Question about NetGear WGR614 Wireless Router
128bit my 128bit hp laptop not connecting with my WGR614 V4 router what r the steps to be follow
  • 1,272 Answers
Follow the steps below to configure settings:
Please follow the steps on a computer connected to the router so as to check the network key:
1. Open the browser(Internet Explorer or Mozilla Firefox).
2. Access the router usually http://192.168.0.1 else try http://www.routerlogin.com
3. Login to the router with the Username as admin and password as password (unless you have changed it).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Check if 'WEP (Wired Equivalent Privacy)' or 'WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)' is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase.
7. If WEP is selected, copy the code entered in the key that has been checked.
This is the code required for connecting the wireless computer to the routers' wireless network.
In some cases, for security reasons the passphrase might show as asterisks. In this case type a new password and click apply. You will then have to use the same password for all the wireless devices connecting to the network.
Now on the HP laptop if you have XP then perform the steps below:
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab .
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove. Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight thee SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
For Vista :
1. Click START, Click Control Panel then click classic view in left hand side menu.
2. In the main screen, open up NETWORK AND SHARING CENTER.
3. In the left hand side menu open up MANAGE WIRELESS NETWORKS.
4. If you see any name in the list, please select the name and click remove.
5. Once the list is empty, click on ADD, select the first option, ADD A NETWORK THAT IS IN RANGE OF THE COMPUTER.
6. Click on your network name SSID and click on connect. If you have a password setup on the router enter the security key.
7. This should setup the wireless network.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Jul 21, 2009
  • 854 Answers
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Posted on Jul 20, 2009
Forgot password
Netgear WGR614 v4 Multi admin password Admin 192.168.0.1 OR www.routerlogin.net
Jul 20, 2011 | NetGear WGR614 Wireless Router
I put in the default login but it wont direct me to the netgear page
NetGear WGR614 router..... what version? v4 or v5 ..etc
Apr 03, 2011 | NetGear WGR614 Router
Dont have cd to run for my laptop belkin f5d7234-4 v4 router what do i do to make it work with my laptop???
If this is the only computer that you are trying to connect then you will need to set up the router from the start.
If the router is already working and there are one or more computer online already then you just need to connect to the network on the laptop.
Is it a wireless laptop or it will be connected to the router with the cable ?
If it is wireless then you will need to connect to the wireless network.
Click Here for step by step instruction
Mar 12, 2010 | Belkin F5D7234-4 Router
My NetGear WGR614 v1 stops broadcasting and needs to be repowered
I suggest you do a firmware upgrade. But in doing this, you will loose the settings on your router. You have to reconnect all you devices on the new settings.
Please follow this steps:
2. Download this link ftp://downloads.netgear.com/files /wgr614v1_1400.zip
3. Save the file to the Desktop.
Note: Please perform firmware upgrade with wired or Ethernet connection only. Before you upgrade, write down all current settings as you need to enter them manually after upgrading.
4. Using the computer hardwired on the router, open any web browser like Internet Explorer or Netscape Navigator.
5. Connect to the router by typing http://192.168.0.1 in the address field and click Enter or Return key.
6. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Setting the router:
b. Connect to the router by typing http://192.168.0.1 in the address field and click Enter or Return key.
5. Power cycle.
Sep 18, 2009 | NetGear WGR614 Router
Netgear WGR614 connectivity issue w/ Time Warner Cable modem
5. Power cycle.
Feb 28, 2009 | NetGear WGR614 Router
Need my password or key for wii consule
You can find it out by looking at the router setup page:-
http://kbserver.netgear.com/products/WGR614.asp
Select your router model (v5,v4..) and look at the docs on the webpage.
You can login to your router by using one of these IP addresses http://192.168.0.1 or http://192.168.1.1 in your browser address bar.
You will see your network key under the wireless settings.
Hope this helps.
Jan 22, 2009 | NetGear WGR614 Wireless Router
Can't connect ibm laptops wep to wgr614
On my WGR under WIreless settings I have WEP, Automatic, 64bit, Key 1 checked, and a 10 character HEX key.
There is an SSID and when I log in via laptop, it askes for the key. I input my 10 character hex number and I'm logged in.
Carl
Dec 10, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
PC repaired, can't find my original installation discs for my netgear 54 Mbps Wireless Router WGR614 v4. Is there anywhere I can download the necessary info? I'm using the router on my laptop OK. Thanks
You should be able to download everything you need. Just go to the manufacture's website, NetGear.com, go to Support>Downloads>select your product>find your V4 listed>download installation. If you cannot find it, just email support and request a CD, be sure to include your name/address/everything necessary.
Oct 18, 2008 | Computers & Internet
ISP blocking my internet connection.
hello!
-- do you know your verizon username and password?
-- what is the operating system of your computer?
-- have you tried connecting your computer directly to the modem to check if you can get online?
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings, you need to input your verizon username and password on the router setup page then save the settings.
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
May 26, 2008 | NetGear WGR614 Wireless Router
NetGear WGR614 Wireless Router Logo
119 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
