Question about Dell Latitude D600 Notebook
UN MOUNTABLE BOOT VOLUME ERROR - BLUE SCREEN
WHEN I TURN ON MY DELL DV051 DESKTOP AND THE WINDOWS XS SCREEN COMES ON IT THEN POPS UP A BLUE SCREEN THAT READS UNMOUNTABLE BOOT VOLUME WHAT DOES THIS MEAN. HOW CAN I CORRECT IT? You need your Windows XP cd for this fix.
I TRIED SEVERAL TIMES TO Boot from the Windows XP CD (THAT CAME WITH THE DESKTOP) BUT WHEN THE CD OPEN IT DOES NOT GIVE ME AN OPTION TO FIRST PRESS R IT START TO RUN AND IT SEEMS IT IS INSTALLING SOMETHING SO I CANNOT TRY TO REPAIR AND FOLLOW ANY OF THE OTHER STEPS.
  • christell002 Jul 20, 2009
    It does not give me the option to repair or install system. It starts to run and you can see system install something or the only other option is press F6 to add mass storage device. My problem is with the Windows XP disk from Dell - the system boot up with it but then does not give me the option to select anything i.e. R for repair........ My hard disk does have code 7 error that means corrupt date by fixable...... and that is why the system will not boot up.
    Problem Solver:
  • 10 Answers
Place a Windows XP disk in to a drive and just after pressing power button keep pressing F10 or F12 to get to the boot menu then choose cd/dvd drive and follow procedures from the screen to repair or install system. ANother way is by pressing F1 or F2 or Del just after pressing power button to get to BIOS the go to Boot options and set firs cd/dvd drive then press F10 and enter.
Posted on Jul 20, 2009
UN MOUNTABLE BOOT VOLUME ERROR - BLUE SCREEN on a dell latitude D505 laptop
try to boot to safe mode using F8 key on boot and then recover system or reinstall OS
Nov 13, 2012 | Dell Latitude D505 Notebook
Dell dv051
On a desktop you can actually buy a usb 2.0 pci card that goes inside the computer in one of the pci slots. 2.0 is the way to go because otherwise you'll be getting a message about how your device can run faster if it was plugged into a usb 2.0 port.
Mar 23, 2012 | Computers & Internet
Blue screen on dell 3100 mountable boot volume
Blue screen is very common error, it mostly occurs due to corrupt registry files, you need to re register you windows. You can also use RegInOut- a utility software to fix windows errors.
Oct 29, 2011 | Dell Dimension 3100 PC Desktop
Loading PBR for descriptor 2... MODEL DELL DV051
That is the boot loader message to boot to the NTFS Primary boot partition (Primary Boot Record for Descriptor 1 is the Utility partition)
Normally, this message flashes and the system boots, since it is not there is a failure in the boot process.
#1 run diags on the Hard Drive (CTRL+ALT+D at boot) and see if it passes
If it does
#2 Boot to you XP CD, press R for recovery console, and run the COMMAND CHKDSK /R see if the system will boot
If no go, go back to recovery console, try the command BOOTCFG /Rebuild then see if the system will boot
If That fails, try reinstalling Windows
If Diags Fail or all the above fail, replace the hard drive
Jun 24, 2010 | Dell Computers & Internet
Unmountable boot volume + how to fix. Have reboot CD's Errors messages 0x000000ED, 0x8137DE8, 0xC0000006, 0x00000000, 0x00000000 can't get past this screen. keep circling around F8 and the Dell start-up...
Turn off your pc and take the side panel off and remove the cmos battery leave for three minutes
and then replace this will reconfigure your
motherboard and hopefully solve your problem.
Feb 15, 2010 | Dell Dimension 2400 PC Desktop
I get a blue screen error message ''c000021a unknown hard error'' after running CHKDSK as a result of receiving an initial blue screen error message ''The Type of file system is NTFS. The volume is...
Hi, Boot into Safe Mode by pressing F8 at bootup and choose
'Safe mode with command prompt'
At the command prompt type
C:\Windows\system32\restore\rstrui.exe
Hopefully System Restore will open so choose a Restore Point a few days ago.
Please rate my response!! Thanks, SF
Jan 28, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
My computer keep on re-booting
So many computer face this blue screen fetal errors on windows.
This error comes usually when there is problem in software or driver compatibility issue with hardware or operating system.
Also this error comes when there is bed indexing unit in hard drive.
You can solve this errors with following 2 methods.
(1)When you power up the computer press F8 key then enter in safe mode.
Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error.
(2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk.
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set frist boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"
Then type "y"
Then it fix error on hard drive.
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windwos " then it repairs old windows then it loads again old windows.
Thanks for using FixYa.
Jan 06, 2010 | Personal COMPUTER - LENOVO THINKCENTRE A61...
Computer will not boot up
need to reinstall windows it is corrupted
Mar 27, 2009 | Dell Dimension 2400 PC Desktop
HOW CAN I FIX MY COMPUTER? ITS READING UNMOUNTABLE BOOT VOLUME?
Boot from the Windows XP CD and at the first prompt, press "r" for repair. Press 1 when asked to choose windows installation and then enter the admnistrator password. If you don;t have one, just press "enter" and it should show you "c:\windows>"
At this prompt, type the following
chkdsk /r
THis should take quite sometime but will fix the problem at the end. when you get the c:\windows prompt again, type the word "exit" and your system will reboot and load windows XP normally
Mar 07, 2009 | Dell Latitude D600 Notebook
Computer won't boot into windows
The event of you inserting a DVD is unlikely to have anything to do with this problem. Probably just a coincidence that it happened after you did so. Hard drives die eventually and more frequently so in laptops.  I'm afraid you will have to bite the bullet and replace the hard drive.
Dec 11, 2008 | Dell Inspiron 300M Notebook
Dell Latitude D600 Notebook Logo
1,016 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
