue with the hard disk, or with your system. Make sure the hard disk has power on it and if you can, it would help to test it on another computer to confirm if it works. If you have ruled out the possibility that it is the hard disk, next is review if the hard disk has system requirements you need to meet. If the requirements are met by your XP SP2 machine, you may try updating the computer's system software/chipset drivers and a BIOS update may also be necessary.
Aug 29, 2010 | Computers & Internet
Dear ... I have recently purchased Seagate's Freeagent External Hard Drive (500 GB Capacity). It was working all right for about 10 Days, but now I face a peculiar Problem. This drive does not show in the...
Plug it back in and try this. Right click my computer and click "Manage"
When the window opens select "Disc Management". In the bottom of the screen you will see all the Disk drives installed on you computer. Right click on your drive and select "Properties". When the window open click the "Tools" tab and finally Run the Error Checking Tool. It will scan and fix any issues with the disk. Cheers :)
Jun 27, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Need Manual or Instructions for Seagate Portable Hard Drive
Your External Drive should be plug and play enable since it is a USB Drive.
Connect the appropriate cables to the External Drive and from the External Drive to the Computer while the computer is fully booted.
The driver for the Drive is loaded else you will be promted that the system have found a new device, if that is the case, put the CD-ROM that came drive and follow the instruction to complete the driver installation.
Open my computer icon on your desktop and you see the external drive.
Feb 01, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
When hardrive connected it says found new hardware
You need to format the external drive. Format the drive as primary drive ans in FAT32.
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that its Healthy.
Oct 02, 2009 | Acer Computers & Internet
Install disk
Just connect the Hard drive to your system using the usb cable that comes along with it, it will automatically install the drive and your system will prompt you that a new hardware has been found and installed. You can then start to use after installation.
Sep 25, 2009 | Maxtor OneTouch 4 500GB External USB 2.0...
My Western Digital Elements external hard drive is no longer recognised by either of my computers. When I attach it to computer it says it has found new hardware and installs it and when I look in device...
Check the Disk Manager to see if the disk has a valid partition and is recognized as being formatted. Start -> right-click My Computer -> Manage -> select Disk Management.
If not, then your MBR could be corrupted.
This troubleshooting external hard disk article should help you further.
Jules
Apr 21, 2009 | Western Digital 500GB ELEMENTS 500 GB USB...
External hard drive not recognized
You need to first narrow down the problem to either your PC or the external hard drive. Do you have access to any other PCs you could try connecting your hard drive to? (think friends, family, public PCs, etc)
If the hard drive works on other PCs, we know it isn't a problem with the hard drive.
If it turns out that the hard drive is fine and the PC is the problem, I would suggest going in to Device Manager and uninstalling everything USB related. Once you have done this, either reboot your PC or right-click inside device manager and "scan for new hardware". All of your USB related devices should reload their drivers automatically. You may want to try this both with and without the usb drive connected.
Another tip would be to try various USB ports.
Mar 19, 2009 | Western Digital 500GB My Book World...
None of my external hard drives or flash drives recognized by Vista
Ok Go into your hardware device manager and uninstall your Universal Serial Bus Controllers and if there is mass storage device also uninstall it. Click on action -> scan for hardware changes, then it should automatically install the drivers back now it should detect.
May 03, 2008 | Maxtor Hard Drive
Western Digital My Book Essential 500GB External USB 2.0 - WDH1U5000N 500 GB Hard Drive Logo
406 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
