Question about Onkyo TX-8511 Receiver
Onkyo tx 902
Don't know how to preset the tuner radio stations.i try manually searching for the station and then pressing the disire number but it don;t work?
Re: onkyo tx 902
I have a TX-902 owners manual.
It states:
Classified Memory Function. The memory can be divided for different users or programs of stations.
How to classify stations. With this model, six classes (Class A to F) are available and stations can be memorized in any class. A total of 30 stations can be memorized in any class. A total of 30 stations can be memorized.
1. Tune in the desired station.
2. Press the MEMORY button. The MEMORY indicator will flash for 8 seconds.
3. Press the desired Classified Memory button (one of buttons A to F). The station is memorized in the selected class with the memory number which is the smallest of the unoccupied numbers in the class.
By repeating the operations above, up to 30 stations can be memorized. Any more will produce "FULL" notice.
How to cancel memorized stations:
Retrieve the class number you want to cancel and then press the MUTE/MODE button while holding down the MEMORY button. Another station can be memorized with the memory number which has been cancelled.
Hope this helps.
Posted on Jan 08, 2008
Re: onkyo tx 902
I have a Onkyo TX902 Receiver, I can't erase the memory ( memory is full) to set my radio stations
Posted on Nov 15, 2008
0 characters
3 Points
How to present the radio stations
Using the front panel of the receiver- select the intended radio station and then press the hold the MEMORY button found on the front panel of the recevier for a few seconds. It should blink and offer a preset number. Press the MEMORY button again to set the radio station to this preset.
If you have any more questions or concerns, Please contact our Product Support Dept for further assistance with this specific issue via our phone number and hours of operation (800-229-1687; option #3 PRODUCT SUPPORT 24 hours a day). We would assist and answer any questions or concerns you may have with your Onkyo product.
- Onkyo USA Product Support Dept.
Oct 11, 2014 | Onkyo Audio & Video Receivers
Can only receive forgein channels
See the swection on "Listening to the radio" on page 24 of the manual...
You can switch the AM band tuning steps between 9 kHz and 10 kHz.
The initial setting is 9 kHz. Please set the AM tuning step frequency to match the AM band tuning step frequency in your area.
USA and Canadian models 10 kHz
Other models 9 kHz
Press MEMORY while holding down TUNER.
Note: All the preset stations are erased when you switch the AM band tuning steps.
Oct 07, 2011 | Onkyo TX-SR500 Receiver
I just bought the RCA CD/DVD home theater system RTD206. I cant figure out how to change the radio channels. Also cant figure out how to change the cd disk tracks. Does this system have a remote. Or do...
The system does have a remote (at least it should come with one if purchased new), and you need it to control pretty much everything. Here's what the manual says about the radio tuner (you can find the whole manual here) :
Manual Tuning
1. Connect the FM aerial and the AM loop antenna at the back of the unit. Rotate the AM loop for
better reception.
2. Press TUNER to enter TUNER mode and toggle between FM and AM.
3. When the FM station broadcasts Stereo sound, ST is displayed.
4. Tune a station by pressing repeatedly the TUNER+/- buttons until the desired station is found.
Alternatively, you can press and hold the same buttons down for about one second to activate
the automatic search function. In this mode the player will automatically tune frequencies until
it finds a station.
5. Repeat step 4 to tune to another radio station.
Storing radio stations
The player can store up to 30 radio stations in its memory. You can enter every single radio station
yourself or the player can store all available radio stations automatically in ascending order.
Automatic preset programming
1. Press TUNER to enter the Tuner mode.
2. Press and hold TUNER down for 3 seconds to start automatic preset programming.
Note: A weak signal can affect the "Automatic preset programming" function's efficiency. Adjust the aerial for better
reception and a more efficient search.
3. Radio frequencies will be browsed and radio stations stored automaitcally. When all the available
radio stations are stored or all 30 memory locations are full, the auto preset programming
function will stop.
Manual preset
1. Tune to a radio station (see "Manual tuning" for details).
2. Press MEMORY once to enter flashing Preset Loaction number.
3. While the Preset Location number is still flashing, input your desired preset number (1-30) using
the numeric buttons or press the CH+/- buttons, then press MEMORY to store it.
