Question about Samsung SGH-t229 Cellular Phone
T229 bluetooth problems
I just bought a T229 and I cannot get the bluetooth to connect to my computers. My Mac laptop can find the T229, but my iMac says device does not have these services. The T229 cannot find any bluetooth devices.
How do I get Bluetooth to recognize new batteries?
Is it an iMac? If it is, turn the Mac off then unplug for at least 10 sec. Plug back in then turn on. Do not put back the batteries until bluetooth starts to search for your bluetooth device that you are tring to connect. Good luck.
Dec 19, 2014 | Computers & Internet
Imac bluetooth and usb not working
Simply you can't alone, probably you have problems with your southbridge on motherboard. Usualy this can be solved with rebaling. Is a common problem because - probably - you not clean your mac regulary.
Nov 20, 2013 | Apple 21.5" iMac Desktop
I have a Mac osx g9 and IO don't know how to install bluetooth do I have to buy something or download it?
Go to
Finder » Applications » System Preferences
Under the Internet & Wireless section there is a Bluetooth option. Click on this.
Make sure both 'On' and 'Discoverable' are clicked.
Dec 25, 2010 | Apple Bluetooth Card (Rev. 3) for eMac,...
Imac Flash Player locks up Bluetooth then crashes
Do you know for a fact that Bluetooth is at all involved? Try attaching a wired mouse -- if the wired mouse also freezes, the problem does not involve Bluetooth.
Flash is notorious for causing system problems on Macintoshes. Try reinstalling the most recent version of Flash.
May 23, 2010 | Apple 24" iMac Desktop
Iomega 1TB HD Works on iMac but not on Windows Laptop?
as the mac has a diffreent format to a pc you cannot connect up the drive to a pc because it simply wont recodnise it. the best way is to network the 2 computers together then alow file sharing on the mac and searcc with windows through the network to find the drive. then copy them across the network to your pc. this will then reformat the files to PC files at they hit your PC
May 17, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
Downloading
Your computer is full of potential free ringtones for your Samsung T229 (also known as Samsung SGH-t229, T-mobile t229) :
By Bluetooth:
The Samsung t229 is Bluetooth-enabled. Bluetooth is a wireless system which lets you connect your cell phone to computers, headsets, car kits, etc. If your computer is also Bluetooth-enabled, simply establish a connection between both devices and transfer your music files from your computer to your Samsung t229.
Simply record sound directly:
Since your Samsung t229 has a sound recorder (also known as "voice memo"), a very simple technique involves simply placing your phone near your computer's speakers, playing whatever music or sound you would like as a ringtone, and recording it -- you can even use your voice, your child's voice or even your cat's "meow!" Record it with your mobile and there you go! Unless that function was specifically blocked on the Samsung t229, you should be able to navigate to the ringtones section and choose your new recording as a ringtone. Of course, the quality will not be ideal but, after all, it's free!
Downloading using the phone
NOTE: MegaTones, HiFi Ringers, and Voices & Sounds are stored at Menu > Fun & Apps > Files > Sounds > Sounds. To download using the phone, perform the following steps: 1. At the main screen, select t-zones. 2. Scroll to and select Music & Sounds. 3. Scroll to and select HiFi Ringers, MegaTones, or Voices & Sounds. 4. Scroll to and select the desired category. 5. Scroll to and select the desired tone. 6. On the preview page, select ACCEPT. 7. After the tone downloads, select Play to preview the tone. 8. Select Set as. 9. Select one of the following options:
  • myFaves ringtone: To set as a myFaves® ringtone. Scroll to and select the desired myFaves contact.
  • Default ringtone: To set as the default ringtone.
  • Caller ringtone: To set as a caller ringtone. Scroll to and select the desired contact.
  • Alarm tone: To set as an alarm tone. Scroll to and select the desired alarm. Turn on the alarm and select the desired time and date.
10. Select Save.
Apr 27, 2010 | Samsung SGH-i300 Cellular Phone
Kensington cable lock
Kensington lock slots are universal. Any Kensington or similarly branded laptop/computer lock will fit any iMac, and Macbook, Macbook Pro, Mac Mini, or Mac Pro.
Apr 16, 2010 | Apple iMac G4 20" Mac Desktop
I have a LG Vu and I want to use the bluetooth setting to download photos into iPhoto. How can I do this? I have tried and tried to no avail, my imac book still shows no connection. Help me please!
What you do is find the bluetooth symbol at the top of your screen (the background) then go to SETTINGS and then to DEVICE VISIBILITY (should be the very top) hit the ON choick then OK for other bluetooth devices to recognise it. then go back to the MAIN BLUETOOTH MENU (just hit back button) and go to SEARCH NEW DEVICE (second one down) but make sure you are in the same room as your computer to have your phone connect with the computer. That should then find your computer and then REQUEST TO PAIR (just touch the name of your mac) and then ENTER THE CODE (should be four zeros if you didnt change it and do the same thing on your mac then after that just select the photo you want to send and hit SEND VIA BLUETOOTH and select your mac
Jun 29, 2009 | LG KU990 Viewty
Setting up an OKI printer on an IMAC
Without mac drivers you do have a problem. Put it on ebay and get another printer that supports mac and windows.
May 12, 2009 | Apple MacBook Pro Laptop Computer with...
Mac / Bluetooth / Viewty issues
http://docs.info.apple.com/article.html?artnum=306631
To send a file using Bluetooth to a computer running Mac OS X 10.5 Leopard, you must enable Bluetooth Sharing in Sharing preferences. By default, Bluetooth Sharing is turned off in Leopard.
  1. On each Mac OS X 10.5-based Mac, from the Apple menu, choose System Preferences.
  2. From the View menu, choose Sharing.
  3. Check (click) the "On" box next to Bluetooth Sharing.
  4. Close the Sharing preferences window.`Works perfect
Jun 08, 2008 | LG KU990 Viewty
Samsung SGH-t229 Cellular Phone Logo
394 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
