Question about Intel ASUS P4C800-E Deluxe 875P Socket 478 DDR 400 ATX Motherboard 3-in-1 Combo (MP4C800EDLXCOMBO)
PS_ON revertsto high as soon as +12V starts to appear on 2+2connector
Can't start system. If 12V2+2 connector plugged into MB, PS_ON goes back high right after going low. If 12V 2+2 not plugged in, power stays up, fans run, voltages check OK. All true with peripherals removed, only CPU and a couple HDDs to load the PS.
What conditions cause PS_ON logic to reject power when 12V2+2 connector is connected?
  • JAStarr Nov 20, 2007
    thanks, 24. Presumably, the overcurrent would be the result of short or excess peripherals on MB, and I think the 12V 4-pin connector only serves the CPU, so it might be implicated. Actually, I think the chip controlling the PS_On is more likely. But the big question is can the rise time of some PSUs be unacceptable to that PS_On logic? How many PSUs should I try to be sure the problem is the MB? or can I get the PS_On logic so I can watch the startup events with scope to see what's tripping it?
  • JAStarr Nov 23, 2007
    24, process you described would determine at what point the PSU trips. I need to know what causes the PS_On to trip on the MoBo--it is happening before the PSU ever gets up to 12V--it maybe gets to 2V before PS_On reverts to high (I don't have a storage scope, so can only watch the transient events as they happen). I've tried a third PSU now; same result--it's the MoBo. I need the logic of PS_On and what chip ANDs the required conditions together to pull PS_On low so I can see what's making it go back up, Know where I can find that? Thx.
No need to get testy--no pun intended--I do appreciate your thoughts and help. What I want is to save the MoBo if I can. I'm sure it is deciding to turn off the PSU for a reason. I know the PSU will shut down if there is too much current draw, but I don't know what bad conditions the MoBo will use to shut down--probably voltage not reached in x msec, maybe overvoltage, and maybe in my case, the logic chip that ands the necessary conditions together and latches PS_On low is burnt. Today I'll try tracing the 12V from that connector on the board--probably doesn't serve much more than the CPU. Maybe I can find something.
Posted on Nov 24, 2007
  • 883 Answers
Usually it is over-current that will make PS_ON go high. However, the opposite is true: if not enough load draw, PS_ON goes high and never goes low. Not exactly certain about link to 12V2+2 connector, although same theory may apply.
Posted on Nov 20, 2007
  • Marty marty Nov 20, 2007
    set up a bench test for supply as follows:
    connect all but 12V 4-pin connector to mobo. now connect a load rheostat (a variable resistor to emulate various loading) from the 12V 4-pin connector to ground. Also connect scopt to PS_ON. Start with about 1 amp draw. Repeat process until you see a fault on PS_ON. Then determine if your total current draw exceeds supply nameplate. Alternatively, you can measure resistance from the 12V 4-pin connector on mobo to ground and calculate same load.
  • Marty marty Nov 24, 2007
    ok, just one thing...if you say "'s the MoBo. I need the logic of PS_On and what chip ANDs the
    making it go back up, Know where I can find that?"...then focus on the mobo. If you want to force PS_On HIGH, then push that wire out of its socket and the mobo should continue to have power....may harm the mobo, but what is that you really want to accomplish...a new mobo?
I recently replaced the multi-function switch on my '95 Olds Achieva because the high beams did not engage. Problem solved. But now, it won't start. I was able to start it initially to take it in for the...
Check the ignition switch connector. Check for 12v on the start circuit with the ignition in the start position. Check neutral safety switch connector. Check for 12v in and out of the N/S switch when the gear selector is in neutral or park and the ignition is in the start position. If you have 12v there check at the small terminal on the starter solenoid. If you find 12v there and on the big terminal there would appear to be a starter problem.
