Instructions to remove bios password m10 - Computers & Internet
  • 30 Answers
I think you might need to get help from any expert to unscrew your laptop to access the jumper for resetting your bios.
Posted on Jul 20, 2009
    Genius:
  • 1,043 Answers
Normally this can be done by removing your CMOS battery and shorting the CMOS with a jumper. This wipes out the stored into including the BIOS password. Unfortunately this may not be the correct procedure for your laptop. Every manufacturer has their own way of doing this. You can get the info either from your local warranty depot or from the manufacturer.
Satellite pro a120. How can I remove BIOS password?
Anon, Remove CMOS battery or use a jumper. Detailed instruction in attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Clear BIOS Password
Knowledge Base
How to Bypass or Remove BIOS Password Technibble
Apr 11, 2016 | Toshiba Computers & Internet
Clear bios password
try pulling cmos battery for a few mins
Jan 30, 2013 | Toshiba Tecra M10 Notebook
Hi, I got a Toshiba Satellite Pro M10, Is there a way to remove Password?, i can not access to the O.S. (not even to the bios). Thanks
Yeah - if it's a BIOS password, but if it's a HDD password then you're screwed and there's nothing to do but replace the HDD.
For a BIOS password removal, either buy a parallel port password removal key, or make your own. Schematics can be found here: http://www.cgsecurity.org/wiki/CmosPwd.
Aug 05, 2011 | Toshiba Satellite Pro M10-S405 Notebook
Toshiba satellite Pro m10 power on password
If you power it on and get a "password=_" prompt, then it has a CMOS password set. The only known way around it is to buy or make your own parallel port key (aka parallel port password removal key - schematics are available free on the Internet) - which will clear the CMOS and set it back to its default state with no passwords.
Mar 30, 2011 | Toshiba Satellite Pro M10 Notebook
Solve Your IBM (08K3972) for ThinkPad A21P, bios password Problem Now!
To remove the BIOS or Power ON Password is difficult. Removing the BIOS battery will not remove these passwords because the these passwords are stored on an EEPROM chip.
For instructions on removing these passwords, please click on this link :-
http://www.fixya.com/support/r4335050-remove_bios_power_password_thinkpad
Mar 09, 2011 | IBM Computers & Internet
How to reset or bypass BIOS administrator password in Netfinity 7000 M10 ?
Remove the BIOS Battery for 10 minutes and reinsert it. Your problem will be solved
Jan 27, 2011 | IBM NETFINITY 7000 (75H8018) Motherboard
I have forget my bios password please help me toshiba satelite pro M10
If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard.
If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
On some motherboards, the battery is soldered to the motherboard, making it difficult to remove.
If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password.
If you have the motherboard documentation, you will know where that jumper is. If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper. This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard.
If all else fails, you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your motherboard.
Many RTC
Dec 31, 2010 | Toshiba Satellite Pro M10 Notebook
Bios password reset for toshiba lap top
You need to build a hardware device that plugs into the printer port.
Get a 25 pin male D sub connector, and solder various wires
to the pins numbered below. The pins on the connector are numbered 1 to 25
For a picture of this hardware device (dongle) go to :-
http://www.tilman.de/sonstiges/toshiba/dongle1.jpg
Connect these pins together by soldering thin insulated wires to the following pins :-
1-5-10,
2-11,
3-17,
4-12,
6-16,
7-13,
8-14,
9-15
Plug the dongle in the printer port and boot up the laptop, you will then be able to bypass the BIOS password and go into the BIOS to reset/remove the password.
Mar 08, 2009 | Toshiba Satellite Pro M10 Notebook
Unlock bios password
i have forget my bios password please help me on Hasee laptop
Nov 20, 2007 | Toshiba Satellite Pro M10 Notebook
Computers & Internet Logo
1,142 people viewed this question
David Payne
David Payne
