My hausqvarna riding lawn mower rear tires do not move forward or backwards. I have tried pulling the pin in the rear to engage and also tried the parking brake but still not results
There are two transmission pins that engage and disengage transmissions so you can drive it or push it around. Usually around the rear of the mower by the tires.
I don't quite get you, if the belt is running but the rear axle is not turning then your transmission is shot. If the belt is running and the rear axle is spinning with no forward or backward motion, then someone took the back wheels off and put them back on without installing the keyways.
Check for a worn belt first.Then check the linkage. Next jack the unit up and try to run it forward and reverse with the engine running.If there is any movement at all in either direction then check the fluid level to see if it is up to the top.The worst case is the hydro. unit has a stuck check valve or something broken inside.Hope some of this helps. donnyb60
