Question about Samsung Jet S8000 Cell Phone
Transfering data via USB & Blue Tooth connection
I am facing a regular problem while transfering data through my USB of Samsung Jet 8003 mobile. Usually when I connect the USB cable to the PC it used to show 2 temporary drives out of which one has all the required data like movies / pictures / sounds, however the other one which is an "H" drive shows no data. The past few days it is only displaying the "H" and no data as a result I am unable to transfer data from my mobile to my PC.
My second issue is that blue tooth activation does not work always
Usually it takes a very long time to get activated & sometimes it never gets activated. The same is with the wifi wherein it shows registration failed.
I dont have data cable of nokia 1209 then, how i connect my mobile to my pc ?
you could connect using your bluetooth, just turn on your bluetooth and connect.
Jul 15, 2011 | Cell Phones
Download music from pc to mobile
With the Nokia 3650 or 3660 there are various ways to download music to the mobile phone. The first is to use the conventional data chord which connects to the phone and PC using PC suite then copy the song onto the phone.
Seccondly if your PC has bluetooth capability you could just send the music via bluetooth to the phone.
Finally you can take out the memory card on the phone and if you use a laptop slot the card into the memory card slot using a memory card adapter copy the music on the memory card and put the card back in your phone. Then you have to option of transfering from card to phone memory.
Hope this solution has been helpful?
Merry Christmas to you
Dec 25, 2010 | Nokia 3660
Unable to connect bluetooth to another cell
Some of the carriers actually have a lockout on Blue tooth transfers. So depending upon your carrier even tough the phone itself is capable it may not be allowed. I work at US Cellular and all the B tooth options on these phone are unlocked, however they are unable to link to a verizon or sprint phone for example without having their associated data plan.
The process for doing the pairing is rather simple and if you followed the steps and they still wont its a lockout.
Go to your blue tooth setting on one of the phones, turn the find me mode on or make visable to others.
take the second phone and go to blue tooth check registered devices and click new search. once you find the other phone click pair and eenter in 0000, the other phone will ask if you want to pair in which case enter the 0000 pass code again.
Once paired if you are transfering pics or music go to your media library or pic gallary and find the fill. Select options and send via blue tooth, it will bring up the registered list and select the phone you are transfering to. that should be all you need to do, if it says not supported or unable to connect the BT is disabled and you need to speak with your wireless carier for assistance.
Nov 20, 2010 | Cell Phones
How to connect samsung corby text to laptop
Do u have the data cable provided with the mobile phone ?
If so connect ur mobile with that cable to the USB port.
Install the drivers from the manufacture cd and enjoy transfering data
Oct 31, 2010 | Samsung Computers & Internet
Problem in transfering file via bluetooth
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Jun 17, 2010 | Sony Ericsson K750
How to connect samsung mobile internet without pc suite?
I found A PC blue tooth at wallmart for less that 20 bucks, transfers pics audio everything on all my cells. plugs into usb port all you have to do is install disc from blue tooth, make blue tooth on and visible on cell phone then pair them code 0000
Jun 02, 2010 | Samsung Tocco F480 - Pay Monthly Cellular...
Not working Bluetooth in my Samsung Mobile Model No.SGH-X820
try an antivirus called net protector . load net protector on your main pc, use a cable to connect your mobile to pc using a compatible software for data transfer.
mobile will get detected in the antivirus software,SCAN YOUR MOBILE may be u are lucky to get blue tooth woking , if the file has come through blue tooth netwoking , pushed by some one when blue tooth was on some time. OTHER WISE do a factory reset and save all data first.
if this too fails then the blue tooth hardware/software has to be rectified.
Sep 20, 2009 | Samsung SGH-X820 Phone
Cannot transfer photographs from mobile to computer
Most phones these days at the very least have blue-tooth, as mentioned, blue-tooth dongle which sticks into your computer via the USB port makes it very easy to wirelessly transfer files.
Nokia and Motorola phones (speaking from experience) tends to have ‘USB ports’ for connection to the PC via the appropriate USB lead using the manufacturers software, I think Motorola try to charge for it, (though there are other open-source software out there) whilst Nokia is free.
Infa-red. Though I haven’t had a laptop yet that had an infa-red sensor, and I’ve bought some pretty expensive laptops.
Most phones these days have access to the internet GPRS/WAP easy to attach it to an email and send. Although all that data-transferring could become rather costly.
Some phones can automatically upload images to website provided by your operator. I know Orange do this.
Nov 05, 2008 | HP Computers & Internet
Samsung Jet S8000  Cell Phone Logo
336 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
