My washing machine is not working?? - Washing Machines
  • 77 Answers
  1. Fixing an Agitator One of the most common problems with a washing machine is due to a broken or malfunctioning agitator. The agitator is the piece of plastic that moves back and forth. In order to fix the agitator, you must first remove it. If the agitator is not broken, but moving slowly in one direction or not at all, this can be due to the clutch assembly that the agitator relies on. You can remove the agitator and check the clutch assembly. The clutch has dogs that depress and pop up with each turn, however if these dogs are worn, they will need to be replaced. You can usually contact your washing machine manufacturer and order replacement parts. Alternatively, you could get one from a home improvement store that stocks common washing machine items.
  2. Electrical Problems Sometimes a washing machine may have electrical problems that can include a blown fuse, a broken timer, switches that are not functioning, etc. Obviously, before you fix a problem with the electricity, make sure you unplug the washing machine. First, check your fuse box and your electrical outlet. Some types of washing machines require higher voltage to work and it might be a problem with your home’s electricity rather than the washing machine. In addition to checking the outlets and fuse box, check the cords and electrical system of the washer machine. Most washer machines will have fuses that are accessible from behind the unit. Check to make sure all are working properly. If you are having a problem with a specific switch such as a timer or thermostat, you might want to check the connection or replace the timer or thermostat completely. Usually this only requires a screwdriver and the new part.
  3. hope your problem will be solved
Posted on Jul 20, 2009
Error code 141. How can I fix it?
Bosch error code 141 Washing Machines Questions ... - Fixya
www.fixya.com > Forum > Tags > error code 141 > Washing Machines
Bosch washing machines error code 141 related questions and answers. Ask your Bosch questions. Get free help from washing machine experts.
error code 141 Washing Machines Questions & Answers ...
Washing Machines error code 141 questions and answers. Ask your error code 141 washing machine questions. Get free help, advice & support for popular ...
Zanussi Washing Machine Fault Code Reset - iFixit
https://www.ifixit.com/...Washing+Machine+Fault+Code.../34977
iFixitMy Zanussi Washing Machine hasn't been working properly for a while. then it stopped spinning and emptying, then wouldn't go through the programmes at all.
[PDF]TOP LOADER Automatic Washing Machine - you
Dec 29, 2015 | Washing Machines
We bought electrolux washing machine ewf 85761 in penang malaysia, before we brought on board ship test is done on the store,the washing machine is in good condition..Then we brought the washing machine on...
Just as a wild guess, the control circuit in the washer may not work with 60 Hz shipboard power. The motor probably is not affected. You must be getting awfully tired of hauling that washer back and forth!
Sep 07, 2012 | Washing Machines
Circuit diagram
Please check on the link below and you can get an idea of the parts and working of a washing machines.
click for parts:
http://www.espares.co.uk/advice/washing-machines/a/7/311/how-to-identify-washerdryer-parts.html
click for video on machine working:
http://www.espares.co.uk/advice/washing-machines/a/7/1392/how-a-washing-machine-works.html
Aug 22, 2011 | Washing Machines
Thers no power to my washing machine.changed the fuse and theresstill no power.what do i do ? thank you emma
Hi emma... Unplug the machine from it's current outlet and use a heavy duty extension cord to plug it into another outlet that you know works [plug a blow dryer in to check it].
If the washing machine works then you know the problem is in the outlet or the wiring to the outlet. IF the washing machine still doesn't work you know the problem is within the washing machine itself. Possibly the lid switch or a fuse within the machine. J.
Aug 02, 2011 | Indesit Washing Machines
Not working no taking water
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Oct 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
MACHINE IS WORKING BUT SPIN FUNCTION MODE NOT WORKING
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 30, 2010 | LG WFT1071TP Top Load Washer
Washing Machines Logo
146 people viewed this question
Top Washing Machines Experts
