Question about Toshiba 32AF43 32" TV
Have intermittent sound on one channel
How can we fix this sound problem. Have tried pushing reset button
    Sergeant:
    Champion:
  • 375 Answers
Sounds like cold solder connection on main board./audio section
Posted on Mar 28, 2008
DnCan't change channels using the remote or buttons on TV. The channel scan will not work either. I
Just a few ideas for you -
Go to some cheap box store and buy a universal remote, they can be real cheap. More than likely, your remote died. Make sure you know your make and model number so you can get the right one.
You didn't say if you have cable, but if you do, reset that connection and let your satellite reboot, see if that works.
Doesn't that tv have controls on it, so you can manually input the channels and adjust sound?
Good luck, Curt
Jan 22, 2014 | Vizio L32 32 in. LCD HDTV
MY BOGEN RECEIVER MODEL BR 360 WORKS ONLY ON ONE CHANNEL. THE SPEAKER CONNECTED TO THE OTHER CHANNEL DOES NOT GET ANY SIGNAL.
You could have the same problem we had on our BR-320. We found that the front panel Local and Remote Speaker switches were intermittent. When jiggling the switch, one or both channels would drop out and come back. After cleaning it works great.
Dec 06, 2012 | Photography
Sound becomes distorted after changing channel requiring pushing mute button and back to sound again to restore proper sound
Tries tv unplug,replug it back like about an hour.By letting the tv by resetting itself back to the factory setting.Now goto the tv menu goto Audio Setting,go down to do resetting,so resetting the tv Tuner board for resetting sound,setting back to factory setting.This should solved ur sound problems.
Jan 30, 2011 | Vizio M370VT 37 in. LCD TV
Pantech matrix turns off when I push the period or backspace button when texting. I have reset phone by removing battery and sim card-did not fix. It is an intermittent problem
Try your reset button. It is around or under the battery. It is usually a small hole. You might need to use the end of a paper clip. If this fails, see your provider.
Dec 05, 2010 | Pantech Matrix Cell Phone
We seem to have no hot water about once a week and its not from excessive usage. The reset button on the top element of our twin heating unit trips off every couple of days. I reset the push button and it...
It sounds thermostat failure. It intermittently does not open or the overlimit is getting weak. replace your thermostats and this will fix your problem.
Oct 07, 2010 | Rheem Water Heaters
My mitsubishi projection tv, ws55813, was losing horizontal sync intermittently, turn off and back on, sync was ok. turned off and back on, once too oftern, to solve sync prob and now I have blue screen....
There is a hard reset you can try on this set--it is done with the Mitsubishi remote that came with the set.
Confirm actual model number and I will tell you how to try it. The set will shut off after the reset(not the reset button some of these sets have on the front) and come back on channel 3 in the air band--any labels for inputs will be replaced by original input numbers etc.
No guarantee this will fix your problem but it will return the set to the condition it was when new in the box.
Let me know if you want to try this.
SD TECH
Oct 24, 2009 | Mitsubishi WS-55813 55" Rear Projection...
Help Toshiba TV Problem!!! Background sound
Restore the set electronics to factory defaults. Check manual for location of reset button or contact toshiba for reset protocol
Sep 21, 2017 | Toshiba MK2103MAV 2.1 GB Hard Drive
Is there a reset button for the NAD Surround Sound Receiver T 751
The only reset that i know of is to unplug it for 15 to 20 minutes. Hope this helps.
Dec 03, 2008 | NAD T751 Receiver
Remote/tv buttons not working & start-up menu flashing
You can get an original replacement remote that will work all functions from Here: http://www.remotes.com/remotes/servlet/rs?o=c&a=Search&m=KV-27FS200&uid=11829594841080 Good Luck
Jun 27, 2007 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Toshiba 32AF43 32" TV Logo
41 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
