Question about KitchenAid KTRP22EK Top Freezer Refrigerator
Water is pooling in refrigerator
From freezer to lower compartment
    President:
  • 1,136 Answers
Hi, The defrost drain behind the rear freezer panel is plugged. Remove the rear panel and clear the ice away from the drain. Then you will need to flush the drain hole with hot water to make sure it is open.
Some models require an after market drain heat kit.
Please get me your model # and I can look this up to let you know if you need that heat kit.
Thanks
Vic
Posted on Jul 20, 2009
Water pooling on top shelf in refrigerator with top freezer
Your drain is obstructed within the freezer compartment causing the water to floe into to lower section via vent ducts. To correct this, you will need to access the rear wall of the freezer and at the bottom you will find the drain hole. Remove the obstruction with warm water and remove all the ice also.
Good Luck
Mar 06, 2016 | Refrigerators
My Roper refrigerator has water inside it at the bottom and on lower level shelves. How can I correct this?
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Good luck
I hope this helps
Gene
Aug 01, 2011 | Roper RT21AKXKQ Top Freezer Refrigerator
Water is pooling at bottom of fridge, comes out from area at top in the back behind light.
If your freezer is above your refrigerator compartment, this may be your problem:
Your defroster (automatic) may not be working properly. Ice is building up in freezer drain, damming up the drain hose to the outlet. Water then overflows down into the refrigerator compartment.
Nov 03, 2010 | Whirlpool Refrigerators
Water pools and freezes at bottom of the freezer. When tray is full water leaks out of freezer onto kitchen floor.
I am uncertain as to what you mean by "when tray is full"? However, you probably have a clogged drain in the freezer compartment. During the defrost cycle, which usually occurs every eight hours, defrost components (defrost thermostat & heater(s) ) melt the ice that has accumulated on the evaporator coil in the freezer compartment. The water from the melted ice drains through a hole in the freezer compartment (behind the freezer's rear panel) and accumulates in a drain pan below the refrigerator. This water should evaporate over time, whereby you should not have to regularly empty the drain pan. If the drain hole is clogged (usually from algae or other debris, etc.), the water finds another path to flow (which is inside the bottom of your freezer compartment). This water will usually freeze. Water will then flow toward the front of your freezer compartment and out of the door on to the floor when you open the door.
Contact an appliance service company to unclog your freezer drain. Also have them check your defrost components (thermostat & heater(s)).
Feb 15, 2010 | Frigidaire Refrigerators
Pooling of water in fridge compartment of my Neff fridge/freezer
The defrost drain is clogged. Defrost drains usually get there clog right behind the back freezer panel. Remove this to get to the defrost drain and remove all built up ice and clear the drain and you should be fine. Hope this helps.
Feb 04, 2010 | Refrigerators
Water weeping out vents in lower back of freezer compartment
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Jun 29, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Water pools under the veggie crisper
yoor problem is with the drain, when your refrig goes into self defrost the water melted from the defrost needs some where to go. There is a drain for this purpose....it is normally a tube that leads from the rear of freezer to pan by compressor. when this gets blocked the water has nowhere to go except into the freezer vent and down the bottom of the refridge compartment. you will need to clear the blockage in the drain tube...if you are still haveing a problem i can tell you how.
Jun 21, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
I have water pooling on my fridge trays and than turning into ice . The water seems to be coming from the vents. How do i get rid of that.
The freezer compartment has a drain hole behind the back wall inside the freezer compartment. The drain hole has probably rusted and has gotten larger. Carefully remove the icemaker and the screws from the back wall inside the freezer compartment. Lift the bottom of the back wall and look to see if the drain hole has gotten larger. You can make a small funnel from an aluminum can to fit over this area directing the water into the drain tube. It worked for me. good luck. Dave.
May 10, 2009 | Whirlpool ET9FHTXM Top Freezer...
Water Pooling and freezing on floor of freezer
most likely you have a frozen drain in the freezer section so that whne your refrig defrosts the water runs out into the freezer compartment instead of the drain pan underneath. the fix is to flush the drain with warm water to clear the obstruction. the drain can be reached either by removing the cover in the freezer area or by back flushing the line from beneath the refrig.
Dec 10, 2007 | GALAXY Microsystems 25.4 cu. ft....
KitchenAid KTRP22EK Top Freezer Refrigerator Logo
114 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
