Question about Panasonic Video Cameras
Cassette will not eject (panasonic nv ds77)
Used this to record a short piece of video this morning which seemed to work fine but then would not replay. Screen now black except for battery level and 'F 03'. Tape will not eject when open/eject button used. Power light flashes.
Please help, there is irreplaceable footage of my baby son on that tape!
SOURCE: Message reads eject. won't eject
Ihatecanon, Tried the steps you provided above with no luck. Then decided to gently smack the camera twice on the right-top side of the tape compartment. It freaking worked the first time. Got this idea by watching Eric Cartman on South Park... No, really. I read about this in another forum. It's a quick $150 back in your pocket. Just think. You sent the camera to their tech guys and paid them 150 to SMACK-IT :)
Posted on Sep 29, 2007
philipp
  • 217 Answers
SOURCE: cassette area
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it. Check your tapes carefully, most cause of this trouble are due to defective tapes, especially sony brand, I recommend you use TDK tapes.
never force open any unit, it will only make things worst!!! [;0)
Posted on Nov 06, 2007
SOURCE: Canon Elura 100 won't eject tape
I have been having the similar problem. Try switching the power to off and then eject the tape in the off position. My finally ejected.
Posted on Jul 08, 2008
  • 141 Answers
SOURCE: Panasonic NV-DS65 won't eject a tape
It sounds that what's happened is your idler wheel is slipping or even your main drive belt.
When you loaded the tape it was taken by tape guides around the video drum. When you pressed eject the tape guides returned to their proper places but the tape stayedin a loop around the mechanism because the take up spool had no drive to pull the tape back into the cassette. When you've tried to pull the cassette out of the camera that loop of tape has snagged on part of the mechanism and that's what is stopping the cassette from being removed. I'm afraid the tape would be damaged at that spot so you may as well simply snip it with a pair of long bladed scissors and the cassette will pull straight out.
What is then required is either the drive belt changed or the idler wheel assembly changed. Either way a service center will be required unless yourself or a friend is able to buy the parts (not expensive) and do the work required.
Good luck
Posted on Apr 24, 2010
SOURCE: Panasonic nv Ds30en
I have apanasonic NV DS30 play problem after capturing they could not play
Posted on Oct 21, 2010
No playback on my nv-dx100
Try putting a DV Head cleaning cassette into the unit, should work a treat!
Oct 02, 2012 | Panasonic NV-DX100 Camcorder
Panasonic dvd video camcorder VDR-M55PP
system malfunction, put a soft reset on the camcorder.
Feb 24, 2008 | Panasonic NV-DS65 Mini DV Digital...
I have a VCR Panasonic NV - FJ623 and when I insert a video cassette into it for playback or recording purposes,it always ejects the video cassette.Can you help, please?
I'ts likely that the record sensor that pushes on the tab on the tape is bent or broken. Making the VCR think you are trying to record on to a protected tape.
Oct 22, 2011 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Good luck
Apr 24, 2010 | Panasonic NV-DS65 Mini DV Digital...
Panasonic NV-EX3B Help
It is 10 years past its useful life.
Sep 23, 2017 | Panasonic Video Cameras
I cant eject my Panasonic NV-GS55 Mini DV Digital video cassette
Try ejecting cassette whilst powered from AC Adaptor. Secondly, try operating Eject from powered off mode. If operation LED starts flashing after any of these attempts, the mechanism is probably jammed or has become mis-timed. Unfortunately this requires professional intervention to avoid further damage to your equipment.
I hope this information is of assistance!
Jan 01, 2010 | Panasonic NV-GS55 Mini DV Digital...
Tape ejects when inserting into video player
check the tab on the back side of the tape- make sure its intact- if tab is missing it will not let you record - i've sometimes added tape to replace the tab ,,
Feb 02, 2009 | Panasonic NV-HS1000 S-VHS VCR
VC recorder keeps on driving
I beleave your sensor that tells the player weather a tape is in there or not needs replaced ~ It sounds like it doesent know the tape is not there aand will not shut down! (replace tape sensor)
Please rate my answer and help keep this site free!
Dec 31, 2008 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Panasonic video recorder malfunction
It sounds like you need a service manual - it tells you how to remove stuck tapes etc.If you need a service manual for this model, which is helpful for checking things/disasembly/assembly, you can obtain a free one from:-
http://www.reptips.dk/Reptips/NV-FJ620.pdf
Panasonic Video Recorder has stopped working
looks like some kind of sensor within the mechanical part, its seems like the mechanism doesnt return fully to its original point giving you these kind of malfunctions, I suggest to take it
to an authorized dealer for a complete check up & tune up
Apr 15, 2008 | Panasonic NV-HS1000 S-VHS VCR
Video Cameras Logo
125 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
