Question about Whirlpool Refrigerators
Model ED20PKXAN01 side by side. Defrost timer
Whirlpool Model ED20PKXAN01 side by side. Defrost timer went recently and was replaced. Refrig. worked for 2 weeks at 40 degrees. Temp started rising and I manually defrosted as it was iced up. Timer starts and stops like it should. Temp is running at 50 degrees at the normal setting. I turned the setting up a little and it is now at about 45 degrees. Any idea why this is not running at the normal setting of 40 degrees?
  • Whirlpool Master
  • 1,606 Answers
The timer could be set for accumulative instead of continuous . The one wire on the timer , set on the wrong terminal .
Posted on Jul 21, 2009
Have a whirlpool refrig. both sides freezing up even when set on lowest level model # ed5phaxtsoo cleaned coils fan runs allthe time.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 09, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My Whirlpool refrigerator trips the main breaker of 40 Amps
A refrig cannot pull 40 amps in defrost , unless there is a direct short in the defrost system ( timer , heater , bimetal ) . I would use an extention cord ( for test purposes only ) , and try a different plug . Sounds like the circuit breaker is weak . In defrost , the MOST you should get , is 6 amps . This will not throw a 40 amp breaker . If you have an amp meter , remove the back refrig panel behind the refrig , and connect to one of the power cord lines (just not the green ground ) , turn into defrost and check the amps . This will tell you if short is in refrig , or weak breaker .
Sep 06, 2009 | Whirlpool ES5FHAXS Side by Side...
Freezer compartment has frost buildup
This can be caused by the drain hole below freezer coil being blocked by ice. You MUST remove all ice in drain under freezer coil. Use turkey baster to squirt hot water into hole and use hairdryer to defrost. Possible defrost thermostat is defective. Unit never goes into defrost, ice forms on coil and in floor of freezer. After defrosting may work OK for a week or two but gradually gets warmer because ice is blocking ports where cool air gets to refrig. May also have water in refrig box. Can also be caused by defective defrost timer.
Aug 24, 2009 | Whirlpool GS5SHAXN Side by Side...
Refrigerator and freezer not working
you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 15, 2009 | Whirlpool ED5FHEXMQ Side by Side...
GE REFRIG. MODEL#TFX30PRYAA. side by side both
It sounds like your defrost control timer is working, but your defrost heater is most likely burnt out. It is a part number WR51X443
and is located behind the back wall inside the freezer. Turning the refrig off for 24 hours helped melt some of the accumulated frost, but not all. You will have to take that back cover off inside the freezer and melt all the frost with a hair blower, replace the defrost heater and reassemble.
Jul 01, 2009 | Refrigerators
Whirlpool ED25DQ - not colling
Need you to look inside the fresh food compartment and turn the defrost timer clockwise slowly.
d01b0a9.png part number 6 is defrost timer. When you turn it and compressor stops leave it there for 20 minutes and see if the refrigerator comes back on. If not the timer will need to be replaced, Let me know, Sea Breeze
Mar 22, 2009 | Whirlpool ED5FHEXMQ Side by Side...
Refrig/freezer just quite working?
The defrost timer is located in the control panel in the fresh food section.
Look up under the panel and see a opening slightly smaller than a dime.
Put the blade of a butter knife in there and turn clockwise a quarter turn.
If the fridge starts working, replace the defrost timer.
Mar 10, 2009 | Whirlpool ET1FHMXLQ / ET1FHMXLT Top...
Whirlpool refrig not cooling
is the fan in the freezer working when compressor is on? if not you need to replace it. do you have a large frost build up on the back wall of the freezer? if so you have a defrost problem, or back to the evaporator fan. If the fan is working you have a defrost problem which could mean a bad heater, timer, or bad defrost thermostat....
Jan 03, 2009 | Whirlpool GS6NBEXR Side by Side...
Wards/Admiral refrig/freezer
I put the fridge in manual defrost by advancing the timer. The defrost heater worked so the problem was with the timer not advancing to defrost every 6 hours. The plastic gears wear out over time.
Apr 18, 2008 | Admiral 26 cu. ft. Side-By-Side...
Refrigerators Logo
121 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
