SOURCE: Boiling
Purchased at Canadian Tire mid December 07.....great sale....still more than I expected to spend on a kettle. EE and nothing.....same as previous customer comments.
SOURCE: HD 4651/C Electric Kettle Handle switch lights but wont heat
This maybe the thermo fuse, and or the heating element that is defective. These parts must be properly replaced for safety issues.
Usually these appliances are not worth to service.
Jerry G.
SOURCE: Our cuisinart electric tea kettle stopped working.
Most likey a burned out heating coil. You can buy them let me know the model number and I can give you a web site to go to buy it.
SOURCE: Cordless Electric Kettle won't turn on anymore.
Sounds like dirty contacts in the base.
UNPLUG THE BASE BEFORE CONTINUING ANY FURTHER!!!! I CANNOT STRESS THIS ENOUGH!!!
Once Base is definitely unplugged, take it outside and use a piece of fine grit sandpaper inserted in the contacts to give it a good rub all around. Also polish the contacts on the base of the kettle.
Blow the contacts out to make sure there's no grit remaining, and then plug in and test again. You might need to do this a couple of times.
However, make sure it is UNPLUGGED before you touch any contacts!
SOURCE: My Cuisinart electric tea kettle just stopped
I took the base apart an repaired the electrical connection. You need a special screwdriver to remove the 3 base screws. I took an old, cheap flat-head driver and filed a v-notch in the middle of the blade so it would work to remove the screws. Had to replace the connector because of corrosion. That fixed the problem for me.
