Question about Maytag Neptune MAH5500B Front Load Washer
My Maytag Washer stopped in mid cycle. I tried starting a new cycle but all the machine does is what I believe is a very slow rotation and I don't believe the clock advances. I think the clock, which must control all functions, is burned out.
    Scholar:
  • 84 Answers
Your internal Unbalance switch might be bad. It should be located under your top panel. Try taking the front panel off and then the 2 srews that hold the top panel and you should be able to lift it up carefully and the internal unbalance switch should be right there. Theres also a Tub displacement switch right underneath the tub..you should see it right there after you take the front panel off. Its located right undernieth the cement wieght. Check out these two switches. Hopefully that helps.
Posted on Jul 26, 2009
Washer stops mid cycle showing (nf) what do I do?
Posted on Jul 25, 2009
Eratic, sometimes door lock doesnt activate, when it does wahser starts but stop mid cycle and wont continue. Replaced door switch and pump
Repair needed on Maytag Neptune washer - Home Improvement ...
www.dslreports.com > ... > Home Improvement
DSLReports
Aug 5, 2007 - 19 posts - ‎8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
Maytag Washer Troubleshooting - YouTube
Dec 02, 2015 | Maytag Washing Machines
Clothes Washer stopped running. I have a Maytag PAV2300AWW clothes washer that was mistaken ran with a full load on the small load setting and stopped working mid cycle. Any help with the cause and
first check the house breaker and make sure you still have power. If it does then I would unplug the machine and lean it back against the wall to look at the motor wiring harness underneath to see if it came loose or is wet.
Mar 31, 2012 | Maytag PAV2300 Top Load Washer
My machine stopped mid cycle and displays the letters dc, flashing. What is happening? thank you
I believe The dc code is due to an "unbalanced" load situation. Is this happening when it tries to spin? I know some washers have switches that sense this. Is this in the wash or spin cycle?
Sep 12, 2011 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune. 10 years old.Slow drum rotation
The problem may be with the bearing of the washing machine is spoiled due to leak please try to change two inner bearing along with the washer it will work for another ten years
Dec 24, 2009 | Washing Machines
Maytag Atlantis stopped mid cycle
Bad/worn/broken lid switch look at the back of the lid there is a little lid cam there that hits a switch,if this switch isn't engaging it will do just what you are describing.use a small screw driver to push the button in and see if it starts.
Sep 03, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washer stalls mid-cycle and keeps running but doesn't progress
check to see if the water is warm if not the heater has gone or the thermistor is faulty
if warm i can be a dead spot on the timer where the contacts are worn if so needs new timer
Jul 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
Stops mid-cycle, does not drain, displays nd error code?
Hello.
That code is telling you that the unit is draining to slow. After 15 minutes it is not below the low water level and will not spin out. The best repair for this is to replaced the pump on your unit.
Jul 15, 2009 | Maytag Neptune MAH9700 Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
461 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