Apr 20, 2011 | 1995 Oldsmobile Achieva
Followed advice from "Ulangreg"...still have
It appears the motherboard is faulty. When the power supply is overloaded it will shut down. You have confirmed this by by removing the eatx connector and it powers up again.
Mar 02, 2011 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
I've got a new Gigabyte Ga-M68Mt-D3 mobo paired with a cooler master 460 watt power supple. Cpu is Amd phenom II 3.2 ghz with 4 gig of DDR3 ram. I powered up the supply attached to my ATX power supply...
Most motherboards now have a 24-pin power supply connector. If you haven't already found a diagram showing the pinouts of the 20- and 24-pin power plugs, here's one borrowed from a handy site:
The two plugs are essentially the same, but the 24-pin version duplicates some voltages on the extra pins. The extra pins in the larger connector were meant to provide extra current paths for voltages that see heavy loads from newer processors and motherboard circuitry. Depending on how a motherboard is designed, it might work with a 20-pin plug connected (leaving pins 11, 12, 23 and 24 empty). But typically if the board has a 24-pin connector it needs the 24-pin power supply plug.
Most power supplies have a 20-pin plug with a separate 4-pin section that fastens to it for connection to a 24-pin mobo connector. It typically has one side designed to slide onto the end of the 20-pin plug, essentially turning it into the 24-pin version. This added plug does not have a retaining clamp on its side, so you can tell it from the the 4-pin CPU power plug. The wire colors are also different. For reference, here is the processor power plug, from the same website:
New motherboard specs call for the separate processor power connector for the same reason the extra pins were added to the power supply connector: to handle the high currents needed by increasingly faster CPUs.
When the motherboard has these connectors, you need to use them all to get everything working. Hope this helps. Thanks to for the diagrams, and thank you for using Fixya.
Nov 19, 2010 | Computers & Internet
My system is win.xp home the game is need for speed carbon. iget no error mess. and i dont know what os is. i click the icon and the game starts to load and the screen goes black and returns to the main...
Follow the steps below. Its from PlayStation Forum:
1. Turn off Playstation.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION.
• Restore PS System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION System
If the above steps still does not solve the problem, then I think will have to update your PS.
Update your PS (in the settings menu the 1st option).
Go on the internet browser on the PS then go on the menu press triangle then on one of them there are delete cookies and the delete the others as well as cookies.
You could also try this as well: put the PS on then press the eject button (with no disc in) then hold it and switch the PS off at the back with your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
Take care.
May 31, 2010 | Video Game Consoles & Games
Plugged computer back in after move and won't start. green light in mb on.
Actually, there is nothing you can do with the hard drive. If its shorting out the power supply when its pugged in then it is defective. However, most hard drives carry a 3 year warranty from the manufacture. If the drive is younger then 3 years old, I would call the manufacture and get it repaired or replace. Hope this helps . . .
May 16, 2009 | Antec EarthWatts EA380 380-Watt Power...
XION Case and Supply
Try unplugging, then plugging back in the 20/24pin power connector. When you plug in the power connector, make sure the power supply is OFF and the switch in the back is OFF and nothing is plugged into the computer.
Jul 21, 2008 | XION (XON-500F8X2-201) (XON-500F8X2-201)...
pls try change the power cable if it works then check your power pack if the FAN doesn't roll that means you have to change the power pack thanks.
May 24, 2008 | Computers & Internet
Pc won't turn on
Hi, Are you able to test or repair some of this your self? is so use a multimeter and check the power supply,If you get no reading then remove the unit and open the cover, on the printed circut you will find a fuse either glass or ceramic. Replace this and also clean all dust from the unit replace the cover and reinstall in computer. If this fails you may need a new power supply unit. Regards mistyman
Sep 07, 2007 | Dell - NPS-200PB-73M (NPS200PB73M) Power...
Intel ASUS P4C800-E Deluxe 875P Socket 478 DDR 400 ATX Motherboard 3-in-1 Combo (MP4C800EDLXCOMBO) Logo
426 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
