Question about Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV
Surround sound trying to set up my tv with a poineer surround sound system ned to know where to connect the tv to the reciever
    Problem Solver:
  • 19 Answers
Electroguy is correct. Plug the L and R audio outs into the L and R audio inputs on your receiver. Then make sure that the internal settings on the TV are set to 'Surround Sound.'
Michael Lazar
Posted on Oct 11, 2008
  • 231 Answers
To connect audio from tv to receiver.Use the monitor out(audio) from tv to receiver .The tv will only put out left/right audio .Also when using the audio out from Sony tv sometimes you cannot use both the internal speakers from tv and audio out from tv to receiver at the same time..Make sure audio is set up on TV menu for audio out..
Posted on Dec 01, 2007
How do I get my Panasonic sa-pt670 to play all the speaker. watching tv and with ps3
Does you Tv set have optical out? If so might I suggest running HDMI into your television set from the PS3, then run an optical audio line out from the tv into the optical line in on your HTIB
Feb 24, 2010 | Panasonic Home Theater System System
You can set up your tv in this way. Hook up your dvd player directly to your tv and then hook up your surround sound reciever from the audio out jacks from the back of your tv. This should allow you to use either your tv volume or the surround sound feature. Hope this helps
Oct 21, 2009 | Samsung HT-Q40 System
All you need to do is follow the following directions on your TV and you will be on your way listening to your great Philips TV on your great Sony Surround Sound. You do not need to buy any other cords or anything else. Its just a setting on your TV that needs to be adjusted.
By the way, I have a Sony Home Thearte System DAV-HDX275 and I've had it for almost 8 months and its sounds good with my TV and Movies. The speakers are very cheap and it doesn't give you the sound you expect. So I came accross some Boston Accustics CR65's that are not sold anymore but they did run around $700 a peice. I am upgrading the Reciever very soon to a better qualtiy Reciever. This Surround Sound System is great for a starter Surround Sound System.
  1. Press MENU on the remote control and select TV settings >
  2. Press up or down to highlight a sound setting and press right to select the setting.
  3. Press up or down to adjust the setting, and press OK to confirm the change.
  4. Press Menu to exit.
You want to pick Incredible Surround, but if that does not work try them all. The Incredible Surround should do the trick because that switches it from the TV Speakers to the Surround Sound.
Thank you for using Fix Ya!
Don't forget to rate the overall satisfaction of this solution.
Have a Great One!
Mar 13, 2009 | Philips 42PFL3603D/27 42 in. LCD TV
LG DvD Reciever (LH-T550) issue (Xbox 360/ TV sound)
I dont know about a universal remote my friend but a remote is defo needed to ajust and alter sound settings , I have the same system and it can not be done with the reciever alone. The AUX button on the remote has to be activated to get sound thru LG speakers providing your game console is connected to your TV, then a set of audio cables from your TV via the (OUT) ports (this is a must) back into you LG reciever. Goodluck
Feb 18, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Hookup my surround sound
for verizon cable box to system
Dec 18, 2008 | Onkyo TX-SR803 Receiver
Connecting surround sound system
get a reciever and then get componet cables then hook it all up through the hdmi cables
Jan 22, 2008 | Sylvania 6727DF TV
Tv sound & surround sound
Go to Settings/SoundSettings/AudioOutputSettings/AudioInputConnector or DigitalOut depending on type of input you are using for surround.
Jan 02, 2008 | Sony Playstation 3 (PS3) Console
Connecting up
Easy set up, Hook up all the components to the back of the TV normally and then use a stereo cable from the tv to your reciever.
Usually on the tv it says audio out or variable audio out, this will go straight to your reciever on one input allowing all devices on your tv to be hooked through your reciever on one cable and the sound will come from the tv and reciever at the same time or you can turn the audio off on the tv., you can also hook up any optical audio outs from your devices to your reciever as well. This will allow for surround sound to your reciever.
Dec 21, 2007 | Televison & Video
Connect PS3 for playing/viewing blue-ray thru surround sound
Connect the PS3 to your TV with the hdmi cable and to the surround sound system with a digital optical cable, then set your PS3 to output sound through the optical port (through the sound options menu) and you're good to go!
Oct 27, 2007 | Sony DAV-HDX500 System
Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV Logo
166 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
