My jvc tv is having a convergence problem and the factory reset will not work when i use the remote
  • 8,617 Answers
Instal a convergence repair kit . You should be able to get one for your JVC at the following link the kits contain the parts and CD with instructions
http://www.tvrepairworld.com/
Posted on Jul 20, 2009
2 Suggested Answers
  • 1525 Answers
SOURCE: convergence
hello theres a couple of codes you can try .1-2-7-0/2-4-5-7/0-3-5-3 /0-3-5-7 do not use the reset it may cause damage ti the tv good luck
shaun
Posted on Apr 10, 2009
I mistakenly turned on the child lock of my JVC TV ,now I can't turn the TV on again all buttons are not working both on the remote and the TV please can anyone help
Try a reset. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Feb 14, 2017 | JVC Televison & Video
How to reset JVC smart TV LT49N940,Remote and all button on TV does not work,when switch on no application appears as it use to be, it`s start directly on the last input with no sound thanks
Apr 18, 2016 | JVC Televison & Video
Need help with tv
U replaced 2 STK convergence ICS right?U check all the resistors too,and replaced it right?The convergence problems usally reset it back by it self.If all convegence parts are replaced correctly,and finish.
Mar 17, 2010 | JVC AV-56WP74 56" Rear Projection...
Rca d52w27d no convergence in the set up menu cant run the convergence
some rca models have the convergence as a seperate button on the front or side of unit. sometimes if unit has guide plus+, unit wont have that option. try on your tv factory remote, with tv on, push menu, 7, 1, go back, tv. that is the code to reset your computer in tv.
Nov 14, 2009 | RCA Televison & Video
Color convergence controls on remote don't work in some areas, ie: location 1 cross won't go up and down, area 5 won't go side to side, etc. Can I adjust the color convergence another way ? I tried the...
It sounds like the convergence ic's have gone bad. Have a service tech look at it because some models of JVC were made by Samsung and they developed a fluid leak from the CRTs which in turn cause this same type of problem.
Sep 28, 2009 | JVC AV-48WP30 48" Rear Projection...
I can`t switch on my g-hanz TV
http://resources.jvc.com/Resources/00/00/94/YA059ien.pdf This is a link to a pdf copy of the owners manual for your model television. You can find all the setting and function controls listed in the manual. To reset the television to factory settings, you must unplug it from the a/c power source for about thirty minutes. This will reset the television to the factory settings. You can do the same thing with the remote control. Just remove the batteries and press the input button continuously for about 1 minute. This will drain all the power out of the microprocessor and reset the remote control to the factory settings. You can then use the owners manuals to reset the television and remote functions.On turning on the television the interactive plug in menu will appear. From here you can set the language you want to use for the television. All of this is explained in the owners manual.You will need a pdf reader and writer to read the owners manual and the writer to make a copy for your own use. I hope this information helps you with your problems with the remote control and television. Thank you for using FixYa and have a nice day!
Jun 16, 2009 | JVC AV-32D305 32" TV
Convergence trouble
You most likley have bad convergence amps and two burnt resistors.Part# STK392-110.Convergence circut is located @ frot of set behind speaker grill.The only reset is in the customer menu listed Convergence reset.
Jan 12, 2009 | JVC AV-65WP74 Rear Projection Television
JVC AV-48WP30 tv(convergence)
This is a convergence board problem. Have a tech replace convergence IC's. The part no. starts with STK. If you are good in soldering and know how to test resistors, you can do it.
Jul 16, 2008 | JVC AV-48WP30 48" Rear Projection...
Remote LOST - need info on what button to press...JVC AV-48WP30
There might be some features that the universal remotes aren't able to do. To perform the convergence alignment you should have the original remote.
Do you have the user manual or service manual?
The service manual will explain this process better.
Apr 10, 2008 | JVC AV-48WP30 48" Rear Projection...
Can't shut off closed caption
I have the JVC I Art 46" TV. The Close Caption was turn on accidentally by my grandson. After lots of searching for the original remote. I called JVC Customer Support. He told me to change the Close Caption settings to CC2 and T1. That fixed the CC without having the original remote.
Apr 10, 2007 | JVC AV-32F704 32" TV
Televison & Video Logo
93 people viewed this question
Top Televison & Video Experts
Electro Med Services...
