Question about Sony CDX-A250 CD Player
How do I remove as coins stuck in cd slot
How do I remove as coins are stuck in cd slot
    Scholar:
  • 106 Answers
Hi....
there is only one way to remove the coins from the cd slot.....you needed to go for the service center....there they will disassemble it in few seconds and take out the coins and reassemble it very carefully.....so that your cd player also doesn't get any damages in it....it will cost only very little....
if you are satisfied with my solution then rate for me.....
thank you for using fixya.....
Posted on Jul 20, 2009
How to remove a carousel stuck on a Kodak Carousel projector
No problem! FIRST, make sure the locking ring is in place and tight on the top of the tray. Next, locate the center hub (the hole in the center of the tray fits over it). In the center of the hub you will see either a "coin slot" or a small metal lever. Push the lever in the direction it will move and at the same time lift the tray off the projector. If you have a "coin slot), use a quarter to turn the coin slot until the tray is released. Turn the tray upside down, replace any slides that may have left the tray when it became stuck, and rotate the bottom metal plate until it locks in the locating slot. Turn on the projector and cycle it a few times IN REVERSE without a tray on it. this unlocks the jam in the projector. You should be good to go now!! Good Luck !! Jim
May 05, 2012 | Kodak Carousel 4600 Slide Projector
Pls help me... my dvd rom have coins inside.i didnt know.i put cd and then it cant open and i cant take out the cd aswell. my laptop is dell studio 1435... pls help me...
Look at the cover near the cd slot - it should still have the hole. You mention coins inside - kids? It seems probable that the cd was installed with power on, but you will still have the hole - it's small so that a paper clip will just fit into it. Since you have the coins probably still in there, I would disconnect power, remove the cover and pull the cd driver from the tower case. More than likely the cd and cdrom drive will be damaged beyond repair, but if you remove the drive from the computer you'd be able to shake the coins out of it and also to be sure the coins aren't going to short out *********** board. If you can do that then you might as well reinstall everything and put it back together, then power it up to check it. Who knows you might get lucky...
Sep 23, 2010 | Dell (JP-03G005-26401-16R-H324)...
Cd error displayed on kia grand carnival 2008 stereo
There could be another cd stuck in your player. you can try to straighten it out with a credit card and press eject. The Cd may have angled itself upwards or downwards and is jammed inside. Or possible a child stuck a coin inside the cd slot and jammed the moving parts.
Apr 06, 2010 | Car Audio & Video
How do I remove coin stuck in my jaguar xtype cd player
The only safe way to remove the coins is to remove the cd player from the dash and then gently shake the coins out. That said, you can take the car to any audio shop and have them do it for you or if you are so inclined you can do it yourself. Just be sure to disconnect the battery and also be sure that you have the correct code for the anti-theft mechanism.
Here is a link that will give you the flavor of all of the steps involved if you should choose to do this yourself http://gopaultech.com/blog/2007/02/removing-honda-odyssey-cd-player/comment-page-2/
Regards, Joe
Nov 12, 2009 | 2002 Jaguar X-Type
I have a coin and a cd stuck in the cd player. What can I do?
Unfortunatly you will have to remove it and take off the cover. You could try a small tipped needle nose pliers and grab cd at same time as pulling on cd Hemostats will work as well you can remove coing by putting double sided tape on a toungue depresser and fishing around. first Hmm do you have a child? seems they love to put coins in slots been there!
Oct 12, 2009 | 2000 Oldsmobile Alero
Cd will not eject from radio
It sounds like a bent mechanism, or you have something stuck in there, i see a lot where kids put coins and stuff into the slot. there is a repair center in Bradford called autosound 01248688990 they repair nissan.
Jul 30, 2009 | Car Audio & Video
STUCK CD CHANGER
A coin has fallen down inside the unit. If you unbolt it from the arm rest and turn it upside down,the coin may fallout. I had to take my apart and physical remove the lodged coin.
Jan 10, 2009 | 2000 Lincoln Continental
Coin operated washer and dryer
remove the coin slot out remove the slug used to plug the coin slot
Feb 24, 2008 | Washing Machines
Whirlpool coin operated washer and dryer
you need to take the coin slot out by using a socket wrench. then you need to flip the slot over and take the screws off. there is going to be two more screws to unscrew. take off that piece and also the claw like coin catcher. form here on out you should be able to remove as many slots as you need to.
Sep 06, 2007 | Washing Machines
Sony CDX-A250 CD Player Logo
566 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
