Question about Sony KP-51HW40 51" Rear Projection Television
Tv will not stay on.
Tv shuts its self off after a short time. Red light flashes 5 times. Is this easy to fix?
  • 39 Answers
Re: Tv will not stay on.
This problem is related to ABL control .
Trace ABL signal from Pin no 11 of flyback transformer.Mostlikely value for the resistor in abl line has gone high.First case reduse the G2 voltage and see if the unit works for long.
Second case its sure that its ABL problem.
Posted on Dec 14, 2007
0 characters
3 Points
I have a sony rear projection TV model number kfws60s1 that will not turn on I press the on button and green light will flash 5 times then goes red again please help shed light into the problem pleaz
Understanding Sony Television Blinking Codes ' Techlore
Now the red light blinks 5 time while watching it. Is there any way of ..... 2006 that willnot power on and the green LED is blinking 6 times. We had a service ...
Sony KDF E55A20 - 5 Flashing Read Lights - TV Forums
Mar 17, 2012 - 14 posts - ‎4 authors
We have had a Sony KDF E55A20 since January 2006 and it has been trouble free. ...The TV will switch on fine green power lights. Then after about 20 ... If I turn off and turn on the power light will flash red 5 times. Leave it off ...
Sony TV - How to troubleshoot a red or blinking light ...
? 3:36
Apr 6, 2012 - Uploaded by SonyListens
Sony TV - How to troubleshoot a red or blinking light ... and power lights, these easy steps will help you determine what the... 5:17. Easiest TV repair - How to Fix Power [TV turns off, freezes, ... Get video URL at current time.
Dec 02, 2015 | Sony Projection Televisions
TV shuts itself light blinks 7 times.
the only way is by bringing to a tech.i think there is no need fro self-fixing with problems like this.try tapping the tv several times then turn it on.
May 28, 2009 | Projection Televisions
TV won't turn on. Red power button flashes then shuts off.
Did the TV work but with a convergence eproblem before you changed the STK's.? If so it is very likely you have misplaced one of the several leads when reassembling the set. It is ususally a perfect cure. Power light flashing 4 times indicates this type of problem.
Feb 21, 2009 | Hitachi 43UWX10B 43" Rear Projection...
I have a Mitsubishi WD-62525. This morning my TV would not turn on so I pressed the rest button. After the Timer light stopped blinking I pressed power. I could hear the fans start than a somewhat loud...
the status light blinking red means a fan (the unit hs 4 of them) has failed. you need to determine which one. use the self diagnostic function:
Error Code Operational Check
The TV must be in “Shut Down” and not manually switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to “12” No Error.
Press the front panel “DEVICE” and “MENU” buttons at the same time, and hold for 5 seconds to
activate the Error Code Operational Check. The LED will then flash denoting a two digit Code.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
Example: If the Error Code is “32”, the LED will flash three times, pause, and then flash two times.
• The Error Code is repeated a total of 5 times.
and read the code.
35= Chassis Fan failure
36 =Exhaust (Back Cover) or Lamp Ballast Fan failure
37= Engine (DMD or Lamp) Fan failure
Nov 15, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Turns red then shuts off
the red CRT is shorted . You should be able to get a replacement CRT at the following link.
Sep 27, 2008 | Sony KP-51HW40 51" Rear Projection...
Red fade, red flashes screen turns off followed by tv turning off.
Replace HV block when self-diagnostic LED blinks 8 times =
Sony part # 8-598-955-32....if that doesn't cure it, the red CRT
would be next..................T.
Dec 21, 2007 | Sony KP-51WS500 51" Rear Projection...
TP50G60 bad scrambled picture - shuts off after 1 minute
This does not sound to me like a convergence roblem. It could be a shorted picture tube. That would put the set in a shutdown condition. Normally in Toshibas , the picture remains on with a convergence problem. Here is something you can try, but you must be very careful. Remove one crt board at a time from all three tubes. if the set stays on after one of the crt board are removed , then that is the shorted picture tube.I cannot caution you on how care full you have to be trying this procedure. Scrivitron
Jun 29, 2007 | Toshiba TP50G60 50" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
51 people viewed this question
Top Sony Projection Televisions Experts
Steve Sweetleaf
Steve Sweetleaf
Jason Harris
Jason Harris
Are you a Sony Projection Television Expert? Answer questions, earn points and help others
