Question about Canon imageRUNNER 3570 Copier
How to make a booklet?
How to make a booklet - I have A4 paper which is printed on the left hand side of each sheet - how do I make that into a booklet using A4 paper?
Ir 3300 Eooo247-0001
Posted on Jul 21, 2009
HP P2015dn when printing booklet, double side print, the print on the back of all pages are upside down. How do I fix it
Many duplex printers have an automatic setting for booklet print. If not, you have an option in the printer settings for long side or short side flip. If you are printing an A5 booklet (ie A4 folded) the setting should be landscape, two pages per sheet, flipped short side.
Nov 04, 2017 | HP Office Equipment & Supplies
My canon pixma 6150 does print on both sides of paper but the second/back side is upside down so I cannot make booklet
select long side flip rather than short side flip for an A4 booklet. An A5 booklet should be set for short side flip.
Feb 03, 2017 | Canon PIXMA Office Equipment & Supplies
How do I clean toner from machine?
Probably it's the jammed paper that might caused the error. I suggest have it serviced by the technician. Be aware of the paper handling capacity of your machine to minimize jamming:
3300MFPV_X
Phaser 3300MFPV/X, Copy/Print/Colour Scan/Fax, B&W, 28 ppm, A4, 1200 dpi, 50-sheet ADF, 250-sheet Paper Tray, 50-sheet Multipurpose tray, 150-sheet Output Tray, 96 MB, Automatic 2-sided printing, USB/Ethernet, PCL/PS3, Scanning software, 220 V
Apr 28, 2014 | Xerox Phaser 3300mfpv/x Print Copy Scan...
Oki - how to print booklet?
The paper you have inserted into the printer, and your page size settings have to match. You can't load A4 paper and tell it to print A5 size. This is why it is printing so small on the A4 paper. It assumes you need to trim it down to A5 size after printing.
Jul 15, 2012 | Office Equipment & Supplies
Can Lexmark x2470 scan and print a double sided document?
after reading the manual, http://www.lexmark.com/publications/pdfs/2007/2400/ug_en.pdf, yes it is possible - not that it tells you how to do it though so read on.
Until you become familiar with the process just use one sheet of paper at a time in the printer.
As you know, in the scanner the top right of your document goes to the right hand front corner of the scan bed (the clear window), place the page on the scanner and scan.
Pick up the printed sheet of paper and flip it so the left hand side edge is now in your right hand and the right hand edge is now in your left hand and you are now looking at the blank side of the paper.
Insert the page back into the sheetfeeder.
Flip the page to copy in the scanner so the rearmost edge of the paper is now to the front of the scan bed and the front edge of the paper is now towards the rear (you should now be looking at the page you scanned previously).
Scan the page.
you should have now scanned both sides of one sheet of paper to another sheet of paper.
as your printer does not have a sheet feeder for the scanner you have to do the process manually. hope this helps.
Apr 20, 2011 | Lexmark X2470 All-In-One InkJet Printer
Is it canon laser LBP 3300 printer take Legal Size printing ?
Here are "little" specification:
Body installation method desktop page printer
Photosensitive medium OPC drum
Exposure method semiconductor laser
Development method Toner projection development
Transfer method by roller
Separation method by curvature
Cassette pickup method by pad
Multifeeder pickup method by pad
Drum cleaning method by blade
Fixing method on-demand
Delivery method face-down/face-up
Toner supply type by toner cartridge
about 6000 prints (A4, single-sided; at 5% image ratio)
Warm-up time in standby: 0 sec (at power-on: 10 sec or less)
Print area top: 5 mm; bottom: 5 mm; left/right: 5 mm (if envelope, top, bottom, left,
right: 10 mm)
Printing resolution 600dpi
First print time 9 sec or less (approx.; A4)
Print speed (A4) 21 pages/min (approx.)
