Question about Samsung Computers & Internet
My Samsung Samtron 40 Bn monitor refuses to start. There were no symptoms of any degradation of picture quality while it was working fine. Could some one help me understand if it is dead altogether and needs to be replaced? It is about 10 years old but sparingly used. Any suggestions are appreciated. Thanks!
SOURCE: Samtron Monitor 56v 15''
samtron 56 v problum: switch on the monitor no ON, but two or three times switch on now ON. what is the problum
Posted on Mar 01, 2007
SOURCE: Open cover of Samsung Samtron monitor
remove two screws on lowerback of the monitor. Loosen the case at the botton and on the top. Two holes will appear on the top. With thin screwdriver push down inserting the screwdriver into this notch.This will release the case. Tks
Posted on Nov 13, 2007
SOURCE: unable to use intex external TV tuner with acer 19''
my display is moving upside- down & sometimes rotating
Posted on Dec 06, 2008
bhagyavichar
  • 414 Answers
SOURCE: My samsung 55v samtron monitor get wet and now it
vry critical....
however look mainly for the smps section..the fuse, bridge, ic (dp104c) & hot (c5404), high value resistances, diodes, opto-coupler ic, ntc, switching transistors n other associative transistors..open the final anode cap carefuly n thoroughly clean with a cotton dapped/soaked in iso-propyl alcohol, also clean the souldered side of the pcb(s), if necessary look for dry soulder n re-soulder them..beware u must b a professional
Posted on Oct 24, 2009
bhagyavichar
  • 414 Answers
SOURCE: samsung samtron 55v display problem
assuming that u r a professional..
i guess there is no problem with ur monitor, it sounds like itz due to graphic adapter..either the adapter on ur system main/mother board/agp/pci/pcie is damaged or itz simply 'driver corruption'..
don't panic..check for driver update/download n reinstall graphic/display driver..
however, 1st make sure that the Screen Resolution (1024x768 or as applicable) and Color Quality (32 bit or as applicable) is correct..from Display Settings->Settings tab..
always better to contact system admin/vendor....
Posted on Oct 28, 2009
What would cause very dark blurred display all modes on Samsung P2250?
the tube lamp is degraded an needs replaced . the high voltage to the lamp might be weak corroded connection too.
consider changing the lamp out for led strip
i ordered 1 ccfl lamp many times from china for 2.50 an they are always damaged . too long for the mail.
i can order the same ccfl lamp from us for 40.
so
im going to insert led strips in place of the lamp.
its not that hard if your a tinker
Jul 25, 2014 | Samsung SyncMaster P2250 22 inch LCD...
Samtron 55e computer desktop,monitor screen is pink and then with the blue coded plug that goes in back of tower is on it turns black and then when i take the blue colored coded plug out the screen turns...
Samtron (a former subsidiary of Samsung) as an entity no longer exists, and I have been unable to find any legitimate links to archived support documentation.
The symptoms you describe indicate that the monitor has failed. One way to verify this is to connect another, known good monitor to the same output on your computer. If that other monitor works, then yours does not and it is not the computer's output that is bad.
Looks like time for a new monitor.
Hope that's helpful.
Jan 17, 2011 | Samtron 96BDF 19" CRT Monitor
I have a Samtron 98BDF crt monitor that has a focusing problem. I notice the more I turn down the contrast, the image will eventually get sharper. If I turn the contrast up the image will eventually get...
I have a Samsung Samtron 97BDF and i have problems with the information cable, so i need to change it, how can i do? Maybe someone have pictures about how to make..
Sep 14, 2010 | SAMTRON 98BDF 19 in.CRT Conventional...
Samsung samtron monitor does not work
Please check whether the power cable is properly inserted...
The power button of this model fails with time.You need 2 press it tightly and hold it till the LED is on....
try this...
Hope this helped...
Dec 21, 2009 | SAMTRON 55V 15" CRT Monitor
BLINKING OF SCREEN
check for Dry Soulders & FBT....
Jan 06, 2009 | SAMTRON 55V 15" CRT Monitor
Samsung samtron 55v display problem
Dec 30, 2008 | SAMTRON 55V 15" CRT Monitor
ATI RADEON X1650 -- Video degrades during vewing - becomes blotchy and red
welcome to fixya
the video card might not be getting enough power you should have a 500w power supply or higher with that video card if you have this already might want to see if you can download any new drivers for the video card
i hope this helps out have a good day
Jul 18, 2008 | ATI RADEON X1650 Graphic Card
Problem with H-Size
you know,in the main board of a monitor you can find a trimmer resistor in horizontal section try to rotate it while the power is on so that you cn see the effect/
Oct 06, 2007 | SAMTRON 55V 15" CRT Monitor
Computers & Internet Logo
100 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
