Question about Dymo LetraTAG Thermal Label Printer
Labels coming out blank
Recently, the print on the labels has been a little bit blotchy; the letters are faded in places. Now there is nothing showing up on the labels at all once they're printed. I type a word and it shows up on the screen, but when I print it, it comes out blank.
    President:
  • 566 Answers
1. Replace the batteries (use only alcalines)
2. See if the tape is correctly inserted.
3. Clean the printer head
4. Replace the tape with a new one.
5. Check the contrast settings
Posted on Jul 20, 2009
My zebra 105Se keeps printing blank labels.
Do the labels come out right when you print locally? That is the first thing to see. Serial devices over a network are tricky. Baud rate and what to do with CR LF, stop bits, parity etc. need to be right.
Jun 04, 2014 | Zebra 105Se Thermal Printer
Own three CP3525dn's (purchased new). Two have recently begun jamming [fuser wrap] when printing labels. If it doesn't jam then the paper usually "dog ears" coming out. New fuser did not...
Over time, printing labels builds up a light residue of the adhesive (due to heat pressing) used on the labels in the paper path. A thorough cleaning of all paper path parts with alcohol prep pads, or Glass Plus and quality paper towels, will reduce this gum build up.
You should regularly print standard paper jobs on a laser printer that will be printing labels. Rule of thumb is 4:1 - four sheets of regular paper print for each sheet of labels printed. This helps keep the adhesive cleaned out of the paper path.
Patience and a lot of scrubbing should do the trick, though you may have to install a printer maintenance kit early given the issues noted. Printing labels cuts maintenance kit duration in half, at a minimum.
Jul 06, 2011 | HP CP3525DN Color LaserJet Printer
We have recently printed and applied hundreds of asset sticker labels on our Dymo LabelWriter 450 and they have all faded! Is there a solution to this? or is the Dymo LabelWriter only useful for temporary...
LabelWriter labels are sensitive to sunlight. The coating is what allows to burn text onto them because LabelWriters do not use ink.
They are not supposed to fade easily so it may have been an old roll. Please contact our help desk for a resolution (see dymo.com for contacts).
^CM
Feb 10, 2011 | Dymo ® LabelWriter® 450 Series PC...
Dymo prints blotchy labels and feeds out many labels after print
Sounds like you have a couple of issues going on...your labels are incompatible or you have an incorrect template selected in the Dymo Software.
Check that the label model matches the template and you are using quality Dymo Labels. Such as the Dymo name brand or the LabelValue brand Dymo labels.
Apr 30, 2010 | Dymo LabelWriter 400 Turbo Thermal Printer
Zebra S600 printer
  1. Try just storing your labels in a cool dry place before using them. Peeling labels are usually a sign the glue is poor or weak.
  2. When tearing you labels off, feed them out before tearing them off, then hit the auto-align. See if that helps it.
  3. Try pushing a normal playing card under the metal cutter that tears the labels and pull it up and through the front to bend the blade slightly outward. This will hopefully allow the labels to pass underneath.
Jul 30, 2008 | Zebra Stripe S600 Thermal Label Printer
Printing blank labels
I am having the same problem! Printing blank labels. Don't know what's wrong now. It was working fine yesterday.
Jul 22, 2008 | Dymo LabelWriter 400 Thermal Printer
Bad driver?
courput print drivers or not the exact drivers.
Jan 15, 2008 | Zebra 105SL Thermal Label Printer
Labels Print Once Then Fail (3.5 X 1)
"The printer will print one label then either push out a half a blank label or several blank labels. At that point the labewriter thinks it's out of paper. I also noticed that the labels tend to slide toward the middle while exiting. After each print I have to pull the labels back in and realign them. Then the process repeats."
This is because you haven't squeezed both sides of the spool to the edges of the label. Without the sides to hold the label in place it is free to slide about on the spool and therefore slides about where the print head and label sensor are. The sensor is on the left, so if it slides towards the middle the sensor can't see the label and reports "out of labels".
See the diagram here for a clear picture of how to correctly load the labels to avoid this problem:
How to load Dymo LabelWriter Labels
Nov 06, 2007 | Dymo LabelWriter 400 Thermal Printer
Dymo LetraTAG Thermal Label Printer Logo
568 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Ed Mac
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
