Question about Sony KP-46WT510 46" Rear Projection HDTV
Kp46wt510 rear projection . The words are blury on the screen.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 80 Answers
Before starting this DO NOT SPRAY CLEANERS IN OR AROUND TV or change factory adjustments.... OK now that's out of the way first remove the front face you should see 3 lamps gently clean each with a clean rag move to the large mirror in the back clean it well then to the lenticular lens or the front screens use microfiber rags these are plastic and easily scratched this should not only clear up the image but make it brighter do this every 6 months to a year................. I hope this helps
Posted on Jul 20, 2009
Half of the screen is clear and left side of the screen is blury
Its a Common Problem with Projection Tv's ~ If your flash focus is not correcting the problem, And It can Not be Adjusted in your service menu: under Manual Convergence, your IC chips and maybe a few resistoirs may have failed and need to be replaced!... onegeo
Jul 07, 2009 | Sony KP-46WT500 46" Rear Projection...
Picture distortion
This is a convergence problem which will require soldering of convergence amps. Occasionally, you can get away with just resoldering the pins of the convergence i.c.s, and other times you must not only change the chips, but also replace burnt resistors in that circuit. In most cases you can get a reputable shop to do this repair for 200-300. Good luck, Russmann.
May 05, 2009 | Toshiba 42H81 42" Rear Projection...
Ghost shadows on the Sony KP-46WT500TV
you can get the KP46WT510 convergence repair kit at the following link under convergence repair kits category which will also work for your model.
http://servicemanuals.vstore.ca/
Apr 12, 2009 | Sony KP-46WT500 46" Rear Projection...
Red ghost in the screen
you can get the KP46WT510 convergence repair kit which will usually repair that issue at the following link the repair kit contains both ICs six pico fuses and 4 of the feed resistors also includes instructions with pictures on how to do the repair.
Feb 09, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Location of the convergence circuit board on KP46WT510
they are located on the board on the left when looking in the rear of the set ( Brown Board) you can get the convergence repair kit at the follwing link which has the ICs , the six pico fuses and four of the feed resistors, plus it comes with instructions, Here's the link.
http://servicemanuals.vstore.ca/product_info.php/pName/sony-kp46wt510-convergence-repair-kit/cName/convergence-repair-kits
Jan 29, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Television picture
Is it bouncing in and out or just blury? If its bouncing in and out you can get a repair kit on www.magnavoxhelp.com. If its blury my guess is that the convergence IC's STK-392-120 are bad.
Aug 04, 2008 | Philips 60PP9202 60" Rear Projection...
No color and green and or purple color stripe
Yes, sounds like the convergance IC's. They will need to be replaced.
Apr 13, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
KP-53S65 blury at times
the screen control and the focus control on the flyback transformer need to be turned down a little
Nov 12, 2007 | Sony KP-53S65 53" Rear Projection...
Convergence problem with my KP46wt510...!
They go on the largest heatsinks in your set---the " back" side,
if you look over & down......that PC board must come out to
replace IC's.......
Nov 05, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Blurry on one side of screen. Green and purple shadows
Convergence IC's should be replaced before any alignment is
attempted ....part # STK392-560....You need two......mount
to large heatsink...............T.
Oct 31, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-46WT510 46" Rear Projection HDTV Logo
251 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
