Question about Nokia 6300 Cellular Phone
The screen says the battery is charging but it wont turn on
I dropped my phone down the toilet a few months ago and since then it wont turn on but when i've tried it today it shows the battery symbol on the screen when i charge it and when i stop charging it the blue lights on the side flash - any ideas??
Why wont my moto g turn on or charge?
Have you checked the battery? I have seen new batteries last only a few months.
Could any moisture possibly gotten inside the phone?
Was the device dropped?
Jul 02, 2014 | Motorola Cell Phones
My samsung rant wont charge. it charged yesterday but today after plugging it into the charger the Samsung name lights up and then it says "low battery please charge" but it wont charge, i did drop it in...
Phone not charging.
Hello, when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
Might be due to dust or dirt. You can Clean charging port on the phone with a brush and alcohol to remove dirt.
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And if charger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
Take care.
Aug 10, 2010 | Cell Phones
My iphone wont charge it just gets hot and wont turn on what do i do?? Its the old one i have had it for 2 1/2 years
I had this problem a few months ago. I shut it down and removed the battery over night, and it was fine when I turned it on the next morning.
Nov 03, 2009 | Apple iPhone Smartphone
Got water damage and wont turn on
I dropped my phone in the toilet and surprisingly it still works. First I took the battery off and dried the phone and battery as much as I could. Then I took my blow dryer and a towel where I folded the towel in half and positioned the phone and the blow dryer under the towel and left it going for about an hour. The next day I took the phone and sat it in the sun until the inside moisture was gone. Then I charged it my phone has been working fine ever since and that was nearly two months ago.
Oct 05, 2009 | LG CHOCOLATE VX8500 Cellular Phone
I dropped my mobile down the toilet and it hasn't
He must have removed the battery when it was dropped. This is to prevent any further damage to the phone due to internal short circuit. Remove the battery and let the unit dry for few days or store it in a warm place beside a desiccant or silica gel.
The battery is drained and must be revived first. You can try using other battery so check if it's only your battery that is drained and makes the phone don't work.
To revive the battery, connect its terminals to a DC power supply with voltage between 5 to 9 volts. Do this until the battery gets warm..
Sep 10, 2009 | Sony Ericsson K750i Cellular Phone
Keypad is jammed
http://www.fixya.com/support/r3771170-phone_water_damage
Aug 23, 2009 | LG Shine KE970 Cellular Phone
I have the same problem!!!! I just dropped mine 2 hours ago!!
Jun 04, 2009 | LG Vu CU920 Cellular Phone
I dropped it down the toilet now it just wont work.
There is a possibility of it working again but water damage does alot of damaging things to phones. The best solution is to take the battery out and don't use it or try to charge it for a few days. Let it completely dry out and it might work but chances are slim. No matter what you hear or read do not place it in the oven, dry it with a hair dryer or even place it in rice. Those things will actually cause more damage to your phone.
Jan 27, 2009 | Nokia N95 Cellular Phone
Phone regularly cutting out
This is due to malfunction of battery,
i have also experienced same kind of problem with nokia set which is other model. i have also done same what you have done. Change or replace your mobile battery. so it 'll finally solves your problem.
Apr 21, 2008 | Nokia 2310 Cellular Phone
Nokia 6300 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
