Question about Husqvarna Zero Turn Mower Z5426
My husqvarna zero turn mower has an auto safety shut off. I have isolated 3 (Brake, Left control level, and Right contol lever)trying to see which one was faulty, but I'm not sure where to go next. When I took the brake off, the mower stalled so I held the safety button down and when the brake was off the engine stayed running. But when I pulled the Left or Right Control level to move, it shut off, so I held those down to see if I could see which one was faulty. The engine stayed running, so I couldn't figure out which one was bad. Every thing stayed running until I engaged the mower deck, and then it shut down again. I gave up at that point and figured I needed an experts help! Thanks, Jon Sable
  • sablejon6 Jul 20, 2009
    Nope. The person I bought this from had disconnected the seat switch before I bought it...
  • blueextc3221
    blueextc3221 May 11, 2010
    Isn't there one on the seat too?? In case you go flying off during a ZERO turn!! :D
  • 1,000 Answers
There should be a switch under the seat. The system is designed to stop all functions if no one is setting in the seat. I believe the seat switch has failed.
Check it out and let me know.
Regards,
Posted on Jul 20, 2009
  • Bruce Bracey
    Bruce Bracey Jul 20, 2009
    If he disconnected the seat switch make sure the wire and or connector are not grounding out or pinched. Did he put a jumper acrossed the two wires to the seat or was it just disconnected.
    Regards,
Husqvarna 4623 zero turn mower will not move
Maintanance - How to purge Hydraulic drive system Published 01/13/2010 11:56 AM ' Updated 06/02/2015 02:52 PM
How do I purge the hydraulic system?
Hydrostatic transmissions use oil, under pressure, to provide movement for the tractor. The fluid is pressurized with a pump inside the transmission. If any air is in the fluid, the pump will try to pressurize air. This condition is known as cavitation, and is detrimental to the pump since it allows the pump top operate dry. When the pump cavitates it is not pressurizing any fluid, so the transmission is not able to provide the movement needed.
If your mower is new, or has been stored for a long period (longer than 2 months) the transmission needs to be purged before use. Also, if you experience loss of drive, or slower response, then the transmission should be purged first.
The following procedure will remove trapped air inside the transmission(s).
IMPORTANT: SHOULD YOUR TRANSMISSION REQUIRE REMOVAL FOR SERVICE OR REPLACEMENT, IT SHOULD BE PURGED AFTER REINSTALLATION BEFORE OPERATING THE TRACTOR.
Step 1- Place the rear of the mower safely onto jackstands on a level surface with engine off and parking brake set.
Step 2- Disengage transmission by placing freewheel control, located at the back of the frame, in the freewheeling position.
2a- Mowers with seperate pumps and wheel motors the freewheel is activated by turnign the bypass valves, one on each pump, two full turns.
The oil resevoir needs to be filled to the specifications listed in the owners manual before starting the purge procedure.
Step 3- Sitting in the operators seat(riders), start engine. After the engine is running, move throttle control to slow position. With motion control levers in neutral (N) position, slowly disengage clutch/brake pedal.
Step 4-Move motion control levers to full forward position and hold for five (5) seconds. Move levers to full reverse position and hold for five (5) seconds. Repeat this procedure three (3) times.
NOTE: During this procedure there may be some movement of the drive wheels, but they are not under load. The air is being removed from hydraulic drive system.
Step 5-Move motion control levers to neutral (N) position. Shutoff engine and set parking brake. Check and add oil as needed for units with an oil resevoir.
Step 6-Engage transmission by placing freewheel control into driving position, or by closing the bypass valves on the pumps.
Step 7-Sitting in the operators seat, start engine. After the engine is running, move throttle control to full speed. With motion control levers in neutral (N) position, slowly disengage clutch/brake pedal.
Step 8-Slowly move motion control levers forward, after the tractor moves approximately five (5) feet, slowly move motion control levers to reverse position.
After the mower moves approximately five (5) feet return the motion control levers to the neutral (N) position. Repeat this procedure with the motion control levers three (3) times.
Step 9-Your mower is now purged and now ready for normal operation.For further information or assistance, we recommend contacting your lo
Aug 06, 2016 | Husqvarna Garden
How do I bypass the seat safety switch on a 5424 Husqvarna zero turn mower?
ether unplug it if wont start then jump the wire pigtail with a wire you can bypass both switch like this
Sep 16, 2014 | Husqvarna Rz5424 Zero Turn Lawn Mower...
Lawn mower
sounds like you got water in a safety switch look at the ones on the speed control arms
Aug 18, 2012 | Husqvarna Mower Rz4621 Zero Turn
My husqvarna zero turn cuts off when i release the parking brake
safety switch problem-
1. under seat
2. PTO Switch
3. one for handle bars for the drive system
one has either come loose or has failed, most likely one id not fully connected.
Jul 21, 2010 | Husqvarna Zero Turn Mower Z5426
Engine will not turn over
Those boxes are probably relays. Sounds as tho one of your safety switches is not working correctly. Make sure you have the machines brake on, blade off, and any other safety measures are applied, such as the operator is sitting in the seat. Check the wiring connections at all the connections where the safety features are installed. Probably just a connection that is not letting the system know that all systems are indeed applied.
Nov 14, 2009 | Husqvarna Zero Turn Mower Z5426
Husqvarna Zero Turn Mower Z5426 Logo
749 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
