Question about Xerox WorkCenter PE120i All-In-One Laser Printer
The printer does not function on push on/off - Xerox WorkCenter PE120i All-In-One Laser Printer
    President:
  • Xerox Master
  • 1,447 Answers
It is problem this ac board or power fuse is burning or mother board problem please chack to items then you can dicission what is problem ? thanks
xptareq
Posted on Jul 20, 2009
Is cannon ir 2200 the shows me error E000051-0000. How can restore it
clearing error code E000051-0000 in canon IR2200
Try to reset the printer follow this stepTo reset the error
1. Additional functions (push)
2. Function (choice)
3. Error (choice)
4. Error code choice (wait)
5. Reset (push)
6. Right power supply off
7. Right power supply on
Oct 24, 2015 | Cannon Office Equipment & Supplies
IR3300earar E-000051-0000
1. additional functions (push)
2. function (choice)
3. error (choice)
4. error code choice (wait)
5. reset (push)
6. right power supply off
7. right power supply on
Sep 30, 2014 | Canon imageRUNNER 3300 All-In-One Laser...
I get a message to replace toner, i replaced and still get the messag
You may want to try the following steps:
  • Step 1 - First turn on your printer: Brother MFC 9840CDW.
  • Step 2 - Push the button on the front of the printer to open the cartridge cover or the front panel of the printer where you can access the toner cartridges. However, do not remove the toner cartridges (Brother TN-115).
  • Step 3 - Push the Clear/Back button and hold still to bring up a reset menu. There are 8 different toner functions ( two Black, two Cyan , two Magenta, and two Yellow).
  • Step 4 - For each of the eight functions in turn, push the O.K. button and then push it again to indicate 'Reset'. After a few seconds, it will say 'Accepted' and will then display a message that the cover is open.
  • Step 5 - Repeat the steps 3 and 4 for each of the other eight toner functions as needed.
  • Step 6 - Once your finished, close the front cover of your printer so the status bar will be reset to normal with no error message.
  • Also, you may want to clean the corona wires for each toner. Clean the corona wire inside the drum unit by gently sliding the green tab from left to right and right to left several times.
Nov 29, 2013 | Brother MFC-9840CDW Laser Printer
Clean unable 46 on brother DCP-130C
HI,
On most Brother MFC machines it is the buttons: function, *, 2, 8, 6, 4, hit the buttons within 2 seconds and in order like push function than push *, than push 2. and on within 2 seconds.
If you do this right Maintenance should show up in the display. Now press 01 which clears all memory and puts the machine back to factory default. Realize that all addresses in the fax and cover page will be gone and you will need to set it up again. Now hit 99 to leave maintenance mode and try the machine.
Jul 23, 2011 | Brother DCP 130C All-In-One InkJet Printer
Toner life end message with brand new toner cartridge.
1. Turn on the printer. 2. Push the button on the front of the printer to open the cartridge door. Do not remove the cartridges.
3. Push the Clear/Back button and hold till to bring up a reset menu. There are 8 different toner functions ( two Black, two Cyan , two Magenta, and two Yellow).
4. For each of these eight functions in turn, push the O.K. button and then push it again to indicate 'Reset'. After a few seconds, it will say 'Accepted' and will then display a message that the cover is open.
5. Repeat steps 3 and 4 for each of the 8 toner functions.
6. When finished, close the door and the status bar will be reset to normal with no error message.
Mar 12, 2011 | Brother MFC-9840CDW Laser Printer
I HAVE PROBLEMS WHIT THE CANON BECAUSE THE PRINTER HAS SISTEMA MISTEK E000
I got this fix from a copier repairman and have used it many times - it works!!
push "additional function" key. push "#" key. push forward arrow key until "#7 (printer)" appears in the screen. push "set" key. push forward arrow key until "#4 (printer reset)" appears in screen. push "set" key. screen will ask if you want to reset answer yes by pushing the back arrow key. Unplug, wait a minute and plug in again. This error will occur about once a year. save these instructions.
Mar 01, 2010 | Canon ImageClass D861 Printer
Nothing nhappens when i push scan start button
dear sir good day to make this button functions you must install the printer setup cd and it'll make the computer undrstand the push of the buttons of your printer thank you
Jan 07, 2010 | Lexmark X3480 All-In-One Printer
Could you tell me what a Print Error 021 is and how to fix it - thanks
Hello, Karen.
From FixYa Support:
You can try a LBP Fuser Reset and Error Log Clear.
LBP Fuser reset:
Press-function-7-"monitor button 4 times slowly"- then the "start" * button. It should say service mode. push 7 then push 1 then start then push 2. 1 then start
LBP Error Log Clear:
Press-function-7-"monitor button 4 times slowly"- then the "start" * button. It should say service mode then press 6 then press 1 then 6 then you're done.
If that does not work, you need a new fuser and would need to get the printer serviced.
Hope this helps.
Dec 17, 2009 | Panasonic PanaFax UF-490 All-In-One Laser...
No booklet came with my lexmark 2600 series
For color copies, you press the function key with two pieces of paper and color dots on it. For black and white copies, you press the function key with two pieces of paper and black dots on it. The link below is to the user's guide for your printer. Page 17 shows a diagram of the function keys, also, page 39 provides steps for making copies.
Lexmark 2600 Series User's Guide
Jun 05, 2009 | Lexmark X1270 All-In-One InkJet Printer
Clearing Memory
Go into test mode(function 7 then push monitor 4 times then *)test mode #6 ram initial push set,this should set machine to factory default.
Apr 19, 2007 | Panasonic UF770 Laser Printer
Xerox WorkCenter PE120i All-In-One Laser Printer Logo
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