Cassette paper size A4, B5, A5, Legal, Letter, Executive
Multi-purpose paper size A4, B5, A5, Legal, Letter, Executive, Envelope DL, Envelope COM10,
Envelope C5, Envelope Monarch, Index Card, Custom Paper Size (width
76.2 to 215.9 mm, length 127.0 to 355.6 mm)
Cassette paper type plain paper (64 to 90 g/m2), heavy paper (91 to 120 g/m2), recycled
Multi-purpose paper type plain paper (64 to 90 g/m2), heavy paper (91 to 163 g/m2), recycled
paper, transparency, label paper, envelop (DL, COM10, C5, Monarch,
B5)
Cassette capacity 250 sheets (approx.; plain paper, 64 g/m2)
Multi-purpose capacity 1 sheet
Delivery tray stack 65sheets (Face-down) /1sheet(Face-up Output Slot)
Memory 8 MB (internal; no optional memory available)
Operating environment
(Temperature range) 10 to 32.5 deg C
(Humidity range) 20% to 80% RH
Noise 52.8 dB or less (during printing; based on ISO9296; announced noise
emission)
Power supply rating AC100V±10% (50/60Hz ±2Hz)
Power consumption (Maximum) 790W or less (approx.; 20 deg C; for input of rated power supply;
including peak value lasting 1 sec or more)
Dimensions 370 (W) x 375 (D) x 258 (H)mm
Weight printer: Approx;11kg; toner cartridge: Approx,0.8kg(2.5K)
Option paper feeder
Jul 06, 2010 | Canon LASER SHOT LBP 3300 Printer
Sheet feeder wheel marks on both sides of A4 photo prints
Open the kodak all in one home center on your desktop and click on [?] on top most right hand side. choose maintenance under general links and choose printhead cleaning. if this does not solve the issue, call kodak @ 1800 421 6699 and they will replace the printhead for you free of cost. no need to switch over to any other brand.trust me Kodak is really good.
Jun 22, 2009 | Kodak ESP 5 Printer
How to photocopy double sided A4 sheets?
you copy first side normaly. then on left side open bypass deck.Put the paper, so that the side on wich you want to print is down. Automatically when you put paper in bypass, the machine ask you wich format is it ( eg. A4 ), confirm with OK, then you need to tell machine wich type of paper ( eg. plain paper ) and OK. then green copy key.
May 02, 2009 | Canon iR 1600 Laser Photo Printer
I need to make a booklet. so when i print the document it be read like in abook
Hi, I dont actually use PageMaker, so you might need to check your help file for more info.
Basically you need to look for an option that lets you 'impose' your document (there may be a tool box or print option for imposition).
If you cant find it just do the imposition yourself.
For a simple 8 page A5 booklet you would want two A5 pages side-by-side on an A4 sheet of paper.
Back cover would be on the left (pg8) - Front on the right (pg1).
Inside front cover on the left (pg2) - inside back on the right (pg7).
Then the centre pages - right (pg3) - left (pg6)
Inner double pages - left (pg4) - right (pg5)
Hope that helps!
arceye10
Dec 20, 2008 | Adobe PageMaker Plus 6.5 for PC
Printing a booklet on WorkCentre 7345 , need help argent !!!
OK, same problem, I've gotten through the solution. I can print and have the first page and last page on one side of the large sheet and the two inside pages on the other side, so that is foldable into a booklet.
I start with a 4 page (US letter sized) document I wish to print as a booklet on tabloid paper.
In the (page layout or editing program's) print dialogue, I've said print all pages, set it at 1 page per sheet, then clicked the printer properties button to open the Xerox Workcenter 7345PS option dialogue.
In the Xerox dialog on the "Paper/Output" tab, selected the larger (Tabloid, 11x17" in my case) paper size, selected 2-Sided Print. Then I select the "Layout/Watermark" tab and clicked the Booklet Layout radio button, chose "Landscape" for the Page Layout Option. Note: I saved these settings as "Tabloid Booklet" by clicking the down-arrow to the right of "Driver Defaults" so that I could select them and not have to dial in every one of the settings whilst experimenting.
Apr 11, 2008 | Xerox Office Equipment & Supplies
Canon imageRUNNER 3570 Copier Logo
135 people viewed this question
old marine
old marine