Retrieving preset stations
2. Press CH+/- to search up or down for the preset stations or directly press the numeric buttons.
As you see, you really need that remote. The same is true for disc play. While there are front panel buttons for play/stop, disc skip, and drawer open/close, you don't have any other control without the remote. Without the remote control you'll find this system won't do too much, unfortunately. If you bought this new, check the packing material before you throw it away to make sure the remote's not still somewhere in the box. They often come tucked into slots on the foam inserts.
Also, when you hook the unit to a TV, it's just using the TV as a video display device. The TV has nothing to do with any of the system's other functions.
I hope you have luck locating the remote! Thanks for using Fixya.
Jun 29, 2011 | Audio & Video Receivers
How do I preset the tuner for radio stations. I've never had a problem doing this with any other stereo. But what I think should work isn't!
Not very specific. Do you have the manual?
The following is from a VSX-03TXH manual. It ain't pretty but it may help.
I'm posting it in multiple parts due to space contraints.
Chapter 6:
Using the tuner
The following steps show you how to tune in to FM and
AM radio broadcasts using the automatic (search) and
manual (step) tuning functions. If you already know the
frequency of the station you want, see Tuning directly to a
station below. Once you are tuned to a station you can
memorize the frequency for recall later-see Saving
station presets below for more on how to do this.
1 Press the FM/AM button to select the tuner.
2 Use the FM/AM button to change the band (FM or
AM), if necessary.
Each press switches the band between FM and AM.
3 Tune to a station.
There are three ways to do this:
Automatic tuning
To search for stations in the currently selected band,
press and hold TUNE ?©/?? for about a second. The
receiver will start searching for the next station,
stopping when it has found one. Repeat to search for
other stations.
Manual tuning
To change the frequency one step at a time, press
TUNE ?©/??.
High speed tuning
Press and hold TUNE ?©/?? for high speed tuning.
Release the button at the frequency you want.
Improving FM stereo sound
If the TUNED or STEREO indicators don't light when
tuning to an FM station because the signal is weak, press
the MPX button to switch the receiver into mono
reception mode. This should improve the sound quality
and allow you to enjoy the broadcast.
Using Neural THX
This feature uses Neural Surround™, THX® technology to
achieve optimal surround sound from FM radio.
• While listening to FM radio, press AUTO/DIRECT for
Neural THX listening.
Dec 23, 2010 | Pioneer VSX-07TX Receiver
How do I preset radio stations on my hi-fi system?
Owner's Manual is PN 3834RH0020U
On pg13
1. Press TUNER/BAND to select AM or FM
(Leftmost rectangular button on left of volume knob)
2. Select station by using TUNING +/-
3. Press PROGRAM/MEMO on the remote
A preset number will appear.
4. Press PRESET +/- (or PRESET ^/v on remote) to
select the preset number you want.
5. Press PROGRAM/MEMO again. The statio is stored.
6. Repeat above for more stations.
Believe you can store up to 30 stations.
Apr 28, 2009 | Denon DRA-375RD Receiver
Onkyo tuner
the model is at the back panel it usually starts with a TX or a T. go to or call 1-800-229-1887 were here to help.
Oct 29, 2008 | Onkyo TX-SR605 Receiver
Tuner Omits No Sound - Onkyo TX-SR605 7.1 Channels Receiver
Make sure your receiver is hooked up to proper AM and FM antennae. Try switching to AM, scan stations. If you hear AM static and/or weak signals the problem could be antennas are not hooked up. FM has AFT which blocks out weak or noisey stations and you wont hear anything without ant.
May 06, 2008 | Onkyo TX-SR605 Receiver
Can't set the tuner radio stations
After finding the station press the memory button and then the station preset you want to save it to.
Nov 19, 2007 | Onkyo TX-8511 Receiver
Radio stations memory preset
Manually tune to the station you want to store.
Press and hold the button you want to store it to for a few seconds.
Oct 13, 2007 | Onkyo TX-8511 Receiver
Onkyo TX-8511 Receiver Logo
1,926 people viewed this question
Top Onkyo Audio & Video Receivers Experts
 Mike M
Mike M
D. E. Hev
Are you an Onkyo Audio and Video Receiver Expert? Answer questions, earn points and help others
