Question about Simplehuman Single Cup Pod Brewer Brushed Steel Coffee Maker
Not Ready Message
I just bought in an auction. We plugged it in and added water and the light just keeps flashing "Not Ready". The tank seems to be warm and ready to go. The magnet that they talk about seems to be there and working. I emptied the tank and it said add water. I did and the message went away.
    Genius:
  • 1,689 Answers
Hi lissa,
unfortunately, the troubleshooting for Simplehuman devices can only be disclosed by their technical support team as per their website and me inquiring. below is the link for the request for in SimpleHuman website that will give you technical assistance.
My apologies if i was not able to help further, but should you have other issues in other devices, I will try my best to help out, just let me know.
http://www.simplehuman.com/service/support.html
Hope it helps.
regards,
voodoo
Posted on Jul 21, 2009
How do I reset salt level
On the left hand side should be button marked salt level, after adding product,on side of brine tank are numbers in yellow telling you the level,push salt level button to the number shown on side of brine tank. Note: do not fill over brine tank, I suggest to fill to level 6 or 7..
Oct 31, 2014 | Kenmore Ultra High-Efficiency Water...
Salt water error message when I have a water softener already
I feed Danby dishwasher salt whenever he asks (buy it by the case online). Still produces marginally clean dishes.
Apr 02, 2014 | Danby DDW1899WP Portable Dishwasher
After de-scaling my girlfriend's keurig mini, the 'add water' indicator does not function properly. It always thinks there is water in the heating tank even when I know it is empty. Because of this, the...
You could be correct in your assessment and if so, as long as the device is under warranty it needs to go back for servicing. If you open the chambers, the warranty is Void and the device a boat anchor.
Jan 21, 2014 | Keurig K10 K-cup Mini Plus Coffeemaker...
My maker keeps on saying descale. but how do i do it.
17.3 Descale
Over time, the continuous heating up of the water used to make the coffee leads to lime scale building up in
the inner circuits of the appliance.
When the message:
DESCALE
flashes on the display, you should perform the descale cycle.
Proceed as follows:
• make sure the appliance is ready.
• press the P button (the light over the button comes on) then press the button repeatedly until the
appliance displays:
DESCALE No
• Press the button (corresponding to the SET symbol flashing on the display) and the appliance will
display:
DESCALE YES
• Press the OK button to start the descale programme.
• Empty the tank and pour in the contents of one bottle (125 ml) of DURGOL descaler plus one litre of
water.
For subsequent descaling, use descaler of the same type and brand as supplied (available from technical
service centres authorised by the manufacturer).
• attach the water spout to the nozzle;
• place a container with a minimum capacity of 1.5 litres under the hot water spout (Fig. 3);
34 C o l l e c t i o n
• press the OK button.Descaler runs off from the hot water spout into the container below.
The appliance displays:
APPLIANCE IN DESCALE
• the descale programme automatically performs a series of run offs and pauses to remove lime scale
deposits from inside the coffee maker.
• After about 30 minutes, the appliance displays:
RINSING FILL TANK
The appliance must now be rinsed through to eliminate residues of descaling solution from inside the appliance.
Proceed as follows:
• empty the water tank, rinse and fill with clean water.
• Reposition the tank.
• Empty the full container and then put it back under the hot water spout.
• Press the OK button. Hot water is run off from the spout into the container below and the appliance displays:
RINSING
• When the water tank is empty, the appliance displays the message:
RINSING COMPLETE PRESS OK
• Press the OK button and refill the water tank with clean water.
• The descale programme is now terminated and the appliance is ready to make coffee again.
Oct 22, 2013 | DeLonghi Prima Donna Avante ESAM6700...
My danby portable air conditioner won't turn on
New or used? Is is plugged in? Is there electric at the plug? Plug a light in there and make sure it works as a test. Next, check the water pan to make sure it is not full of water. There is a switch there that could be causing the problem.
Jul 06, 2010 | Danby 7,000 BTU Portable Air Conditioner -...
Light keeps flashing and water will not heat
there is a float at the side of the machine by the water level, if the float gets stuck the red light will continue to flash even though water is present. Use a magnet on the outside of the machine by the water and float level and raise the float when connected to the magnet and the light will stop flashing red rapidly
Oct 05, 2009 | Philips Senseo HD7832 Coffee Maker
Keurig B70 Not Ready Message
Unplug the unit for 20 seconds- 1minute. Plug it in again. You should be able to program from the menu. Hope this works.
Feb 12, 2009 | Keurig B50 Coffee Maker
Newair ADS-300 Dehumidifier
The tank may be full. Your dehumidifier has a safety device that turns off the dehumidifier when the water tank is full. Usually the tank itself either presses against a switch or there's a device connected to the tank that triggers a switch when the tank is in place and full.
If you've emptied the tank and the unit doesn't run, inspect the place where the tank rests to see if there's a switch or mechanism that's not being activated. You may be able to turn it on with a simple flick of your finger.
Nov 12, 2008 | NewAir ADS-300 Dehumidifier
Water light can't be reset
I got my machine for Christmas and I have had the same problem almost everyday. Usually wiping down the water supply area worked but not today.. I have spent the past hour and a half trying everything I read online. Finally after reading the gray thing that floats in the water tank was a magnet I decided to maybe try to "reactivate" the magnent/sensor?.? I dumped all the water out and rubbed the magnet up and down the outside of the water tank making the gray block move up and down.. I even rubbed the magnent on the black surface where the water tank goes and the gray thing-e touches when attached.. To my surprise It worked!! It may have been pure coincidence..I dont know..but I figured I'd share anyway..It's worth a try!
May 11, 2008 | Coffee Makers & Espresso Machines
Open Questions:
Simplehuman Single Cup Pod Brewer Brushed Steel Coffee Maker Logo
55 people viewed this question
Top Simplehuman Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Simplehuman Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
