Question about LaCie d2 Extreme FW800 (300878) 200 GB Hard Drive
Lacie visible with airport express but not visible with directly
If my Lacie drive is connected to my airport extreme base station all is fine, visible in the finder and on the desktop and it gurgles away happily, if however I try to connect it with Firewire 800/ firewire 400 or USB directly to my mac book pro (os x 10.5.7) it just doesn't show. Like the other guy it starts up, and gurgles just like it should but I just can't see it and neither can the disk utility. I have had it for a while now, long before I got the airport extreme base station, it always worked, I have a feeling that it has something to do with the fact that the aebs has to set some sort of password (either on a user basis, with the password from the aebs or a hard drive only password). Please help, I do need to use it via Firewire 800.
fire sine
  • 382 Answers
SOURCE: Two units conflict when connected thru Firewire 400
Windows XP and most pcs running it does not natively support firewire,as it was developed by Apple computers. Most Firewire ports on PCs are 4 pin. Your PCI card ( and I take it, its a desktop youre referring to ) should have a 6 pin connection. Firewire connections also have a 7 watt supply via the bus. You may need to open the computer and see if the molex jack on the card is being powered by your computers power supply. Two firewire drives, especially the power hungry Lacie quadras, may be to much consumption for the card. Hope this helps.
Posted on Oct 02, 2007
fire sine
  • 382 Answers
SOURCE: Can't accept Quadra 500 on my owerMac G5 Quad
Scrap LAcie!! Sounds like in this case, it may have been jostled around during shipping. None the less, Lacie drives are nothing more than bricks waiting to fail. Go Western Digital, but if oyu can, zip straight for Seagates!!!! Professional grade!! ALways check the cables, the ones that come with them are bottom bin cables, made by little singapore children with no fingers..... Invest in a good cables...a drive is only as good as the weakest datalink.
Cash on the warranty!!!
Keep me posted.
Posted on Dec 16, 2007
edisonfrelan
  • 113 Answers
SOURCE: firewire hd not showing up in profiler or diskutility on imac gr
Hello! You know how to take off the HDD from its casing?  okay, No. 1 error is due to loose of connections. All you have to do is to dismantle it. And be sure to memorized where its original position. You need to set the jumper settings of your HDD to master.  next, be sure all the connections are intact and well connected, then assemble it again. next, be sure you are using Power Mac g4 CPU 1.2Ghz with at least 1GB of memory or Higher than G4 units, cause 300GB couldn't be detected lower than that, then plug it in. if it still didn't work out, try to ask help from service center near you to assist you.
Posted on Dec 15, 2008
SOURCE: cannot access my lacie rugged
Go to computer Management, change the drive letter from F:\ to any letter.
Posted on Mar 13, 2009
SOURCE: deference Lacie d2 Quadra1TB/Lacie big disk ?
It's all about the interfaces.
The Quadra has four interfaces: • eSATA • FW 400 • FW 800 • USB 2.0
The triple has all but the eSATA interface listed above.
For doing video work you want a big drive with a fast interface. If you have eSATA available then that's the fastest. If you don't then you're just as well off to go with the triple interface. The FW 800 would be the next fastest, then the USB 2.0, then the FW 400.
Because of the way that data is transferred I believe that when doing video work you would be best served by the FW 400 instead of the USB 2.0 even though the USB is faster I don't believe it is a full duplex communication so the FW 400 is actually better for video.
Posted on Apr 06, 2009
Trying to update firmware on y airport extreme but i forgot my password
You need to perform a soft reset of your router. There directions to do this from the Apple web site are:
  1. Connect the AirPort Base Station or Time Capsule to power.
  2. Press and hold the reset button with a pen or pencil for 1 full second, then release it. The light (LED) will begin flashing amber, indicating that the AirPort Base Station or Time Capsule is in soft reset mode.
  3. From the AirPort menu bar item, choose the network created by the AirPort Base Station or Time Capsule (the network name does not change).
  4. Open AirPort Utility in Applications > Utilities on a Mac using Mac OS X, and in Start > All Programs > AirPort on a computer using Windows.
  5. Select the AirPort Base Station or Time Capsule and click Continue.
  6. A window indicating that the device has been reset will appear.
  7. Select "Restore the previous settings" and select OK.
  8. Move through subsequent windows to make changes to your passwords or other settings as desired, clicking Continue after each one.
  9. When you have moved through all of the selection windows you will be able to select Update. Click Update to install the new settings.
  10. Click Continue to allow your AirPort Base Station or Time Capsule to restart.
  11. Quit AirPort Utility.
These directions are from the Apple Support Web Site:
http://support.apple.com/kb/ht3728
Jan 02, 2011 | Apple AirPort Extreme Base Station
How to use apple time capsule and apple base station together?
Basically Time capsule is same as Airport extreme base station added with a hard drive to take wireless backup.Put same Network Name and password in both Time capsule and airport base station.Suppose your are making TC as a primary base station and Airport extreme as a secondary base station. Select WDS in both the base stations .In "Wireless Mode" select"Participate in WDS network" in both the base stations.Dont change rest of the options.Put TC Mac id to Extreme base station and extreme Mac ID to TC.now open the airport option in your laptop and check.you can see a single network name.Its DONE.Njoy using wireless
Mar 31, 2010 | Apple MacBook Pro Laptop Computer with...
Apple AirPort cannot get IP address from cable modem using DHCP
go to applications,utilities and go to airport set up and check the settings, it could need the DHCP setting up or the old settings deleted
May 24, 2009 | Apple AirPort Extreme Router
Airport Extreme Bases Station not detectable with utility
This depends... Reaching them wirelessly may be unreliable for a number of reasons, so, I'll proceed on the assumption that you are attempting to test in the simplest lowest-variable situation:
First, make sure that you have the latest Airport Utility for your Mac.
Connect your Mac to the Airport via a single Category 5 (or 5e or 6) cable. Factory-reset the Airpot and then wake up the Mac. If the utility still can't discover your airport, it's probably time for a trip to your local Genius bar as you most likely have a hardware problem.
Lather, rinse, repeat for each of the two airports.
Apr 28, 2009 | Apple AirPort Extreme Base Station...
I can't connect apple airport expresses with a siemens 587 route
Login to your airport express using Apple's airport utilities (either in it's current configuration or after resetting it).
Using the airport utility do not choose manual setup, just select continue.
Adjust (as required) the airport express station name and password and select continue.
Select "I have a wireless network and I want to add AirPort Express or replace an existing device on my network and select continue.
Select I want Airport Express to wireless join my current network and select continue.
Choose if you want to extent the rance of your network or just join the network and select continue.
Choose the network you wish to join... etc etc etc....
You should be fine.
Jan 31, 2009 | Apple AirPort Extreme Base Station
Apple extreme bridged to apple extreme (Windows network)
OK, do you have the latest version of Apple's Airport Utility: Version 5.4.1 (541.9) ?
If you don't, get it... it's got an excellent interface that will walk you through bridging two wireless routers together.
Once you get your hands on it, you will need to choose which airport will be the primary and which will be the secondary. Ideally, pick the one connected to the highest speed and most reliable internet access.
Connect to the secondary airport and configure it as bridge to the primary, the Airport Utility will walk you through it step by step.
Jan 13, 2009 | Apple AirPort Extreme Base Station...
Apple® - AirPort Express Wireless-N Base Station
No. The airport express just has a shorter range. You can use both a regular base and express to extend the range further. Also, the express can be used at your home stereo. You can play your Itunes library directly to your stereo with an adapter to the express. Anyway, the express is just a less powerful wireless, with some special features. We print through it and use it exclusively. May add base station later. Good luck.
Jun 16, 2008 | Computers & Internet
New wireless network - now my airport express and airtunes does not work
Hi I was searching this site for a solution to a problem I am having and came across your post. I had the same issue and what I did was reset my airport express to factory settings (detailed in manual) - this enabled the Airport extreme to find/pair with it.
Sep 02, 2007 | Apple AirPort Express (M9470Z/A) 802.11g/b...
LaCie d2 Extreme FW800 (300878) 200 GB Hard Drive Logo
133 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
